Clutch gone in Tamworth
The Pell boy should have one.
hartmut
On 08/04/2013, at 8:40 PM, Mr Scott Pitcher wrote:
It wasn't the fan that was the issue - it was the shroud - mine was damaged by someone and was very weak in the arm sections that hold the fan allowing it to droop and hit the damaged shroud. The fan still runs perfect - just need to find a shroud in good nik to reuse it again.
Thanks for the advice.
On 8/04/2013 8:10 PM, plander@optusnet.com.au wrote:
There is about 6 different fan motors in T25s. Syncro ones are much larger than 2WD. (and much noisier)
To:
<Syncro_T3_Australia@yahoogroups.com>
Cc:
Sent:
Mon, 08 Apr 2013 20:00:26 +1000
Subject:
Re: [Syncro_T3_Australia] Syncro Radiator Fans
Phil,
The fan blades are the same size and the shroud diameter is exactly the same - its just the fan motor that is significantly larger - mines a monster - but it has hand written Audi fox written on it like it was plucked from one and stuck in my syncro?
The 2wd fan is very quiet and very effective too - in traffic it works well.
On 8/04/2013 7:53 PM, plander@optusnet.com.au wrote:
Syncros have a larger fan than 2WD in Australia Early models may differ.
2WD has the relay on the fuse box.
4WD has the relay mounted on the body to the left of the fuse box.
To:
Cc:
Sent:
Mon, 08 Apr 2013 19:45:16 +1000
Subject:
Hi All,
My radiator fan was becoming significantly noisy and the shroud was
significantly deformed and therefore I replaced my shroud and fan with
one from a 2wd caravelle from around the same year.
I noticed my original syncro one had written on it Audi Fox and the fan
is an absolute monster approximately 1.5 inches ;larger than the 2wd
"new" version and the shroud is made to fit it.
The shroud dimensions and fixings are exactly the same and the shroud
shape is basically the same.
Hence, my question is - did we get larger fans for syncros or was my one
put in there by its previous Owner "Beetle Wreckers"?
Or both?
Thanks for any opinions.
Thanks Hart but I like my new 2wd - very quiet and very effective with the new Behr radiator.
SKot
hartmut
To:
Cc:
Sent:
Subject:
Phil,
To:
Cc:
Sent:
Subject:
Hi All,
Or both?
Three things to look out for here. That the breather grommet and line are inserted in the top of the case. That the black bung is fitted at the bottom of the case. Lastly that the bell housing is sealed. Most of these measures are to keep water out. If sand is getting in I would guess one of the two bungs are missing and if they left a bung out they would not have sealed the bell. Greg E
Sent: Monday, 8 April 2013 7:46 PM
Subject: Re: [Syncro_T3_Australia] Re: UPDATE - Clutch gone in Tamworth
At least it is quality sand. How would you stop sand/ water/ mud getting in there again?
On 8/04/2013 7:39 PM, peter_kolevas wrote:
Faser Island!
--- In mailto:Syncro_T3_Australia%40yahoogroups.com, Mr Scott Pitcher mailto:spbconsulting@... wrote:
> Well done Peter.
> We all knew the North Coast crew would sort you out one way or the other.
> There is now another good repairer of syncros on the list.
> Where did all that sand come from Peter?
> Skot
> On 8/04/2013 6:40 PM, peter_kolevas wrote:
> > For those that were following my troubles and those that helped thank you.
> > After losing the clutch operation I drove clutch-less from Tamworth to
> > Port Macquarie where I found several people that were recommended by
> > forum members who could work on the car but the problem was that it
> > would the 2-3 weeks before they could get to it. So I drove to Taree
> > where I found Jarrah from Jarrah Automotive who was able to work on
> > it. Although not a dedicated VW mechanic he had some T3 customers and
> > 1 Syncro customer. i was very pleased with his work and price.
> > After checking all hydraulic components he pulled the gearbox out
> > which proved to be difficult because the pressure plate, clutch and
> > flywheel had bonded together. When eventually separated he found a lot
> > of sand in the bell housing and a destroyed spigot bearing. He
> > installed a new clutch kit (pressure plate, clutch plate, thrust
> > bearing and installed a new spigot bearing and everything worked a treat.
> > So back on the road, sorry for the update taking so long.
> > Cheers
> > PK
> > <mailto:Syncro_T3_Australia%40yahoogroups.com>, "peter_kolevas"
> > <peter.kolevas@> wrote:
> > > Update.
> > > Free play is minimal, fluid is good I tried topping it up to ensure
> > that the fluid made it into the clutch reservoir but no change. Both
> > master and slave appear to be good condition, no sign of fluid
> > leakage. Bled the system, no air only clean green fluid. The whole
> > system was changed at 400,000km now at 412000km. The ball that the
> > slave pushes on look in tack.
> > > After serval calls to some very helpful but too busy VW mechanics I
> > have managed to get into Jarrah's in taree. My conversations with him
> > indicte that he has done a lot of work on T3's with only one other
> > customer with a Syncro. He believes the issue is inside the clutch
> > housing.
> > > So thankfully we have RACQ Ultimate cover which will get us a hire
> > car to continue our journey whilst Jarrah does what he does.
> > > Thanks for everybody's help and input it has been really useful and
> > educational. I will keep you posted when I find out the actual cause
> > of the problem.
