It will only get worse. At minimum you need heads off, new gaskets and head surface clean up. If you have lots of kms up you will be smart to do more than that.--- On Sun, 10/4/11, richardnicholls74 <richardnicholls74@yahoo.com.au> wrote: |
Done it recently, ended up doing a complete top end overhaul.
One way or the other, the job has to be done as you say it will get worse and more expensive... cheerio Hart
Date: Sun, 10 Apr 2011 02:18:22 -0700
Subject: Re: [Syncro_T3_Australia] Coolant leakage from head gasket.
Could not agree more Hart. The subject is so big I have left out a thousand topics, like adding more ponies...--- On Sun, 10/4/11, Hartmut Kiehn <hartis@live.com.au> wrote: |
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290307584828&ssPageName=STRK:MEWAX:IT
Sam
> --- On Sun, 10/4/11, Hartmut Kiehn <hartis@...> wrote:
> From: Hartmut Kiehn <hartis@...>
> Subject: RE: [Syncro_T3_Australia] Coolant leakage from head gasket.
> To: "Hartmut Kiehn" <syncro_t3_australia@yahoogroups.com>
> Received: Sunday, 10 April, 2011, 7:35 PM
> Â
> Greg, just heads off ???? But how ? Heads normally stick to the barrels like being welded on with Ken's JB Weld. And once you disturb the bottom seals you are in the thick of it....
> Â
> From: gregespo73@...
> Â
> --- On Sun, 10/4/11, richardnicholls74 <richardnicholls74@...> wrote:
> From: richardnicholls74 <richardnicholls74@...>
> Subject: [Syncro_T3_Australia] Coolant leakage from head gasket.
> Received: Sunday, 10 April, 2011, 6:43 PM
> Â
> Just discovered minor coolant leak between head and block, location on the head side of seal!!very minor should i take action or give it some time and see if it develops i suspect it has been like it for some time?
Date: Mon, 11 Apr 2011 14:06:55 +0000
Subject: [Syncro_T3_Australia] Re: Coolant leakage from head gasket.
Sam
> Â
> Â
> Â
> Â
| Ken, some mechanics are very shy about using such products! I would even hesitate to use it as a "get home method". Re the Subaru conditioner (a holts product), the difference between your leaking t3 pump and a new Subaru with a design fault in the head gaskets is vast. Your pump would have had a failed bearing or seal or both. No amount of goo would have PERMANENTLY fixed it. The right way to look after mechanical things is when you notice a fault you fix it properly, that way when you are at the base of big red and you gun the engine you don't get a sea of coolant pouring out and five guys in landcruisers laughing at you. Those Subaru's needed redesigned parts fitted to properly fix their head gasket leaks which tells you, yes, it was a way of weaselling out of spending some of there goodwill budget. Greg E --- On Tue, 12/4/11, Ken Garratt <unclekenz@hotmail.com> wrote:
Date: Mon, 11 Apr 2011 14:12:49 -0700
Subject: RE: [Syncro_T3_Australia] Re: Coolant leakage from head gasket.
----- Original Message -----From: Ken GarrattSent: Monday, April 11, 2011 3:21 PMSubject: RE: [Syncro_T3_Australia] Re: Coolant leakage from head gasket.Greg,
Actually, I know what you mean but fitting a new water pump isn't necessarily a permanent fix either, just delays the inevitable next failure.Any 20yo vehicle getting as far as then taking on big red would most likely have been virtually gutted of mechanical parts and rebuilt beforehand. In recent times, I've only heard of Yurik tackling and winning over big red.When it comes to dodgy head gaskets, there seems to have been around for a long time a school of thought that the WBX2.1 motor is well qualified. I have no opinion either way.You can sleep easier knowing I'll not be sullying my syncro by fitting a Subaru motor ... with or without dodgy head gaskets.Cheers and thanks for your response.KenTo: Syncro_T3_Australia@yahoogroups.com
Received: Tuesday, 12 April, 2011, 12:50 AM
Sam,
I tend to think mechanics aren't too shy about using this type of product, depending upon individual vehicle repair circumstances, keeping costs down or selling the vehicle soon.I remember my sons Mazda once had a minor head gasket leak and my mechanic advised me to use a Nulon product which I did and it fixed it no problem. Never had a problem since.On the other side of the coin, some say use of such products may contribute to clogging up radiator cores. I suppose ... ask a radiator repairman.Interesting it specifically mentions fixing leaking water pump shaft seals which is exactly the problem I had recently and went through the exercise of replacing the pump ... maybe it was worth considering this as an alternative .... don't know for sure, I guess one would have to take a punt and try it ... caveat emptor eh.Would Subaru sully its reputation by selling a crap product? Probably not.Sorry Sam, probably not much help.Cheers.ken
On the topic of seeping coolant, does any one have comment on the utility of the stop leak products such as this one here:
Sam
> Â
> Â
> Â
> Â
----- Original Message -----From: Scott Daniel - TurbovansSent: Tuesday, April 12, 2011 9:42 AMSubject: Re: [Syncro_T3_Australia] Re: Coolant leakage from head gasket.
