On 24 February 2012 11:41, Bill <marg_bill@westnet.com.au> wrote:
Has anyone ordered a complete set of coolant hoses from VAN CAFE. At $us375.00 (250) it seems like a reasonable solution to out of stock situation in Aust. Provided postage is not over the top. Bill
Philippe Tyack
Mobile:+61450059162
On 24 February 2012 12:00, Bill <marg_bill@westnet.com.au> wrote:
Philippe. Thanks. That postage seems ok. A new set of hoses should help a lot with reliability issues in 20+ year old vans. I suspect few of our 2.1 engines just wear out but get cooked with cooling failure. Bill
Philippe Tyack
Mobile:+61450059162
A lot of people have made that mistake and it is hard to go back.
The aftermarket small hose that you buy by the metre is actually fuel hose. The correct water hose 443 121 107A is available for $35 from VW dealers for 5 metres.
Bill,
I got a set of hoses from Van Café and the service re delivery was excellent. There are one or two hoses that they do not include, one is a heater hose that runs under the van from one side to the other at the engine end. This can be replaced with some heater hose and Unicoils to allow the hose to bend.
Re the comment regarding the 20 year old hoses most of the ones taken off my T3 where still in good condition. The local RAC told me that 10 to 12 years is about the maximum life that you can expect so this proves that VW do use good gear!
I also purchased a new radiator and stainless steel junction tree from these guys.
Dave WA
> Phil. Noted. This kit is sold as a combination of Genuine
> vw,aftermarket, and silicon hoses that van cafe have had manufactured.
> The hoses that have failed on my van 251 121 103, 251 121 072a, and 251
> 121 102. They all come off the H PIPE COOLANT JUNCTION. They are no
> longer available in australia, as is the junction. So may as well get
> the full set. Bill
look at the inside of hoses sometimes..
often the outside will look fine, but the inside surface will show signs of deterioration.
of course...any hose that feels mushy and soft if 'really getting there.'
The ones that run the hottest go first.
That one going off the front of the right cylinder head ....S shaped and about 6 inches long ..
I've seen a few of those blow.
in general, I find many of the original VW T3 hoses to be just excellent and very, very long lasting .
I gather you guys run in very hot temps a lot, and may have more stress going on than T3 vans in other places in the world.
'Water Wetter' ..
btw.........that stuff works. ( or similar products by other companies ) .. Read what it says on the side of the bottle , very useful and interesting. Pure water With water Wetter added removes heat the best, according to what it says on the bottle. Racing cars generally run pure water I read.
I use Water Wetter for sure where really high temps and heat loads are a concern.
( of course ..failure of the ends of the main plastic cooling pipes ....that occurs. I have seen some fine vans in the boneyard ...just due to that failure. )
Stay cool !
www.turbovans.com
On 2/23/2012 8:34 PM, plander@optusnet.com.au wrote:Be careful of replacing perfectly good genuine VW parts with new aftermarket. You could be making it more unreliable. You need to take a commonsense approach. If the original looks brand new, keep it. If it looks like it has been sitting on the floor of the ocean for years, replace it.
The hose however looks like a hard to get one:
http://www.van-cafe.com/home/van/page_474_1141/h20-pump-pipe-to-thermostat-housing-hose.html
Are any local vendors likely to have this? Don't want to be off the road too long
Also, is there any way to get an early warning of an issue? If this happened on a long trip, could have lost a lot of coolant without realising.
I'm also thinking a complete kit could be a good idea, has anyone used this kit, or are there better places to get them?
http://www.van-cafe.com/home/van/page_194_1141/syncro-coolant-hose-kit-1986-1991.html
http://www.thesamba.com/vw/forum/archive/index.php/o-t--t-513918--.html
Its scary just how many parts are in the cooling system!
Just get a hose the right diameter with a bend in it from a store like Repco or Supercheap and cut it to length.
cheers
Doone Wyborn
On Oct 12, 2014 11:24 PM, "cathrich1@yahoo.com.au [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:My bus decided to impersonate a steam train today. Fearing the worst of course, check it over and was one of the hoses on the thermostat. I was lucky as it was only a tiny hole and must have happened just before we stopped, so I managed to patch it and get home fine, hardly lost any coolant.
