Hi group.
This has been a pretty big weekend. I took on the challenge of the 2.1 donor motor swap. I found a 2.1 for $800 in reasonable condition with 180kms. (bargain?). Pulled out the old motor (head problems) and fitted the donor one within 2 long nights. Found out a few problems the hard way, one being that a 2wd engine frame is smaller than the syncro frame. (though the engine looked strange sitting 10cm higher than before).
Anyway everything went to plan, it cranks over well, drives fine with plenty of power however as soon as you slow down for a u turn or the stop lights it will chug like a choke is on and then stall (if you let it). Crank it back over and its fine again. Is this an air flow sensor issue? I swapped the little unit on top of the manifold which I assume is the air flow sensor off the donor engine with the old original engine to see if it made a difference but it was still the same. If anyone has any clues or advice I thank you. Also when I first cranked it over it ran pretty rough with some blackish smoke so I dissconnected the lead out of the air flow sensor* and plugged it back in. It ran fine after that. . . . . . .
I uploaded a few photos there as well
Bartley Olsen
Sorry about some photos there, attempting this task alone made me a little insane at times.
Bartley Olsen
