Gday Harold,
Adding to what Les has said, offroad, it is possible in the circumstance
where one wheel on each axle spins at the same time, so a stock syncro
is going nowhere under those conditions. Having a rear diflock and
engaged would give you that extra possibility of extracting yourself
from a ticklish situation which otherwise you may end up stuck.
If it's important enough to anyone wanting a diflock (usually the rear),
then its a case of searching around for a complete replacement diflocked
transaxle (2nd hand) and also finding and installing all the extra bits
needed to get it to function. Lot of trouble and expense, but heh,
that's your choice in terms of priorities.
My syncro didn't originally have a diflocked transaxle. However, when I
bought it, there was one onboard. I went ahead and had all the extra
bits installed and so yes .... works a treat. In my view however, if you
want to avoid huge repair bills, it's not something to use as a
play-thing, rather as a last line of defence for offroad
security/safety.
--- In
Syncro_T3_Australia@yahoogroups.com, "Les Harris"
<leslieharris@...> wrote:
> Harold,
> The diff locks, both front and rear, were original equipment and a
Syncro could be ordered with no locks, rear lock, or front and rear
locks. The gearbox casting, however, is different, so it was an OE
option when ordering the Syncro from new.
> For average difficult terrain - eroded fire trails and similar - a
Syncro without diff locks is remarkably capable. Using judicious driving
techniques, it will deal with some quite improbable situations.
> From: oznewf19
> Sent: Tuesday, October 28, 2008 10:37 PM
> Subject: [Syncro_T3_Australia] Diff Switch's
> Hi, I was just curious about the diff switch's I hear and read about
on
> the differnet syncro sites. I have a 1989 syncro Trakka conversion and
> so far I am truly impressed and happy with my van. We recently did the
> Holland Track in WA and intend to do more of the same type of trakking
> and camping. I was just wondering was the diff lock and switch an
> option, a factory thing or an aftermarket? Also, unless doing serious
> 4X4ing would it be considered a necessary item or a desirable. On the
> track we did I didn't even hear or feel the wheels spin and we were
the
> only ones who had to tow anyone out of a mud hole! A very pleasant
> surprise. Thanks for any info... Sincerely, Harold