hi all,reWhen it comes to dodgy head gaskets, there seems to have been around for a long time a school of thought that the WBX2.1 motor is well qualified. I have no opinion either way."I sure have an opinion !it's a totally dumb design.it's amazing they last as well as they do.it's 'dumb' because ..look at what every other manufacture does ..combustion sealing and coolant sealing take place on one plane..like any conventional cylinder head and gasket.on the waterboxer ..the two sealings are done separately ..becuase it is an adapted air-cooled design.the head still sits on top of the barrle with metal sealing rings ..just like in an old VW Bug ..the head reaches down around the barrel about 10mm to help keep things in place..all fine and dandy.then ....VW just extended the air-cooled design block up so there are water jackets..and that sealing ..the outer rubber water-retention gasket is on a different plane than the combustion sealing is ..so they can't just use a good old fasioned flat headgasket.and ...this is the real joke part ..how well the outer rubber water gasket is compressed to seal ..is determined by how far down over the barrels the heads fit ..I have seen many that squease the outer rubber gasket too much and it gets pinched and split ..then it leaks in a few years..or the opposite .......that qasket isn't squesed enough ..and it seeps after a few years. ..though that is rather rare.and I have seen a brand new AMC head fit so that it's tilted sitting on the barrlss ..so the outer rubber gasket is pinched on one end and not compressed enogh on the other.'usually' the outer water gasket gap is about right .It's smart to install the bare head ( with metal rings on top of the barrels ) and measure that gap ..when I first discovered this problem in the 90's ..in my research and talking to everyone about why gaskets on a new head only lasted about a year ..finally ..a VW dealer tech told me ...you install the bare head, meausre that gap .and it it's too small ( or too big ) try another head !!!at which I really threw up my hands and knew it wasn't my workmanship that was any cause ..since the notion 'standardized' car parts dates from the late teens in the US I believe. Prior to that each car was indiviudallty fitted, piece to piece.It was a big deal when they drove 3 Buicks I think..to a New York Expo kind of event..tore them all apart, mixed up all the parts ..and put them back together and they all ran and worked..so ...the idea that one head might fit right and another not ..is just a pure joke.In practice though ..we manage to live with them and they work well enough ..usually.I see lot of corrosion on T3 vans here in the Western US ..and this is a nice environment too ..but corrosion happens ..especially inside the engine in the coolant.You can't change coolant too often on a waterboxer engien that is 20 years old.so when I hear....'my heads have been on 240,000 miles with no problems ' ..I get very nervous.About the very worst corrosion related thing you want to be aware of, and not have..is the cylinder head studs breaking off down in the block.Rare .but it happens..and it very serious to correct or deal with.the way the nuts feel unscewing them is just nervous feeling ..before they start to unscrew, the stud under it twists quite a bit ...then finally the nuts breaks loose and unscrews , usually.if the nut is corroded..or worse..the stud is weakened down in the case due to corrosion you can be in big trouble.so ....delaying addressing it, if there is corrosion at all.........can only allow it to get worse.If it's a 'keeper' van ..deal with it now, or at a convenient time soon, rather than put it off for a long time.as for the barrels getting stuck in the heads ..that does happen sometimes...corrosion is a factor.There are bumps on the outside of the barrels placed there specifically for prying them out of the heads with a bar ...that works nicely. Usually is not a problem there.