Chosen engine oil for 2.1 WBX motor
Gday all,
I'm wondering whether there is some commonality of views amongst
members as to which engine oil is preferred in the 2.1 WBX.
Service people for the previous owner of my Syncro were using Mobil S
Synth 10W-40 for about 5 years.
In the other cars in my family, I've been using Castrol Magnatec 10W-
40, so I'm wondering if it would help or hinder if I swapped to
Magnatec for commonality. Magnatec is straight mineral oil, whereas the
Mobil S Synth 10W-40 is a mineral/synthetic mix.
Any comments would be appreciated. Cheers.
I have tried various oils in my syncro over the last 220,000 K's and keep going back to
Castrol GTX2.The viscosity suits our climate and its characteristics seem to be quite stable
over the lifetime of the oil. I found the fully synthetic Mobil to be too expensive while the
one you mentioned Mobil S changed viscosity over time and kept tripping the low oil
pressure switch on very hot days after big hill climbs, eg 35deg. days and 10 mins
constantly in 3rd gear. Have done 310,000 km on the same motor with the last 220,000
being with Castrol GTX2 99% of the time.
-- In Syncro_T3_Australia@yahoogroups.com, "Ken" <unclekenz@...> wrote:
> Gday all,
For what its worth my specialist VW/Subaru mechanic reckons they have quite a few owners complaining about noisy tappets which they diagnose as too heavy an oil causing the hydraulic valve lifters to be slow in pumping up. They fix them by replacing with lower viscosity oil. They put in a 10-30 grade non synthetic German brand for my trip to WA . They also justified the low viscosity by it being winter. Do I understand correctly that multigrade oil basically is the viscosity of the lower level with additives to allow it to still perform like an oil at the heavier level of its range. Car certainly ran well but have no idea of course about wear. Topped up with about half a litre after about 6000Km and changed oil i a little later than I would have liked on return after a total of 12000Kms.My 2.1 WBX motor has now done 165000Kms. I previously ran a Peugeot 505 Wagon on GTX2 and sold it  with the original untouched motor still running well  at 380,000Kms which seems to bear out Nick's experience. I think if I had one of the new T5 diesels I might think differently but our engines are not of that generation.
-- In Syncro_T3_Australia @yahoogroups. com, "Ken" <unclekenz@. ..> wrote:
> Gday all,
Send instant messages to your online friends http://au.messenger.yahoo.com
Gday Nick and ALL,
Thanks a lot for your input, good points. Some comments to add ...
I see in the owners Syncro handbook, VW indicates for a climate range of
-10 to +30 degrees centigrade, an oil of either 20W-40 or 20W-50. GTX2
is 20W-50 so Nick you are spot on there, whereas I referred below to
10W-40 oils which, if anything then, are more likely less ideal for
usual summer/winter Australian temperatures for this motor.
Also, selecting a thin oil rated 10 might be good for circulating oil
quickly at cold startup but in a motor designed and built 15-20 years
ago and with 100-300 thousand klms up, there's a good chance that motor
will burn oil excessively and it'll show up at the exhaust. Again, on
balance, your 20 grade oil makes more sense.
Reading around online, I get the general impression that mineral oils
deal with heat better than synthetic, both in climatic conditions and
the heat of the oil in the motor. And seeing as the 2.1 WBX motor isn't
exactly the latest technology nor turbo charged, seems to me on balance,
synthetic is not the right oil here. And certainly if the Syncro is
going on outback safari, the 50 rated oil, as you stated, is again
correct for this motor.
So now I ask, which 20W-50 mineral oil gets the guernsey?
Guess it could come down to a mineral type oil that has a preferred mix
of added "goodies" that boost either/and/or smoothness, contamination,
heat, flow, seal, lubrication etc. handling best. Methinks the gallery
is still awaiting the jury's (syncro members?) verdict. Penny for your
thoughts please anyone.
Coincidently, a motor mechanic who rebuilds motors said to me just the
other day, the oil he uses in rebuilds and in his own cars for years is
Shell Helix Super 20W-50 (mineral). Again a consistency with your oil
type Nick.
Lastly, I'm also getting the general impression that to enhance
longevity of the motor between rebuilds, changing engine oil at maximum
5000klm intervals and oil filter at 10000klm intervals is the way to go.
Yes/no?
Anyone else like to add their tuppence worth to Nicks and mine would be
very much welcomed. TIA all. Cheers.
--- In Syncro_T3_Australia@yahoogroups.com, "nickbellau"
keep going back to
and 10 mins
the last 220,000
> -- In Syncro_T3_Australia@yahoogroups.com, "Ken" unclekenz@ wrote:
> > Gday all,
S
10W-
the
Gday Roger and ALL,
Thanks Roger, another great contribution to this topic.
Noisy tappets eh. Yes in my case though when I start it up after its
been parked in the garage for up to say a week without use, I experience
what seems to be, as you say, noisy tappets. I raised this with my VW
mechanic and he seemed pretty non-plussed about it as an issue that
needed addressing in any hurry. I do know after running it for a short
while, the noisy tappets sound disappears. Seems to me its a bit of a
balancing act as to what issue/s is uppermost in your mind as the most
important, sways you toward a particular type of oil.
Again, if you go by the VW handbook, it indicates that a thin 10 grade
oil isn't really warranted until you get below minus 15 degrees
centigrade. Maybe that in the snowfields or Tassie, not sure about WA in
winter. My guess is your mechanic is simply prioritising dealing with
the immediate problem of sticking (noisy) tappets. Similarly Roger, my
Syncro has done 175,000 klms, close to yours. Noisy tappets too at
times, like yours.
