It is unlikely that the “switch” (vacuum valve) would be beyond reclamation. I haven’t had one apart but I surmise that it uses ‘O’ rings, as most vacuum valves do. Whilst it is unlikely that a VW dealer would have them (and they would cost a ridiculous amount anyway), all commercial bearing companies carry an immense range of ‘O’ rings and are sure to have the size.
There are lots of small switch panels available at the auto aftermarket places and you are bound to find one that suits.
On Behalf Of greg_navarro95
Sent: 30 May 2010 17:48
diff lock switch and face plate
Hello, Can anyone tell me where I could buy a switch for my diff lock and a dashboard face plate where the diff lock switch is located. Both are stuffed on my vehicle. Thanks Greg
----- Original Message -----From: Les HarrisSent: Sunday, May 30, 2010 6:34 PMSubject: RE: [Syncro_T3_Australia] diff lock switch and face plate
It is unlikely that the switch (vacuum valve) would be beyond reclamation. I havent had one apart but I surmise that it uses O rings, as most vacuum valves do. Whilst it is unlikely that a VW dealer would have them (and they would cost a ridiculous amount anyway), all commercial bearing companies carry an immense range of O rings and are sure to have the size.
From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of greg_navarro95
Subject: [Syncro_T3_Australi a] diff lock switch and face plate
The face plate I am talking of is the same as the one in the second photo of the photos section, so I figure it must be a syncro part.
I have read that you have a CD with syncro parts on it and I was wondering if I could get a copy of this if its not too much trouble.
Greg
> Greg,
> It is unlikely that the "switch" (vacuum valve) would be beyond reclamation.
> I haven't had one apart but I surmise that it uses 'O' rings, as most vacuum
> carry an immense range of 'O' rings and are sure to have the size.
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of greg_navarro95
> Subject: [Syncro_T3_Australia] diff lock switch and face plate
--- In Syncro_T3_Australia@yahoogroups.com, "greg_navarro95" <greg_navarro95@...> wrote:
> Les, the problem with the switch is the shaft pulls straight out of the dash into my hand and whatever keeps it from coming out has broken off.
> Greg
> --- In Syncro_T3_Australia@yahoogroups.com, "Les Harris" <leslieharris@> wrote:
> > Greg,
> > Les
> > _____
Have you taken the control panel out to see if it can be repaired instead?
Finding a replacement is problematic and expensive.
Date: Sun, 30 May 2010 13:58:16 +0000
Subject: [Syncro_T3_Australia] Re: diff lock switch and face plate
Greg
> Greg,
Find it at CarPoint.com.au New, Used, Demo, Dealer or Private?
I dont like problematic or expensive but the face plate is cracked in 3 places and missing a piece all together.
Of course the bit missing is the bit that holds the switch/ shaft from coming out in your hand. I was hoping someone had one sitting in a box somewhere that they dont want. LOL Greg
> Greg,
> From: greg_navarro95@...
> Greg
> > Greg,
> > Les
> > _____
> New, Used, Demo, Dealer or Private? Find it at CarPoint.com.au
> http://clk.atdmt.com/NMN/go/206222968/direct/01/
----- Original Message -----From: greg_navarro95Sent: Monday, May 31, 2010 9:29 PMSubject: [Syncro_T3_Australia] Re: diff lock switch and face plateHi Ken
> Greg,
> Greg
> > Greg,
> > Les
> > _____
Angebot beobachten Range observed
Wenn Sie weitere Angebote hinzufügen möchten, entfernen Sie bitte einige aus der Liste der beobachteten Angebote Mein eBay . If you want to add more services, please remove some from the list of observed Offers My eBay .
> Greg,
> Greg
> > Greg,
> > Les
> > _____
I am in WA and a fair way from you.
I will either email you or phone you tomorrow and get your price and arrange postage from your end. Greg
> Greg,
> This is my spare face plate.
> See the strange shaped hole made in the front diff-lock spot.
> Let me know if you want it.
