On May 27, 2010, at 3:28 AM, greg esposito <gregespo73@yahoo.com> wrote:
Ben, Sorry but 2wd springs are not all the same. Greg, if you re-read my posting, you might find that I said 16" & 14" Syncro are the same.
Carats are lower from the factory. I believe that is also written in the second paragraph.
There was also heavy duty springs available as an option on dokas, they have green paint dots. I did not touch the subject of spring rates inybposting because it was late (in California) and I did not want to go into writing about taxi springs, etc. w/o having all the details on hand.And just to be clear, I also specified reference only to FRONT springs. Another FYI, Carat springs gauge (I'm sure spring rate too) from the 84-85 2wd springs.BenT
--- On Thu, 27/5/10, BenT Syncro <syncro@gmail.com> wrote:
Subject: Re: [Syncro_T3_Australia] Re: electrolisis
Cc: "gregespo73@yahoo.com" <gregespo73@yahoo.com>
Received: Thursday, 27 May, 2010, 8:01 PM
Greg,I going to throw in my 2 cents here. I own a Syncro 16 Doka. There is no difference between the springs on the 16" Syncros or the 14". There is also no difference between springs on vans or dokas or sinkas for that matter.You can use 2wd springs to raise the Syncro a little. Tallest are from the 1985 models. I recently removed some from a 1984 T3 and compared them to 87-91 Carat springs (all these are 2wd). They Carat springs were about 1.5" shorter. Unfortunately, I did not have a Syncro spring handy for comparison. I did not get an opportunity to check on the rear springs yet.
The coolant is the direct contact. Think of how chrome/zinc plating works.
> Isn't the coolant conductive? Don't get me wrong I don't have a problem
> with s/s pipes in t3's and I know this has been debated on other forums
> at length. My thinking is that if you are running the right coolant and
> replacing it often you have nothing to worry about. Greg E
> From: Yurik Orlowsky <yuriko@iinet.net.au>
> Sent: Tuesday, 24 April 2012 10:32 AM
> Subject: RE: [Syncro_T3_Australia] Re: electrolysis
> Hi Pete,
> Electrolysis will only occur if there is physical contact between
> dissimilar metals. Since the ss pipes are connected to the Al engine
> with rubber hoses, there is no physical ����contact between them and hence
> no electrolytic reaction will occur. ����It is an important factor in
> installing the ss cooling pipes to make sure that there is no contact
> with the engine.
> Regards
> Yurik
> From:Syncro_T3_Australia@yahoogroups.com
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Anette
> Sent: Tuesday, 24 April 2012 8:04 AM
> Subject: [Syncro_T3_Australia] Re: Sticker
> Guys, with our waterboxers being aluminium and the replacement pipes
> being Stainless could there be an issue with electrolisis turning the
> alloy motor into a sacreficial anode ? best Regards pete
