BenT,
My sentiments exactly and addresses the nub of the problem. One would have to demolish the van to access and properly treat/seal/protect the total width of the seams. Impossible/impractical.
Date: Tue, 8 Mar 2011 12:42:19 -0800
Subject: Re: [Syncro_T3_Australia] Re: Dealing with rust.
Hi Skot,
In my experience, the procedure you describe is a 'bandaid' repair. Unless the seams are cleaned-up and resealed from the backside, the seam rust will return very quickly. You would almost be better off sealing both sides without making any repairs than repairing only on one side without touching the source of corrosion. The freshly sandblasted metal would just provide fertile ground for the tinworm to cultivate.
sent from my electronic leash
On Mar 8, 2011, at 12:34 PM, "Mr Scott Pitcher" <spbconsulting@bigpond.com> wrote:
Ken,I saw a bloke from the Gold Coast area who just works on kombis and restores them doing a T3 2wd recently (Das Autohaus). He had a special tool that removed the seem sealer (scraped it out) then he sandblasted the seam before repainting in there then using new seam sealer.At least the area had paint protection.These areas are a very common problem and I have even seen a few T4's starting to get seam rash.Skot----- Original Message -----From: Ken GarrattSent: Wednesday, March 09, 2011 12:52 AMSubject: RE: [Syncro_T3_Australia] Re: Dealing with rust.Greg,
Yeah well there's long been a school of thought that syncro seam rust starts from the inside of the seam and works to the outside. Probably right too. So when eyeballing closely a rusted seam from the outside and with a thought of remedying it properly, I must say I have serious doubts it is even remotely possible without first dismantling the panels, and what average punter is going to do that?Yep, Sika products look pretty good eh, with the proviso that rusted seams from without to within are properly treated first. The hard bit.Cheers.Ken
Date: Mon, 7 Mar 2011 19:29:34 -0800
Ken, Fusor and I think sika make the correct products for seam filling. Remember these vans are 20yrs old, the seam filler in our vans has shrunk and gone hard. No mailable product will stay the same forever.
Received: Tuesday, 8 March, 2011, 9:49 AM
Benny,In my view, a prerequisite to a syncro full body prep and respray would be first establishing my confidence that the body panel shop has the knowledge, experience and long established technique for a longish term solution for treating AND sealing panel seams, be they rusted or not. I see no point in proceeding down this path if this cannot be established. A case of needing "the weakest link in the chain", the panel seams, being properly addressed or else forget it, leave the existing paintwork as is and deal with rust/paint as best one can. I mean it's a lot of money invested in a new paint job, only to see seam failure again on the first trip away.So for panel seams to be properly addressed/treated/sealed/painted as opposed to overlooked or contemptuous scant regard, if lead loading is a solution but unavailable and bog is available but the wrong solution, is there in the panel beating/spray painting industry an established technique that satisfactorily deals with panel seam seal failure due most likely to body panel/structural flexing? In other words, if the panel seams succumb to flex and so the seam seal duly fails, is there a known technique that treats and reseals the seams, allows the seam to flex thereafter AND that auto paints adhere to and don't crack?I'm here to learn but I suspect I know your answer but please prove me wrong. TIACheers.Ken
Date: Mon, 7 Mar 2011 13:00:54 +0000
Subject: [Syncro_T3_Australia] Re: Dealing with rust.
Kenny,I wasnt advocating the use of nicky in seams.
Bog is widely used as a filler in the repair of vehicles.
If used properly after minor rust repair it will be fine..
> Benny,Do typical bog properties include stretching/flexing ability to accommodate usual stresses and strains in syncro body panel join seams?Cheers.Ken
> From: bencroft96@...
> Date: Mon, 7 Mar 2011 00:36:41 +0000
> Lead wiping is a skill that most younger gen panel beaters wouldnt of even seen.Just bog it up,mate.
> --- In Syncro_T3_Australia@yahoogroups.com, Roger Bell <bellrmit@> wrote:
> > I found the attached interesting and informative for those reluctant to replace all metal parts with stainless steel ! I've seen lead loading done by a skilled tradesman and was most impressed with the quality and promised logivity of the result.
> > Roger
> > Melbourne not on Sea
> > Seam rust prevention?: lead loading...
> > Posted by: "Pedro" pedrokrusher@ pedrokrusher
> > Sat Mar 5, 2011 2:11 pm (PST)
> > Hi syncronuts
> > Here is a web site describing a lead loading technique that I believe could be a usefull way to stop/limit the seam rust for us on the salt belt:
> > http://www.thehotwo rks.com/restorat ion-and-customis ation-techniques /lead-loading
> > Check out the custom job on the doublecab. Some pretty neat stuff like the custom metal bumpers. Don't like what they did with the horizontal middle side rib do...
> > Pedro
> > 1991 vanagon westfalia conversion TDI, Silverfox
> > 1989 vanagon syncro passenger, Syncrofox
