Cylinder heads
Hi Scott
I got one from aircooled.net with lifters. Price seemed OK
On Tue, Jul 3, 2018 at 11:02 AM, Paul Dumais paul.d.dumais@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Thanks Scott
Greg do you know where I can get my hands on a new cam. My only option so far is VW Heritage in the U.K. $385 aud. it's a bit of a wait.
On Mon, 2 Jul 2018 at 11:53 am, gregespo73@yahoo.com [Syncro_T3_Australia] <Syncro_T3_Australia@ yahoogroups.com> wrote:
Reground cams and second hand cams are a waist of time and money. Greg
Sent from Greg's iPhone
On 2 Jul 2018, at 11:31 am, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@ yahoogroups.com> wrote:
Unfortunately Paul - the rest of that engine has been promised to Nils on here - which he requested from Phil prior to the engine being removed.
Maybe contact Nils - he may have a spare lying around?
On 2/07/2018 10:57 AM, Paul Dumais paul.d.dumais@gmail.com [Syncro_T3_Australia] wrote:
Hi Skot.
I'm seeking a good camshaft. Can you see if that engine being disassembled has a one available please.
I rebuilt my engine with all new parts a couple of years ago. I had the cam reground by Waggots in Alstonville. I used new Febi lifters.
The engine starting getting hot on occasions running warmer the. Usual and I decided to pull the heads. I found that my lifters from the rear cylinder are badly worn as is the cam.
Now I find out from Janian at Stokers that he has found reground cams and febi lifters are not compatible.
On Sun, 1 Jul 2018 at 10:11 pm, Hartmut Kiehn hartis@live.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@ yahoogroups.com> wrote:
Looks like a special Syncro. Bullbar could be a Trakka. You will regret having parted with it once it's gone...
Sent from my Samsung Mobile on the Telstra Mobile Network
From: "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@ yahoogroups.com>
Date: 1/7/18 6:40 pm (GMT+10:00)
Subject: Re: [Syncro_T3_Australia] Re: Cylinder heads [4 Attachments]
Hi Mark,
The heads that were on the motor we pulled today weren't the best - they needed some new valve springs due to rust and were full of creamy gunk due to a broken head stud.
See photo.
However, Graham from the syncro club rang and said he had a set of AMC heads in great condition.
One head has a tiny crack between valves but the other is perfect and both have no corrosion just some gasket debris.
Graham said he will part with them for $200.00. plus shipping cost.
He also has his beloved syncro with fully rebuilt engine tentatively for sale for $24k.
A couple of photos attached.
For contact with Graham - try 0412 432 151.
On 27/06/2018 3:47 PM, Mark Fisher mark@spe.com.au [Syncro_T3_Australia] wrote:
Scott. My number 0427127128
On Wed, Jun 27, 2018 at 3:41 PM, Mark Fisher <mark@swiftperformance.com> wrote:
Yes please!!
On Wed, Jun 27, 2018 at 3:16 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@ yahoogroups.com> wrote:
I know someone who is pulling a 2.1 engine from a reco motor due to it having massively leaking head gaskets but almost zero kms on it since the rebuild and new AMC heads.
He has promised the block to someone already but he may have the heads available.
I will ask him this weekend.
On 27/06/2018 1:30 PM, mark@spe.com.au [Syncro_T3_Australia] wrote:
Hi John,
I am in a similar situation where I have a running motor, but I'd like to keep it a spare.
I'm looking at about $1500 for a pair of new heads. Re-birthing an old set might cost circa $550-$600 so its a tough call. I was hoping some had a pair sitting on a shelf that were rebuildable.
May be I use mine? Not sure waht to do.
Of course throwing buckets of cash always seems to fix a $inkro
Head Office
Ph: +61 7 3879 3005
US Office
Nortbrook IL, 60062
USA
Office: +1 224 501 9001
Head Office
Ph: +61 7 3879 3005
US Office
Nortbrook IL, 60062
USA
Paul Dumais
Aerospace Engineer
Paul Dumais
Aerospace Engineer
Head Office
Unit 2, 1472 Boundary Road Wacol, Qld, 4300 Australia
Ph: +61 7 3879 3005
US Office
3388a Commercial Ave
Nortbrook IL, 60062
USA
There you are Paul.
Give them a try.
When our Aussie Peso was good I would usually get a good deal from Van Cafe for new parts however, they only do reground cams:
http://www.vancafe.com/025109019X_p/025109019x.htm
On 3/07/2018 11:09 AM, Mark Fisher mark@spe.com.au [Syncro_T3_Australia] wrote:
Hi Scott
Thanks Scott
On 2/07/2018 10:57 AM, Paul Dumais paul.d..dumais@gmail.com [Syncro_T3_Australia] wrote:
Hi Skot.
Hi Mark,
See photo.
Yes please!!
Hi John,
Head Office
Ph: +61 7 3879 3005
US Office
Nortbrook IL, 60062
USA
Head Office
Ph: +61 7 3879 3005
US Office
Nortbrook IL, 60062
USA
(Message over 64 KB, truncated)
Use a type one cam and cog. They are available everywhere. You need to match the grind to the engine. Re stroke, bore, static compression ratio, porting, valves e.t.c.
Eagle cams
Cb performance
Vanistan (also has type 5 adapter so you can use old cam gear)
Greg
On 3 Jul 2018, at 11:02 am, Paul Dumais paul.d.dumais@gmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Thanks Scott
On Mon, 2 Jul 2018 at 11:53 am, gregespo73@yahoo.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
On 2 Jul 2018, at 11:31 am, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Skot.
On Sun, 1 Jul 2018 at 10:11 pm, Hartmut Kiehn hartis@live.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Mark,
See photo.
Yes please!!
On Wed, Jun 27, 2018 at 3:16 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi John,
Head Office
Ph: +61 7 3879 3005
US Office
Nortbrook IL, 60062
USA
Head Office
Ph: +61 7 3879 3005
US Office
Nortbrook IL, 60062
USA
Paul Dumais
Aerospace Engineer
Paul Dumais
Aerospace Engineer
I dont need the camshaft. if it is good, you are welcome to it
On Mon, 2 Jul 2018 at 11:31 AM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]
Hi Skot.
Hi Mark,
See photo.
Yes please!!
Hi John,
Head Office
Ph: +61 7 3879 3005
US Office
Nortbrook IL, 60062
USA
Head Office
Ph: +61 7 3879 3005
US Office
Nortbrook IL, 60062
USA
Paul Dumais
Aerospace Engineer
