Hi Phill, that’s no problem.
I have the part that they took which I understand was the existing output housing and coupling sleeve. The original flange must have been used or possibly kept by the mechanic.
You can call Dean at Volkspower on 03 9808 6777 - they did the work and will have the info for you.
He also has a couple of syncros himself and may have a s/h flange on the shelf that he can help you out with measurement.
If I can help you with any of the parts that I have I would be happy to.
Stuart
Behalf Of plander@optusnet.com.au
Sent: Thursday, 28
July 2005 10:25 AM
Subject: Re: RE: RE:
[Syncro_T3_Australia] Decoupler
Thank
You.
If it is possible and you still have your old
flange, could you please measure accurately the PCD of the four tailshaft
bolts. Should be around 70mm but I need an accurate measurement and also the
diameter of the raised centre.
> Stuart Parry <stuart@oddball.com.au>
wrote:
> If you say "thank you" and
ask nicely I will tell you.
On Behalf Of
> Sent: Thursday, 28 July 2005 9:45 AM
> Subject: Re: RE: [Syncro_T3_Australia]
Decoupler
> Did yours come with the flange for the
tailshaft or did you have to swap
> it
> over?
> I need to see a flange or tailshaft (or get
the measurements) so that I
> can
> make a tool to hold it for removal.
> Who did the work?
> > Stuart Parry
<stuart@oddball.com.au> wrote:
> > I have.
> > Had it fitted last Monday onto my 89
Syncro Trakka.
> > Haven't driven it much since then but in
the time I have I know that
> it
> > makes a terrific difference to the
van. It rolls nicely, it turns
> > fantastically, the fuel economy (in the
limited time I have driven it)
> > appears to be better. Comparisons
are easy because the complete
> > opposite
> > happens when I switch the decoupler off
. I guess the thing ended up
> > costing me around $2500 completely
fitted etc. but I knew it was worth
> > it
> > after 10 minutes of city driving.
> > My VC was still working according to the
standard testing methods but
> > once
> > you turned full lock it was very tight.
> > The fitting had a few difficulties
- the mechanics couldn't find the
> > connection in the loom where the
instructions stated it was - this
> might
> > well be a Trakka thing - the van was
fitted with all the Trakka
> extras
> > and
> > this might have created the problem.
> > If you have any specific questions just
let me know.
> > Stuart
> > From:
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of hdvwoc
> > Sent: Wednesday, 27 July 2005 9:03 PM
> > Subject: [Syncro_T3_Australia] Decoupler
> > Has anyone fitted their group buy
decoupler yet?
> > _____
> > YAHOO! GROUPS LINKS
* Visit your group
"Syncro_T3_Australia
> > <http://groups.yahoo.com/group/Syncro_T3_Australia>
" on the web.
* To unsubscribe from
this group, send an email to:
<mailto:Syncro_T3_Australia-unsubscribe@yahoogroups.com?subject=Unsubscri
> > be>
* Your use of Yahoo!
Groups is subject to the Yahoo!
> > <http://docs.yahoo.com/info/terms/>
Terms of Service.
> > _____
> YAHOO! GROUPS LINKS
* Visit your group "Syncro_T3_Australia
" on the web.
> be>
Terms of Service.
