My brake master cyl is shot and looking to replace soon. Am thinking of pulling the dash and going through the whole pedal cluster and clutch master at the same time, check the clevis's and pins etc while in there reading recent posts!
Doing some reading, the brake and clutch master's can be replaced without pulling the dash? But the pedals and bush's/pins. clevis's require the dash out to check/fix/replace?
Don't want to pull the dash for no reason as it's really only the brake master gone, but also happy to pull the lot and fix it all in one go rather than find in a months time something else needs doing.
Also in a not too old post some one had the clutch plastic hose let go. Has anyone had one remade in steel, and is it something easy to replace later (or better to replace if everything is out)
From what I have read, I will leave the booster as is, they seem to last fine.
Not sure if anything else is worth doing while in there if the dash comes out? I have recently put relay's in for the head lights and ignition. If I get keen I might open the vent box and grease the fan bearings (another common thing I see)
Thanks for any suggestions,
