I started to lose brake/clutch fluid a couple of week ago, looked under the Syncro and saw that the slave cylinder was leaking. Got a replacement from Justkampers $46.40 (branded JP Group- Clutex, distributed by Denmark * Germany), scheduled in 2 hours to replace and lined up my son to help bleed.
Tried a suggestion from AA Transaxle of taking off the clutch lever and removing the bracket and slave as one unit - no go, lever well and truly rusted on shaft.
Take off bracket and slave, discover the rod I had welded on the rear nut of the slave had rusted off - replace with rivet nut ( new tool I bought recently )
Find there is not enough clearance for rear attaching bolt to go down into slave cylinder hole so grind off bottom of bleeder boss. Bolt in cylinder and bracket.
Go to attach fluid line banjo bolt, drop one of the copper washers, spend fruitless 20 mins looking for it, race off to friendly mechanic, find him closed, go to Bunnings and get fibre washer and drill to fit.
All together now, start to bleed with son's help, but find nothing comes out of bleeder hole, just oozes out of base of bleeder!! Pull out bleeder and find it has no passage through to base!!
Replace it with bleeder from old unit, get more brake fluid, find son has shot off in disgust.
Getting dark now, wife comes home, politely asks her help to bleed, but am refused with her reminding me of other last minute repair jobs that went wrong.
All fixed and bled next morning - 5 hours in total - think I had better check on master cylinder, yes it has a slight ooze coming out of the boot!!! check on Justkampers $165.00!! check on eBay, SMF Autoparts has a Meyle shipped to Aust for $43.63 so I order one and write a critical review on the Justkampers website.
Ah the joys of owning a Syncro!!
