Front and rear disc brakes for all BEETLES and Type 3 in 4 and 5 stud V.W., |
Or in any other bolt pattern e.g.. Ford - Commodore - Chevrolet - Porsche etc. |
No modifications required at all, to front or rear end. The kit comes with everything required: |
Discs - Calipers - Mounting Brackets - Bearings - Pads and Bolts. |
Rear Brake Calipers have a handbrake mechanism which works with the original V.W. |
Handbrake cables on all models. Rear brake drums also available in any other bolt pattern. |
Front from.... $650 Rear from.... $750 |
Front discs only are available from.... $350pr. |
Front and Rear Disc Brakes for all KOMBIS up to 1992. No modifications required at all. |
All Kits come complete, and Rear Calipers have a handbrake mechanism which works with |
The original handbrake cables on all models... Priced from.... $850 |
Rear disc brake kits to suit all models up to 1980 from.... $660 |
All Front McPherson strut beetle can now be lowered 2" - 3" - 4" lower, |
By using our new struts and shorter shocky inserts - oil or gas |
And still retain the same travel by using your own standard coil springs. From.... $400pr. |
Strut Brace for all McPherson front ends - All Chrome .... $170 |