( I did have one set of Brazilina 1.9 pistons and barrels where the barrels fit much, much too tightly into the cylinders ..had to hone those to fit right .....hand lap them in ...hopefully your barrels will separate from the cylinders nicely ..the usualy do. )there can be pretty bad pitting at the rubber gasket surface on the head ( oh ..only saw this once..but I recently say a waterboxer head removed and there was a chunk of the engine case missing from corrosion ! ..it was either JB weld there and hope..or another engine. ..usally just the heads are pitted or corrodded. )if they are ..just resurfacing the bottom of the head like a normal head..it not really a viable repair.the 'step distance' between where the metal rings sit in the combustion chambers and the flat bottom of the head has to be about right ..since that distance determines how well or not well the outer rubber gasket is compressed.'normal machine' shops can not address that so easily ..since their reference point for surfacing the bottom of a head is the top of it ..the valve cover surface........which is not what that distance is referenced from ..it's referenced from the combustion chambers ..where the metal rings fit.anway ..the sooner a leaky head gakset is dealt with ..generally ..the better.and I also have a valve job done too.it's common on the 2.1 for the exhaust valves to be leaking a little.scottOregon, USA----- Original Message -----From: Ken GarrattSent: Monday, April 11, 2011 3:21 PMSubject: RE: [Syncro_T3_Australia] Re: Coolant leakage from head gasket.Greg,
Sam,
Sam
> Â
> Â
> Â
> Â
Date: Mon, 11 Apr 2011 16:42:37 -0700
----- Original Message -----From: Ken GarrattSent: Monday, April 11, 2011 3:21 PMSubject: RE: [Syncro_T3_Australia] Re: Coolant leakage from head gasket.Greg,Actually, I know what you mean but fitting a new water pump isn't necessarily a permanent fix either, just delays the inevitable next failure.Any 20yo vehicle getting as far as then taking on big red would most likely have been virtually gutted of mechanical parts and rebuilt beforehand. In recent times, I've only heard of Yurik tackling and winning over big red.When it comes to dodgy head gaskets, there seems to have been around for a long time a school of thought that the WBX2.1 motor is well qualified. I have no opinion either way.You can sleep easier knowing I'll not be sullying my syncro by fitting a Subaru motor ... with or without dodgy head gaskets.Cheers and thanks for your response.KenTo: Syncro_T3_Australia@yahoogroups.com
Sam,
Sam
> Â
> Â
> Â
> Â
I think that a lot of Aussies are putting tap water in with the coolant.
> Scott,If you're trying to frighten us, you've succeeded! ... hahaIts not
> an easy decision to make, having the engine pulled and inspected by
> "experts" and probably overhauled while its out, purely on the basis
> that one should check the head studs.I concede, it's an issue I lose
> sleep on every other night. Unfortunately I'm well versed in
> procrastination. Does crossing ones fingers help?Cheers.Ken
> From: ScottDaniel@turbovans.com
> hi all,
> re
> a
> have no
> in
> place..
> all fine and dandy.
> water
> jackets..
> and that sealing ..
> gasket
> the heads
> fit ..
> gets
> barrlss ..
> enogh
> on the other.
> only
> finally ..
> that
> was any cause ..
> piece to piece.
> pure joke.
> years
> old.
> I get very nervous.
> and
> not have..
> ...then
> be
> in big trouble.
> for
> a long time.
> for
> is
> barrels
> right
> usualy
> do. )
> oh ..
> there
> JB weld
> there and hope..
> if they are ..
> that
> compressed.
> ..the valve
> cover surface..
> referenced
> anway ..
> scott
> www.turbovans.com
> Oregon, USA
> From:
> Garratt
> To: Syncro _T3_Australia
> forum
> PM
> Greg,
> failure.
> beforehand.
> big
> red.
> for
> qualified. I
> a
> From:
> gregespo73@yahoo.com
> Subject: RE:
> gasket.
> method". Re the
> your
> gaskets
> both. No
> look
> properly,
> engine you
> you,
> goodwill
> budget. Greg E
> From:
> Subject: RE:
> To:
> Sam,
> of
> circumstances,
> my
> fixed it
> may
> radiator
> repairman.
> went
> worth
> guess
> Probably not.
> ken
> From:
> me@samarnold.org
> Subject:
> gasket.
> products
> Name=STRK:MEWAX:IT
> Sam
> > Could not
> agree more Hart.�� The subject is so big I have left out a
> > --- On
> > Subject: RE:
> > To:
> welded on
> are in
> the thick of it....