Richard,
If you look in the Files section of the Syncro_T3_Australia website, you will find a very comprehensive document authored by Ken. It is a compilation of coolant hoses for the MV engine, giving original numbers and alternative sources of supply.
Re coolant loss:
The temperature instruments normally fitted to motor vehicles are grossly inadequate when it comes to catastrophic coolant loss. You can lose the entire contents of the cooling system before the average temp gauge responds, by which time it is far too late.
The only device which tells you before you have lost the lot is based on the presence of / absence of coolant.
They usually consist of two probes close together in the coolant, through which a current passes. So long as they are surrounded by liquid, the current flows between the probes. The moment the liquid drops below the level of the probes, the current stops flowing and a loud alarm is triggered on the dash – usually a shrieking piezo!!
It follows that, the higher up in the coolant system the probes are mounted, the more warning you get. (It is on the ignition circuit and runs only when the ignition is on.)
This is an absolutely positive warning system; coolant present = OK, coolant absent = loud alarm. This gives you time to get off the road and shut off the engine.
I find that Davies Craig released a warning kit last year and I will try to get full details –
Davies Craig make very good quality gear and I would expect this to be no different. (We used a lot of DC gear in our test gear at General Motors.)
[mailto:Syncro_T3_Australia@yahoogroups.com]
Sent: 13 October 2014 00:24
Coolant hoses
coolant.
On the kit, this doubles up with the factory one in the header tank, I'm just not sure how quick you notice loss of coolant from the header tank?
Thanks also for the tip on finding a suitable hose, will have a look tomorrow at repco.
Date: Sun, 12 Oct 2014 06:49:23 -0700
Subject: [Syncro_T3_Australia] Re: Coolant hoses
Thanks for the detailed reply Ken, I will certainly be adding the complete kit to the ever growing wish list for the Bus.
I have looked at the SS pipes front to back, certainly interesting you decided to keep the originals. Not that I know, but I would have thought any original ones out there would have a finite life left in them. Not sure if there would be any potential issues going to stainless.
I understand you comment on the clips, unfortunately my bus has a number of hose clips already there, so am at the moment forced to re-use them.
For the moment I have found a suitable candidate locally, Repco luckily let me into there wearhouse, they had a rack probably 4m x 2m of various hoses I sorted through.
Now comes the fun of actually replacing and bleeding the system, not a task I'm looking forward to!!
Thanks again every one for your help and assistance.
Thanks again everyone for your help. I have put the complete hose kit on the wish list for now. With the use of the handy document in the files section, the local Repco let me loose in the store room, got a crummydore hose (gates brand) that I cut the right size piece out of and fitted to the bus, was straight forward and didn't loose much coolant. Bleed the system and was back on the road quickly!
I read up both the files here and the Bentley for the bleeding procedure, it seemed straight forward enough. Why do so many people seem to get it wrong? What are the common mistakes people make?
Out of interest, when the hose first leaked, I taped up the hose and surprisingly it seemed water tight for the trip home (~10km). I also bought a silicon repair "supatape". Not sure how good it is, but seems like cheap insurance and usable on coolant, oil, fuel etc
http://www.abseals.com.au/wp-content/uploads/2014/02/Flyer-SupaTape-Ver120229.pdf
Hi to all the experts out there. Gearbox is out for a refurb by Ron in Kempsey. It was looking great until we checked the pinion shaft. Not good news. Couple of small areas where the case hardening is starting to go. Ron is sourcing a new one. I have the house mortgage papers out!!!! And will put in a new friction plate at the same time. Everywhere I look only sells the full kit. Does anyone have any idea where I might source a friction plate locally. Tried Tooleys, Just Kampers, Stokers so far. Not even GoWesty have just the plate.
Peter from Port Mac.
Peter,
Try John Goodison at Volks Home in Thomastown , Victoria . John is probably the most reliable source of good quality parts. He is very fussy about quality and simply refuses to stock anything that he is not happy with or unsure of.
He is VW from way back and has exceptionally good knowledge of VW parts and sourcing. (He is also the technical officer for the VW Club of Victoria , an invaluable asset to the club.)
Sent: 18 November 2014 12:45
To:
Clutch Friction Plate
