Hi Hamish, I thought you might be interested in this little device. I think it would suit that stroker wbx you have. I bought mine from an eBay re seller in Aus for about $200. Just google Innovate motorsports and quite a few different sellers come up. The gauge is an MTX L air fuel ratio gauge. You also need a longer 18ft cable to go from the rear of the bus to the front . Got this from Rocket Industries for $70 , but have noticed some sellers offer these as well . Basically the O2 sensor replaces the stock sensor . It sends a signal to the gauge to give you a readout of the AFR. you are running. The gauge also has two programable circuits that you can use to send info (voltage) to the ecu. Different voltages mean different afr's. One circuit is ideally left so that it mimics the stock sensor' s signal and the second circuit you can program with a laptop to run a richer mixture when you need it. I got the idea of a vacuum activated switch to switch between the two circuits from Chris Corkins, the wbx builder in the US . Greg Esposito did some searching & came up with the perfect switch for this application. You'll have to extract info on that switch from him , as I don't know where he sourced it from. Hope you understand my long winded explanation . Any other questions & I 'll answer as best I can. Maybe Greg can give you a more technical explanation if he gets any free time from his young family. Eddie.
--- In Syncro_T3_Australia@yahoogroups.com, Hamish Dobson <dobson_hamish@...> wrote:
> Hi Eddie,
> This 'Innovate air fuel ratio gauge which comes with its own 02 sensor'.
> How can one acquire one of these?
> Additionally how did u integrate it with the Vw ecu? Can you explain in more detail how u installed it and got it working?
> Best regards
> Hamish
> Sent from my iPhone
> On 09/03/2013, at 7:48 AM, "eddie" <bergodaz@...> wrote:
> > Or for an extra 100 bucks get yourself an Innovate air fuel ratio gauge which comes with its own 02 sensor. Been running mine withMax the Machwo airfuel ratios I programmed into itfor nearly a year now ( about 20000k's) and its running great. Runs nice and rich when I put my foot down and lean when I'm cruizing. The stock 02 sensor can't give you that.
> > --- In Syncro_T3_Australia@yahoogroups.com, Scott Daniel - Turbovans <ScottDaniel@> wrote:
> >> Greetings all,
> >> re how much does an 02 sensor cost . Here in Oregon an OE style one
> >> with the right connectors could be as high as $ 90 to 130 US .
> >> An aftermarket generic Bosch one that you splice in might be $ 60 to 70 US.
> >> I suppose having a hollow cat downstream of an 02sensor could affect how
> >> it reads the exhaust ..
> >> I wouldn't think so though really ..Many waterboxer engines are running
> >> with hollowed out cats.
> >> btw ..regarding poor fuel mileage ...consider if cat ( or muffler )
> >> might be starting to fail or partially clogged.
> >> I have seen them look ok looking into both ends , but in themiddle
> >> starting to fail.
> >> yeah ..it's always a good test if it's not running right to disconnect
> >> the 02.
> >> 02 input is bypassed at wide open throttle btw.
> >> I have not seen this issue myself but I have read about shorted 02
> >> coaxial cable ..and seen one or two vans with a new wire spliced in near
> >> the ecu.
> >> re apprarent engine power ....were tiresizes about the same ? Extra big
> >> ties eat up apparent engine power.
> >> scott
> >> turbovans
> >> On 3/8/2013 5:34 AM, Ken Garratt wrote:
> >>> Hi Philip,
> >>> It's said the engine runs rich when the Oxy sensor is disconnected or
> >>> has failed, so running the engine in that state long term may not be a
> >>> good idea.
> >>> It's said the Oxy sensor may not sense so well if the internals of the
> >>> Catalytic Converter are shot/non existent.
> >>> A useful thing to know is that if your van should ever have the
> >>> symptoms of "Vanagon Syndrome", it's worth trying disconnecting the
> >>> large green wire of the Oxy sensor leads ... this may help get you home.
> >>> Examples of Oxy Sensor pricing from usual US suppliers, plus shipping
> >>> cost:
> >>> https://www.busdepot.com/13957
> >>> http://www.van-cafe.com/home/van_1223689737929/page_347_1217/oxygen_sensor_-_complete.html
> >>> Cheers.
> >>> Ken
> >>> To: Syncro_T3_Australia@yahoogroups.com
> >>> CC: dobson_hamish@
> >>> From: philipmacrae@
> >>> Date: Thu, 7 Mar 2013 23:07:58 -0800
> >>> Subject: Re: [Syncro_T3_Australia] Exhaust sensors
> >>> Scott,
> >>> What does a new Oxygen Sensor cost these days???
> >>> I remember being told my Oxygen Sensor was exhausted so mechanic
> >>> disconnected it and the car went well disconnected for a long time.
> >>> Not Totally sure if its connected today because its in the shop
> >>> getting the ten year old penrite synthetic transmission oil changed
> >>> so I cant check.
> >>> I never replaced it.
> >>> I always check the fuel consumption as I always fill the tank.
> >>> Using 95 Super petrol Getting about 11.5 lt per 100k without decoupler
> >>> or diflock etc. Motor is original 255,000km. purchased with 98,000km.
> >>> The VC is probably also exhausted!
> >>> Oil consumption is 1 litre per 10,000km or less depending on type of
> >>> driving ie city vs highway or dirt roads.
> >>> When I drove the car for some years without the drive shaft (so 2WD) I
> >>> think I got about 10.5lt per 100k.
> >>> Other Syncros I have driven have had better acceleration than mine.
> >>> *From:* Scott Daniel - Turbovans <ScottDaniel@>
> >>> *To:* Syncro_T3_Australia@yahoogroups.com
> >>> *Cc:* Hamish Dobson <dobson_hamish@>
> >>> *Sent:* Wednesday, 6 March 2013 1:53 PM
> >>> *Subject:* Re: [Syncro_T3_Australia] Exhaust sensors
> >>> Imagine all the gasoline wasted in all that time by not having it
> >>> running really right.
> >>> Possibly rough on the engine having it run rich ..
> >>> like rough on the oil.
> >>> They are real easy to check for good function too ...the oxygen sensor.
> >>> On 3/6/2013 1:32 PM, Hamish Dobson wrote:
> >>> Hi all I recently replaced my exhaust sensor. Was the original
> >>> that I never changed when I rebuilt my engine aprx 15000 km ago.
> >>> I was always suffering from poor low down drivability issues due
> >>> to over fueling. At traffic lights the car would bog down and and
> >>> it got hot it got worse....then other times it was fine.
> >>> After changing it and having to splice it into the wiring the car
> >>> is like a whole new car.
> >>> Very very pleased.
> >>> Sent from my iPhone
> > Yahoo! Groups Links
