F·%&/·/)·%&/ bad.
Let's do it
KAISERLAUTERN
Has anyone fitted their decoupler yet?
How about a story?
> How about a story?
Phil …I have fitted a Diff Lock and Decoupler to a Non-Standard ex Telstra Van…Its very simple.( The Vacuum side of it) If you get the chance to swing under a Dlx or Caravelle and you will see that the Vacuum line that feeds the Brake Booster has a “T’ that leads to the Vac Reservoir…these “T’s” are cheap through VW…and you will also need a few other “T” pieces if you have access to ETKA the Nos are on it.
The Decoupler I bought was from Germany (Bernd Jaeger) one , and it did have the flange attached to the Nose piece with it.
Ken Tyler
-----Original
Message-----
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of hdvwoc
Sent: Monday, 11 July 2005 1:16 PM
Decoupler
Has anyone from the decoupler
group buy fitted theirs yet?
Did the flange that bolts to the tailshaft come
with it?
Has anyone fitted one to a standard non diff lock
syncro and where did
you pick the vacuum line from?
I also need some info on the vacuum reservoir and
valve from a deluxe
or Carravelle.
> Phil .I have fitted a Diff Lock and Decoupler to a Non-Standard exthe
> Telstra Van.Its very simple.( The Vacuum side of it) If you get
> chance to swing under a Dlx or Caravelle and you will see that theVac
> Vacuum line that feeds the Brake Booster has a "T' that leads to the
> Reservoir.these "T's" are cheap through VW.and you will also need afew
> other "T" pieces if you have access to ETKA the Nos are on it.did
> have the flange attached to the Nose piece with it.I don't think that Bernd Jaeger's quality control is too good. I don't
> Ken Tyler
Phil…Not too sure what your referring to here?? Please explain..
Ken Tyler
-----Original
Message-----
Sent: Tuesday, 12 July 2005 9:52
AM
Decoupler
--- In
Syncro_T3_Australia@yahoogroups.com, "Ken Tyler" <kct@i...>
of it) If you get
the
Vac
few
did
with it.
> Ken Tyler
think that I would recomend him. You think that
something like that
would get noticed at the workshop?
> The Decoupler I bought was from Germany (Bernd Jaeger) one , and itdon't think that I would recomend him. You think that something like
> did
> > Ken Tyler
> would get noticed at the workshop?No flange or nut on mine.
Oh…Sorry I didn’t realise yours was a Bernd Jaeger one….I thought it was from the States??
Yes the Vacuum Servo is identical as the Diff Lock one. Why do you have to replace yours?? Was it damaged in transit? Have you located the Electrical wiring for the Decoupler??
It took me awhile…but I eventually found it.
Regards..
Ken Tyler
-----Original
Message-----
Sent: Tuesday, 12 July 2005 10:31
AM
Decoupler
> did
piece with it.
> > Ken Tyler
is too good. I
that something like
that
Is the vacuum servo the same as the normal diff
lock ones as I have to
replace mine?
> Yes the Vacuum Servo is identical as the Diff Lock one. Why do you haveYes
> Electrical wiring for the Decoupler??I've seen it before up above the gearbox.
Phil, What oil do you use in your Gearbox/Trasaxle…I'm about to do a change…and have been told Redline ML90.?? Any thoughts??
Ken Tyler
-----Original
Message-----
Sent: Tuesday, 12 July 2005 11:07
AM
Subject: Re: RE:
[Syncro_T3_Australia] Re: Decoupler
transit?
Yes
> Ken Tyler <kct@iinet.net.au> wrote:
> Phil, What oil do you use in your Gearbox/Trasaxle.I'm about to do a
> change.and have been told Redline ML90.?? Any thoughts??
>Has anyone from the Bernd Jaeger decoupler group buy fitted theirs yet?
>The flange that bolts to the tailshaft did not come with mine. I need
>someone that has a propshaft or the flange out of the car to get
>measurements so that I can make a tool for holding the flange so that I
>can swap my old old one to the decoupler if it is the same. I am hoping
>that the flange is not supposed to be modified or machined for some
>reason. Can anyone on here help me?
>(see the decoupler at photo number 31)
>Yahoo! Groups Links
I have.
Had it fitted last Monday onto my 89 Syncro Trakka.
Haven’t driven it much since then but in the time I have I know that it makes a terrific difference to the van. It rolls nicely, it turns fantastically, the fuel economy (in the limited time I have driven it) appears to be better. Comparisons are easy because the complete opposite happens when I switch the decoupler off . I guess the thing ended up costing me around $2500 completely fitted etc. but I knew it was worth it after 10 minutes of city driving.
My VC was still working according to the standard testing methods but once you turned full lock it was very tight.
The fitting had a few difficulties – the mechanics couldn’t find the connection in the loom where the instructions stated it was – this might well be a Trakka thing – the van was fitted with all the Trakka extras and this might have created the problem.
If you have any specific questions just let me know.
Stuart
Behalf Of hdvwoc
Sent: Wednesday, 27
July 2005 9:03 PM
To:
Decoupler
Has anyone fitted their group
buy decoupler yet?
> Stuart Parry <stuart@oddball.com.au> wrote:
> I have.
> Haven't driven it much since then but in the time I have I know that it
> opposite
> it
> once
> The fitting had a few difficulties - the mechanics couldn't find the
> connection in the loom where the instructions stated it was - this might
> well be a Trakka thing - the van was fitted with all the Trakka extras
> and
> Stuart
> Sent: Wednesday, 27 July 2005 9:03 PM
> Subject: [Syncro_T3_Australia] Decoupler
> Has anyone fitted their group buy decoupler yet?
> YAHOO! GROUPS LINKS
> * Visit your group "Syncro_T3_Australia
> <http://groups.yahoo.com/group/Syncro_T3_Australia> " on the web.
> * To unsubscribe from this group, send an email to:
> <mailto:Syncro_T3_Australia-unsubscribe@yahoogroups.com?subject=Unsubscri
> be>
> * Your use of Yahoo! Groups is subject to the Yahoo!
> <http://docs.yahoo.com/info/terms/> Terms of Service.
If you say “thank you” and ask nicely I will tell you.
Sent: Thursday, 28 July 2005 9:45
AM
Subject: Re: RE:
Did yours come with the
flange for the tailshaft or did you have to swap it over?
I need to see a flange or tailshaft (or get the
measurements) so that I can make a tool to hold it for removal.
Who did the work?
wrote:
> I have.
Trakka.
> opposite
> it
> once
> and
me know.
> Stuart
On Behalf Of hdvwoc
yet?
> YAHOO! GROUPS LINKS
* Visit your group
" on the web.
> be>
Terms of Service.
> If you say "thank you" and ask nicely I will tell you.
> Sent: Thursday, 28 July 2005 9:45 AM
> Subject: Re: RE: [Syncro_T3_Australia] Decoupler
> Did yours come with the flange for the tailshaft or did you have to swap
> it
> over?
> I need to see a flange or tailshaft (or get the measurements) so that I
> can
> Who did the work?
> > I have.
> it
> > opposite
> > it
> > once
> might
> extras
> > and
> > Stuart
> > _____
> > YAHOO! GROUPS LINKS
> > be>
> > _____
> YAHOO! GROUPS LINKS
> be>
