Michael,
The front end of the gearbox is that same so there is no difference in the fitting but you will have to procure all the parts that normally exist on a Syncro with a diff lock – vacuum tapping off the manifold, vacuum reservoir and plumbing, plus the control panel and “switch” (actually a vacuum valve) for the front.
The decoupler with a needle roller is better than the plain bush variety.
On Behalf Of Michael Rayner
Sent: 12 May 2010 18:32
decoupler
I know it's probable been discussed before, but can I
install a decoupler on my NON rear diff lock syncro.I have
an aggressive VC and would feel more comfortable disengaging it when it's not
required.If so which of the two versions are better suited, the German or
American models.
Michael_,_.___
Sent: Wed, 12 May, 2010 6:51:13 PM
Subject: RE: [Syncro_T3_Australia] decoupler
Michael,
Syncro_T3_Australia @yahoogroups. com
[mailto: Syncro_T3_Australia @yahoogroups. com ]
Subject: [Syncro_T3_Australi a]
decoupler
American models.
Michael_,_.___
Michael,
Your choice. The end result is much the same. There is a case for utilizing the better handling and braking characteristics that is experienced with an aggressive VC but eventually it’s your call.
Sent: 12 May 2010 18:57
decoupler
Hi Les.
Might be cheaper to buy a new VC?
Michael
Michael,
decoupler
American models.
Michael_,_.___
Try the USA boys for S/H.
> Michael Rayner <mrayner51@yahoo.com> wrote:
> Do all the below listed plumbing and vacuum's come in kit form? Does
> anyone sell such accessories, maybe Brent T's mate Florian in USA.
> Regards
> Michael
> From: Les Harris <leslieharris@optusnet.com.au>
> Michael,
> will have
> lock �������� vacuum
> control panel
> and �������switch�������� (actually a vacuum valve) for the front.
> From:Syncro_T3_Australia @yahoogroups. com
> [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of Michael
> Rayner
> decoupler
> it's not
> or
> American models.
> Regards
> Michael_,_.___
> Reply to sender | Reply to group | Reply via web post | Start a New
> Topic
> Messages
> in this topic (21)
Thanks for the responses.
Michael,
decoupler
American models.
Michael_,_.___
--- In Syncro_T3_Australia@yahoogroups.com, Michael Rayner <mrayner51@...> wrote:
> I've read some of the old postings on decouplers. I'm non m/m (mechanically minded). What does it entail in returning the 'refund core deposit'. Has anyone in Australia returned/shipped their 'core' for fitting a decoupler?Regards
> Michael
> From: Les Harris <leslieharris@...>
> Michael,
> to procure all the parts that normally exist on a Syncro with a diff lock â" vacuum
> and âswitchâ (actually a vacuum valve) for the front.
> [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of Michael Rayner
> decoupler
> American models.
> Regards
> Michael_,_.___
> Reply to sender | Reply to group | Reply via web post | Start a New Topic
> Messages
> in this topic (21)
Michael,
A good kit will come with the vacuum servo, lots of small diameter nylon vac tube and a vac valve that mounts on the front control panel.
If you are fitting it to a Syncro that never had a diff lock fitted, you have to source the vac supply, vac reservoir and the control panel that fits on the dash. The decoupler valve (“switch”) usually goes in the middle position.
Sent: 12 May 2010 20:27
decoupler
Do all the below listed plumbing and vacuum's come in kit form? Does anyone sell such accessories, maybe Brent T's mate Florian in USA .
Michael
_,___
On Thu, May 13, 2010 at 9:05 AM, Les Harris <leslieharris@optusnet.com.au> wrote:
Michael,
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Michael Rayner
Sent: 12 May 2010 20:27Subject: Re: [Syncro_T3_Australia] decouplerLes
Do all the below listed plumbing and vacuum's come in kit form? Does anyone sell such accessories, maybe Brent T's mate Florian in USA.
Michael
_,___
Sent from my iPhone
On 20/11/2010, at 7:44 PM, gregespo73 <gregespo73@yahoo.com> wrote:
For all those coming to the DOTVW tommorrow. I have just received the first shipment from Florian of my decoupler, which includes the nose cone. I will bring it in case any one wants to "touch and feel" before buying one. They are beautifully put together and the kit is beyond comprehensive. Greg E
--- In Syncro_T3_Australia@yahoogroups.com, Mark Kofahl <markkofahl@...> wrote:
> Hi Greg
> That will be great. Just back from the dinner. Should be a good day tommorow
> Regards
> Mark
> Sent from my iPhone
Pete, I am not selling just buying. Florian last posted on the 28/10, search back and you will find his add. Greg E--- On Mon, 22/11/10, nerdnetty <peterw1000@gmail.com> wrote: |
Regards Greg.
(taken from their email sent to me recently)
Decoupler comes as a complete unit, so all you have to do is change the nose cone and install the tubes and switches which are part of the decoupler unit. It is quite easy, but we will add a manual instruction off course as well.
The deposit is for the old nose cone that we need to get back to get new decouplers manufactured. If you send the nose cone back to us, please sign the parcel as "example" without any value; otherwhise we´ll get in trouble with customs here in germany.
On 4 May 2011 22:14, Greg <greg_navarro95@yahoo.com> wrote:hello, I am looking at purchasing a decoupler from Syncro Services in Germany. Just checking if people have succesfully gone through this supplier and have had any problem in fitting or being re imbursed for the nose cone deposit as indicated in there email below.
Regards Greg.
Date: Wed, 4 May 2011 12:14:13 +0000
Subject: [Syncro_T3_Australia] decoupler
Regards Greg.
> Greg,The alternative supplier is Florian in the USA. He sells the german decoupler and even includes the nose gasket and detailed install instructions, a number of members here have been very satisfied not only with the product but also Florians shipping arrangements as well so as to avoid GST here on entry, keeping the overall price down. Also the exchange rate of the $OZ with $US makes it very attractive at the moment.
> For more info, goto: http://www.thelowestgear.com/
> Cheers.Ken
> From: greg_navarro95@...
> Regards Greg.
we bought sofar 4 units from Florian, every time the transaction has been faultless with core dep returned immediately. Same as with Syncro Services. Comes down to choice
for you. Mainthing is that you instal a unit asap. And the $ won't stay that high forever , Ben Bernake (helicopter Ben) will make sure of that. Hartmut
Date: Wed, 4 May 2011 22:46:35 +0000
Subject: [Syncro_T3_Australia] Re: decoupler
Thanks Ken is the product Florian supplies the same as the product Francesca has been supplied by Syncro Services? Greg
> Cheers.Ken
> Regards Greg.