> > > Driving without a clutch is not ideal but it is possible as the last
> > 400km has proven
> > > Cheers
> > > Peter & Isabel
> > > "Broken down but not defeated"
> > <mailto:Syncro_T3_Australia%40yahoogroups.com>, Scott Daniel -
> > Turbovans <ScottDaniel@> wrote:
> > > > re
> > > > :I will attempt to locate the adjustment bolt at the peddle end."
> > > > extremely hard to do. One thing you never want to have to do is
> > adjust
> > > > the length of the clutch master cylidner push rod, as it's really a
> > > > major pain to do.
> > > > How much freeplay is there at the top of your clutch pedal travel.
> > > > it should be a very small distance...like 1/8th to 1/4th of an inch
> > > > ..that is pure mechanical slop , before the pedal and pushrod are
> > > > starting to push on the master piston.
> > > > On syncro's often, there is wear at the clevis and pin that connect
> > > > clutch pedal tomaster cylpushrod.
> > > > I have seen up to 2 1/2 inch pure freepay/slop on a syncro clutch
> > pedal
> > > > before -not good.
> > > > it's metal-to-metal at the clutch clevis pin , in the hole for it
> > in the
> > > > clutch pedal ..
> > > > at least spray up in there now and then with some spray lube to keep
> > > > that spot lubed some.
> > > > Youcan barely tell where it is, it's so well hidden.
> > > > on the times I have adujsuted the push rod ..
> > > > it goes like this ..
> > > > remove the two bolts that hold the master cylinder in place, and
> > push it
> > > > aside. Don't undo any lines on it.
> > > > Find a very deep15 mm socket ..like 5 inches deep..
> > > > usally those are stamped sheet metal , like out of a tool kit ..
> > > > use that to reach over the push rod to loosen the lock nut up in
> > there.
> > > > turn the threaded push rod to where you think it should be .
> > > > Assembly master cyl back on and test your freeplay ..
> > > > if it needs moreadjsuting, repeat.
> > > > it's the worst adjustment to do in the entire van.
> > > > Fortunately seldom needs to be done.
> > > > And sometimes a very worn clevis pin hole needs to be repaired, in
> > the
> > > > clutch pedal.
> > > > Syncro's Rock ..
> > > > scott
> > > > On 3/10/2013 12:06 AM, peter_kolevas wrote:
> > > > > Well it's a long,windy, hilly road to Port Macquarie from
> > Tamworth but
> > > > > we made it.
> > > > > We are sitting with a glass of wine reading the various messages
> > from
> > > > > you all.
> > > > > I will definitely bleed the system and see what comes out.
> > > > > I note that nobody thinks it could be the clutch itself!
> > > > > Which are the "really we'll run mechanical workshops" as I will
> > need
> > > > > to makes some calls in the morning and any recommendation will be
> > > > > better that a dart in the yellow pages.
> > > > > Cheers for all the advice it is very welcome and makes us feel less
> > > > > alone in this little challenge.
> > > > > Cheers
> > > > > Peter & Isabel
> > > > > 0448 690 696
> > > > > <mailto:Syncro_T3_Australia%40yahoogroups.com>, Hartmut Kiehn
> > > > > <hartis@> wrote:
> > > > > > Pretty obvious Peter that you don't have NRMA Premium Cover .
> > If you
> > > > > take it out today your wait
> > > > > > Is 2days before you can claim. They tow you anywhere, by tow I
> > mean
> > > > > all four wheels on deck of the truck . And you get a ride in the
> > cab,
> > > > > you never forget that special wedding anniversary ! You could
> > have it
> > > > > fixed here at Port have a hire car poss on NRMA . We are blessed
> > here
> > > > > with some really well run work shops. Ha.
> > > > > > Sent from my iPad
> > > > > > On 10/03/2013, at 1:40 PM, "Les Harris" <leslieharris@> wrote:
> > > > > > > Peter,
> > > > > > > Before you do anything else, make sure that the clutch cylinder
> > > > > reservoir is full of hydraulic oil. The first symptom of low oil
> > level
> > > > > is that, whilst the lever still moves, it is not moving far
> > enough to
> > > > > disengage the clutch plates. It lives under the instrument panel
> > hood.
> > > > > Spring the hood off and the reservoir is immediately obvious.
> > > > > > > Les
> > > > > > > From: mailto:Syncro_T3_Australia%40yahoogroups.com
> > > > > [mailto:mailto:Syncro_T3_Australia%40yahoogroups.com
> > > > > <mailto:Syncro_T3_Australia%40yahoogroups.com>] On Behalf Of
> > peter_kolevas
> > > > > > > Sent: 10 March 2013 13:23
> > > > > > > To: mailto:Syncro_T3_Australia%40yahoogroups.com
> > > > > > > Subject: [Syncro_T3_Australia] Clutch gone in Tamworth
> > > > > > > This is my 2nd day of a 2 week trip to celebrate our 25th
> > wedding
> > > > > anniversary but at the present I am sitting in a park with what
> > > > > appears to be a buggered clutch. I can see the lever at the gearbox
> > > > > moving when the clutch pedal is depressed.
> > > > > > > I can select gears with the engine off and start in first.
> > So I am
> > > > > contemplating driving back to the Gold Coast and having it
> > repaired at
> > > > > my mechanic or getting a recommendation from someone for place
> > that is
> > > > > a little closer.
> > > > > > > Do I recall mention of a good T3 mechanic in Kempsey?
> > > > > > > Any suggestions welcome
> > > > > > > Cheers
> > > > > > > Peter
