Hi guys,
I’m building up a DJ motor. Need a couple of used heads in rebuildable condition.
Anyone??
Hi guys,
Anyone??
Hi John,
I am in a similar situation where I have a running motor, but I'd like to keep it a spare.
I'm looking at about $1500 for a pair of new heads. Re-birthing an old set might cost circa $550-$600 so its a tough call. I was hoping some had a pair sitting on a shelf that were rebuildable.May be I use mine? Not sure waht to do.Of course throwing buckets of cash always seems to fix a $inkro
CheersMark
On Wed, Jun 27, 2018 at 3:16 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:I know someone who is pulling a 2.1 engine from a reco motor due to it having massively leaking head gaskets but almost zero kms on it since the rebuild and new AMC heads.
He has promised the block to someone already but he may have the heads available.
I will ask him this weekend.
On 27/06/2018 1:30 PM, mark@spe.com.au [Syncro_T3_Australia] wrote:
Hi John,
CheersMark
Best regards, Scott Pitcher SPB Consulting--Head OfficeUnit 2, 1472 Boundary Road Wacol, Qld, 4300 AustraliaPh: +61 7 3879 3005US Office3388a Commercial AveNortbrook IL, 60062USAOffice: +1 224 501 9001
On Wed, Jun 27, 2018 at 3:41 PM, Mark Fisher <mark@swiftperformance.com> wrote:Yes please!!--On Wed, Jun 27, 2018 at 3:16 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@ yahoogroups.com> wrote:I know someone who is pulling a 2.1 engine from a reco motor due to it having massively leaking head gaskets but almost zero kms on it since the rebuild and new AMC heads.
Hi John,
CheersMark
Best regards, Scott Pitcher SPB ConsultingHead OfficeUnit 2, 1472 Boundary Road Wacol, Qld, 4300 AustraliaPh: +61 7 3879 3005US Office3388a Commercial AveNortbrook IL, 60062USAOffice: +1 224 501 9001--Head OfficeUnit 2, 1472 Boundary Road Wacol, Qld, 4300 AustraliaPh: +61 7 3879 3005US Office3388a Commercial AveNortbrook IL, 60062USAOffice: +1 224 501 9001
So if it's a reco motor with new heads, what went wrong? Scary to think some one spent a lot of $$ on a motor to have it fail. Is it poor workmanship, or poor components?
What do you consider the "head gaskets", is that the water jacket seal, or the barrels into the heads?
Hi John,
I am in a similar situation where I have a running motor, but I'd like to keep it a spare.I'm looking at about $1500 for a pair of new heads. Re-birthing an old set might cost circa $550-$600 so its a tough call. I was hoping some had a pair sitting on a shelf that were rebuildable.May be I use mine? Not sure waht to do.Of course throwing buckets of cash always seems to fix a $inkroCheersMark--
On 27/06/2018 1:30 PM, mark@... [Syncro_T3_Australia] wrote:
Hi John,
CheersMark
I am very keen if he wants to sell them.
My number is in an earlier mail.CheersMark
On Thu, Jun 28, 2018 at 8:19 PM, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Mark,
You are top of the list if I can convince him to sell.
On 27/06/2018 3:47 PM, Mark Fisher mark@spe.com.au [Syncro_T3_Australia] wrote:
Scott. My number 0427127128
Yes please!!--
Hi John,
CheersMark
On Sun, 1 Jul 2018 at 6:41 pm, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Hi Mark,
The heads that were on the motor we pulled today weren't the best - they needed some new valve springs due to rust and were full of creamy gunk due to a broken head stud.
See photo.
However, Graham from the syncro club rang and said he had a set of AMC heads in great condition.
One head has a tiny crack between valves but the other is perfect and both have no corrosion just some gasket debris.
Graham said he will part with them for $200.00. plus shipping cost.
He also has his beloved syncro with fully rebuilt engine tentatively for sale for $24k.
A couple of photos attached.
For contact with Graham - try 0412 432 151.
Yes please!!--
Hi John,
CheersMark
Are the parts be you pulled not recoverable.. Sounds like a poor engine rebuild, broken valve springs and head studs?
Can you put me in touch with Graham?--
Hi Mark,
See photo.
Yes please!!--
On 27/06/2018 1:30 PM, mark@spe.com..au [Syncro_T3_Australia] wrote:
Hi John,
CheersMark
Hi Mark,
See photo.
Yes please!!--
Hi John,
CheersMark
On Sun, 1 Jul 2018 at 10:11 pm, Hartmut Kiehn hartis@live.com.au [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Looks like a special Syncro. Bullbar could be a Trakka. You will regret having parted with it once it's gone...😪
Sent from my Samsung Mobile on the Telstra Mobile Network
-------- Original message --------From: "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>Date: 1/7/18 6:40 pm (GMT+10:00)Subject: Re: [Syncro_T3_Australia] Re: Cylinder heads [4 Attachments]
Hi Mark,
See photo.
Yes please!!
Hi John,
CheersMark
Hi Skot.I'm seeking a good camshaft. Can you see if that engine being disassembled has a one available please.I rebuilt my engine with all new parts a couple of years ago. I had the cam reground by Waggots in Alstonville. I used new Febi lifters.The engine starting getting hot on occasions running warmer the. Usual and I decided to pull the heads. I found that my lifters from the rear cylinder are badly worn as is the cam.Now I find out from Janian at Stokers that he has found reground cams and febi lifters are not compatible.
Hi Mark,
See photo.
Yes please!!
Hi John,
CheersMark
CheersPaul DumaisAerospace Engineer
On 2 Jul 2018, at 11:31 am, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:
Unfortunately Paul - the rest of that engine has been promised to Nils on here - which he requested from Phil prior to the engine being removed.
Maybe contact Nils - he may have a spare lying around?
On 2/07/2018 10:57 AM, Paul Dumais paul.d.dumais@gmail.com [Syncro_T3_Australia] wrote:
Hi Mark,
See photo.
Yes please!!
Hi John,
CheersMark
On Mon, 2 Jul 2018 at 11:53 am, gregespo73@yahoo.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Reground cams and second hand cams are a waist of time and money. Greg
Sent from Greg's iPhone
On 2 Jul 2018, at 11:31 am, Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com> wrote:Unfortunately Paul - the rest of that engine has been promised to Nils on here - which he requested from Phil prior to the engine being removed.
Hi Mark,
See photo.
Yes please!!
Hi John,
CheersMark