Roger, I'm sure there are forum members who can expertly define here
what the various gradings of oil really mean, for example ... 20W-50. As
a laymans general guide, and I stand to be corrected and refined, the 20
refers to the viscosity (thin/thickness/stickyness) of the oil and the
50 refers to the heat handling capabilities of the oil. On top of that,
makers add various expendable "goodies" as well to enhance performance
in various ways. Fact or salesmanship or a bit of both? Probably both.
Another hint given to me recently is ... one should try and select an
oil that is more commonly available throughout ones travels in
Australia. In other words, selecting a you-beaut obscure engine oil in
Sydney, it won't necessarily be available off the shelf near say, the
Tanami desert. Lugging spare you-beaut oil around Australia I guess is
an option. Somewhere to stash it all. Extra weight. More wear and tear.
Oh dear.
Lastly, I haven't investigated this yet but I should soon ... knowing VW
has its own endorsed coolant fluid ie., G12+, does VW also sell its own
endorsed engine oil for normal range of year round Australian
conditions. If so, shouldn't we simply be using it?
Good stuff Roger and thanks again. More thoughts please anyone? TIA.
--- In Syncro_T3_Australia@yahoogroups.com, Roger Bell <bellrmit@...>
> Cheers
> Roger
> nickbellau nick.bellgrove@... wrote: I have tried various oils in my
and 10 mins
the last 220,000
> > Gday all,
S
10W-
the
I fixed the noisy tappet problem by using Mobil 1. I can now leave my syncro for months and there is no noise on start up.
As for changing oil at 5k and filter at 10k. Why? Better off changing the filter at 5k and the oil at 10.
10W-50 oil acts like a 10W oil when cold and like a 50W when hot. Synthetic oils can stand heat much better than mineral oils. Mineral oils break down and go thin when overheated.
> Gday Roger and ALL,
> times, like yours.
> Oh dear.
> > Cheers
> > Roger
> and 10 mins
> the last 220,000
> > > Gday all,
> S
> 10W-
> > > Ken
Gday Phil and ALL,
Very nice contribution .... thanks a lot and much food for thought here,
particularly for all those people concerned about the need to fix the
noisy tappet problem.
I know there are a range of views about using additives to fix problems,
I for one believe selecting a quality additive, after consultation with
my mechanic, is an alternative worth considering. Beware there are
cheap, dodgy products available, sticking to a quality brand like Nulon
is much safer.
Phil you suggested changing oil filter at 5k and oil at 10k instead.
Using Mobil 1, a synthetic oil, that may well be possible, given what
one reads about it's claimed longevity in a modern motor. Using mineral
oil, sure it would likely help keep the oil cleaner for longer. As I
understand it though, by 10k, the added expendable "goodies" in the oil,
in there to enhance a range of performance and protection functions, may
well and truly have been expended by then. Hence the 5k oil change, that
renews the "goodies" to benefit the motor and the filter is good for 10k
in this case.
As I said in a previous post, my syncro has had a semi synthetic oil in
it for at least 5 years under the previous owners service people. I've
never used a synthetic oil, that's why it's timely for me to have
started this topic to get a discussion going and perhaps we all get to
learn more from each other. Because I've found it confusing reading
about the claimed attributes of synthetic oils on the one hand, yet on
the other hand, motor mechanics, oil salespeople and others I speak with
give it a drubbing for reasons such as an unnecessary waste for this
older design VW motor, question the validity of claimed attributes, say
it's mostly a current fad except for latest technology engines and
performance vehicles, and in any case, way too expensive.
I stand to be corrected about commonality of oils used in members
syncros, that was the reason I started this topic. At this stage, if
this was a poll, there is no clear winner either way, I'm hoping for
more input from other members to add to the knowledge base. Thanks again
Phil. Any more members input please? Cheers.
> > Ken unclekenz@... wrote:
> > Gday Roger and ALL,
experience
VW
short
a
most
grade
WA in
with
my
> > times, like yours.
20W-50. As
the 20
the
that,
performance
both.
an
in
the
is
tear.
> > Oh dear.
knowing VW
own
> > Cheers.
> > --- In Syncro_T3_Australia@yahoogroups.com, Roger Bell bellrmit@
have
diagnose
in
They
They
lower
of
6000Km
after
original
out
might
> > > Cheers
> > > Roger
> > > nickbellau nick.bellgrove@ wrote: I have tried various oils in my
characteristics
be
days
> > and 10 mins
with
> > the last 220,000
> > > > Gday all,
Mobil
> > S
> > 10W-
whereas
> > the
> > > > Ken
All of the oil companies have engineers that are very willing to provide technical information. Give them a call.
Any decent oil will last a lot more than 10k without losing its properties. The oil lasts longer than the filter.
I don't see any difference between an old technology engine and a modern one. It's all about bits of metal rubbing up against other bits of metal. Synthetic oils were around long before the WBX motor was designed.
> Gday Phil and ALL,
> is much safer.
> in this case.
> > > Gday Roger and ALL,
> experience
> VW
> short
> a
> most
> grade
> WA in
> with
> my
> > > times, like yours.
> 20W-50. As
> the 20
> that,
> performance
> both.
> an
> in
> is
> tear.
> > > Oh dear.
> knowing VW
> own
> > > Cheers.
> > > Ken
> have
> diagnose
> in
> They
> They
> lower
> of
> 6000Km
> after
> original
> out
> might
> > > > Cheers
> > > > Roger
> characteristics
> be
> days
> > > and 10 mins
> with
> > > the last 220,000
> > > > > Gday all,
> Mobil
> > > S
> > > 10W-
> whereas
> > > the
> > > > > Ken