> Scott
> Hi Ken
> > Greg,
> > Greg
> > > Greg,
> > > Les
> > > _____
----- Original Message -----From: greg_navarro95Sent: Monday, May 31, 2010 11:34 PMSubject: [Syncro_T3_Australia] Re: diff lock switch and face plateThanks Scott
> Greg,
> Scott
> Hi Ken
> > Greg,
> > Greg
> > > Greg,
> > > Les
> > > _____
On 31/05/2010, at 10:43 PM, Mr Scott Pitcher wrote:<108_6814.JPG>Greg,This is my spare face plate.See the strange shaped hole made in the front diff-lock spot.Let me know if you want it.Cheers,
Scott----- Original Message -----From: greg_navarro95Sent: Monday, May 31, 2010 9:29 PMSubject: [Syncro_T3_Australi a] Re: diff lock switch and face plateHi Ken
--- In Syncro_T3_Australia @yahoogroups. com, Ken Garratt <unclekenz@.. .> wrote:
> Greg,
> From: greg_navarro95@ ...
> Greg
> --- In Syncro_T3_Australia @yahoogroups. com, "Les Harris" <leslieharris@> wrote:
> > Greg,
> > Les
> > _____
> > [mailto:Syncro_T3_Australia @yahoogroups. com] On Behalf Of greg_navarro95
> New, Used, Demo, Dealer or Private? Find it at CarPoint.com. au
> http://clk.atdmt. com/NMN/go/ 206222968/ direct/01/
----- Original Message -----From: Gary CooksonSent: Tuesday, June 01, 2010 9:11 AMSubject: Re: [Syncro_T3_Australia] Re: diff lock switch and face plateScott, that is a factory hole. The front diff lock requires an extra turn to operate it, safety measure I guess.
Gary
> Greg,
> Greg
> > Greg,
> > Les
> > _____
I see.Oh well Greg can have one with a factory hole and he can easily fit a front diff -lock if he feels inclined. Seeing the hole was so large and it had a side slit - I just assumed it had been butchered for an electrical device. Other than that - it is in perfect condition and the hole is fairly neatly cut - possibly done by the factory?----- Original Message -----From: Gary CooksonSent: Tuesday, June 01, 2010 9:11 AMSubject: Re: [Syncro_T3_Australi a] Re: diff lock switch and face plateScott, that is a factory hole. The front diff lock requires an extra turn to operate it, safety measure I guess.
Gary
> Greg,
> Greg
> > Greg,
> > Les
> > _____
You better rush out and buy a lottery ticket. Well done Scott.
See my added pics attached. This method of blanking the large hole should work a treat for you.
As you would know, the historical link between Steyer-Puch and the syncro drivetrain components makes the embelishing of the panel with this badge to be most fitting. The fact that the badge colours match exactly with the panel colours, especially when the lighting is on ...... is really nice.
I sourced these badges in Sydney direct from the suppliers shop. Or else it is available through the same suppliers ebay store.
Goto: http://cgi.ebay.com.au/11899-PUCH-ROUND-LOGO-MOTORBIKE-PIN-BADGE-/370349501782?cmd=ViewItem&pt=AU_PinsBadgesPatches&hash=item563a8ced56
There are many different Puch badges available on ebay but this one happens to be the correct size to fit snugly into the switch position recess and sourced locally was a bonus. I understand it is manufactured in New Zealand.
Food for thought.
Date: Mon, 31 May 2010 22:43:44 +1000
> Greg,
> Greg
> > Greg,
> > Les
> > _____
It just gets better and better.
Now If I could open the attachments it would be better still. I know Les says its in the settings but I cant find it.
Does Anyone have any clues where to find these and what to do when you have?
> Greg,
> Food for thought.
> From: spbconsulting@...
> Greg,
> Scott
> Hi Ken
> > Greg,
> > Greg
> > > Greg,
> > > Les
> > > _____
> Need a new place to live? Find it on Domain.com.au
> http://clk.atdmt.com/NMN/go/157631292/direct/01/
The Syncro_T3_Australia settings allow all members to attach image files to their messages. If you aren’t getting images with the Syncro_T3_Australia emails, then it is your own email programme that needs to be reset to allow you to view them. We can’t help your from this end. What email programme are you using?
Sent: 01 June 2010 15:08
To:
Subject: FW: [Syncro_T3_Australia]
Cheers Ken.
Now If I could open
but I cant find it.
I ordered a badge this morning. Simple process through EBay and PayPal. It will look great in the button unit alongside the button for my new decoupler which is on its way.