> > Done it recently,�� ended up doing a
> expensive...�� �� cheerio�� �� Hart
> > From:
> gregespo73@...
> gasket.
> lots of
> > --- On
> > Received:
> take
> it has
> > Cheers.
One of the principal roles of the coolant is to prevent the studs from corroding through.
I have seen MV engines run on tap water in which ALL of the studs have corroded down to next to nothing. For the sake of saving a few dollars on the correct coolant, the cost is many thousands of dollars!!
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of plander@optusnet.com.au
Sent: 12 April 2011 11:28
Subject: Re: RE: [Syncro_T3_Australia] Re: Coolant leakage from head gasket.
The head stud problem appears to be more common in Australia than anywhere else.
> corroding through.
> on
> gasket.
> anywhere
> else.
> About the very worst corrosion related thing you want to be aware of,Very, very common in Australia.
Putting it the other way round - what kilometers could we expect from a properly serviced WBX engine run on the correct coolant which has been regularly changed.(And only used by a little old man to go to church via Cape York Peninsular)
My camper has just clocked over the 200,000K and has never run better -am I living in a fool's paradise or should I be very very scared?
washington for the last 40 years or so in all kinds of cars.
Never a problem from doing that.
I also add water soluble machinist's cutting oil..
just a half cup or so ..as a w. pump lubricant and rust inhibitor.
works really well.
Sent: Monday, April 11, 2011 6:27 PM
> else.
>> hi all,
>> re
>> a
>> have no
>> in
>> place..
>> all fine and dandy.
>> water
>> jackets..
>> and that sealing ..
>> gasket
>> the heads
>> fit ..
>> gets
>> the
>> barrlss ..
>> enogh
>> on the other.
>> only
>> finally ..
>> that
>> was any cause ..
>> piece to piece.
>> pure joke.
>> years
>> old.
>> I get very nervous.
>> and
>> not have..
>> ...then
>> be
>> in big trouble.
>> for
>> a long time.
>> for
>> is
>> barrels
>> right
>> usualy
>> do. )
>> oh ..
>> there
>> JB weld
>> there and hope..
>> if they are ..
>> that
>> compressed.
>> ..the valve
>> cover surface..
>> referenced
>> anway ..
>> scott
>> www.turbovans.com
>> Oregon, USA
>> From:
>> Ken
>> Garratt
>> forum
>> PM
>> Greg,
>> failure.
>> beforehand.
>> big
>> red.
>> for
>> qualified. I
>> a
>> Ken
>> From:
>> Subject: RE:
>> gasket.
>> method". Re the
>> your
>> gaskets
>> both. No
>> look
>> properly,
>> engine you
>> you,
>> goodwill
>> budget. Greg E
>> From:
>> Subject: RE:
>> To:
>> Sam,
>> of
>> circumstances,
>> my
>> fixed it
>> may
>> radiator
>> repairman.
>> went
>> worth
>> guess
>> Probably not.
>> Cheers.
>> ken
>> From:
>> me@samarnold.org
>> Subject:
>> gasket.
>> products
>> Name=STRK:MEWAX:IT
>> Sam
>> > Could not
>> > --- On
>> > Subject: RE:
>> > To:
>> Â
>> welded on
>> are in
>> the thick of it....
>> Â
>> > From:
>> gregespo73@...
>> gasket.
>> > Â
>> lots of
>> > --- On
>> > Received:
>> > Â
>> take
>> it has
>> > Cheers.
----- Original Message -----From: plander@optusnet.com.auSent: Monday, April 11, 2011 6:41 PMSubject: Re: Re: [Syncro_T3_Australia] Re: Coolant leakage from head gasket.
----- Original Message -----From: Ken GarrattSent: Monday, April 11, 2011 6:10 PMSubject: RE: [Syncro_T3_Australia] Re: Coolant leakage from head gasket.Scott,
If you're trying to frighten us, you've succeeded! ... hahaIts not an easy decision to make, having the engine pulled and inspected by "experts" and probably overhauled while its out, purely on the basis that one should check the head studs.I concede, it's an issue I lose sleep on every other night. Unfortunately I'm well versed in procrastination. Does crossing ones fingers help?Cheers.Ken
Sam,
Sam
> Â
> Â
> Â
> Â
And make sure the earth lead to the motor is clean and connected.
And keep your fingers crossed :)
> corroding through.
> plander@...
> else.
