Hi all, just a quick reminder to check your CV joint bolts.
I have started to hear a faint clicking in the rear on the Syncro in left hand turns. Checked everything over this afternoon, engine & GB mounts, axle nut, bearings etc, all looked fine. When I checked the CV joint bolts, even though all were tight, about 1/2 were not at full torque.
I replaced all the bolts last year when the GB was out, torqued them up, and re-checked after a couple of hundred km, so was surprised they were not all at full torque.
Probably something worth checking form time to time. I have checked the bolts since I have had it occasionally, have not seem them loose torque like this before.
Unfortunately for me, looks like the left outer CV is getting worn, I could just feel a little play in there that was not noticeable the last time I checked.
