there an exhaust that will improve performance or does everyone just
refit the standard? The van goes well at the moment but a few more
herbs wont go astray. Thanks Chris.
> Will have to change the exhaust in the near future on my 90syncro.Is
Chris…If your looking for a “few more Herbs”…(As a lot of Syncro Owners are!) I have just recently installed High Compression Pistons, Vanagon Chip, Modified Snorkel/Air intake, K&N Air Filter..and am pleasantly surprised with the results. This was not such a costly exercise…infact, Parts came to approx $880.00 plus Labour. I tried the Ratio Rockers with this combination…but didn’t like them…and subsequently went back to originals…and I felt a lot more comfortable with that.
From my understanding , adding the High Comp’ Pistons, basically turns a M.V motor to a D.J apart from a different type of Injection System.
The above modifications…after about 4000kms are working very well. I'm able to remain in 4th gear…where before I would have to go to 3rd…on familiar ground. The next modification I will attempt will be to change the ratios of 3rd and 4th gears to reduce the RPM’s at speed.….I feel that a fair bit of home work will have to be done in this area before I order from the Albins Gear Shop!!...but that’s down the track a bit. Oh I also had an Exhaust Guru here in Perth make me a Stainless Exhaust..(Muffler only)…which adds a bit of a boxer note to the package…but I cant say that it added any improvement at all. In the US you can buy extractors for the 2.1…pipes and muffler package.. www.volkscafe.com
Ken Tyler.. Perth ..WA
-----Original
Message-----
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of southervan
Sent:
Monday, 30
May 2005
7:41 AM
Exhaust
exhaust in the near future on my 90 syncro.Is
does everyone just
Thanks Chris.
> Chris.If your looking for a "few more Herbs".(As a lot of SyncroOwners
> are!) I have just recently installed High Compression Pistons,Vanagon
> Chip, Modified Snorkel/Air intake, K&N Air Filter..and ampleasantly
> surprised with the results. This was not such a costlyexercise.infact,
> Parts came to approx $880.00 plus Labour. I tried the RatioRockers
> with this combination.but didn't like them.and subsequently wentback to
> originals.and I felt a lot more comfortable with that.turns a
> From my understanding , adding the High Comp' Pistons, basically
> M.V motor to a D.J apart from a different type of InjectionSystem.
> The above modifications.after about 4000kms are working very well.I'm
> able to remain in 4th gear.where before I would have to go to3rd.on
> familiar ground. The next modification I will attempt will be tochange
> the ratios of 3rd and 4th gears to reduce the RPM's at speed...Ifeel
> that a fair bit of home work will have to be done in this areabefore I
> order from the Albins Gear Shop!!...but that's down the track abit.
> Oh I also had an Exhaust Guru here in Perth make me a Stainlessthe US
> Exhaust..(Muffler only).which adds a bit of a boxer note to the
> package.but I cant say that it added any improvement at all. In
> you can buy extractors for the 2.1.pipes and muffler package..southervan
> www.volkscafe.com <http://www.volkscafe.com/>
> Regards
> -----Original Message-----
> Sent: Monday, 30 May 2005 7:41 AMsyncro.Is
> Subject: [Syncro_T3_Australia] Exhaust
> there an exhaust that will improve performance or does everyonejust
> refit the standard? The van goes well at the moment but a few moresubject=Unsubscr
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> <mailto:Syncro_T3_Australia-unsubscribe@yahoogroups.com?
> ibe>of
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms
> Service <http://docs.yahoo.com/info/terms/> .
> Regards
> ibe>of
>Why not use the Volkswagen system? Much cheaper and it's worked on mine
> I am about to fit a Piranha dual battery management system. If you
> want more details, ring me.
>>>kct@iinet.net.au 05/31/05 12:44 pm >>>
Will have to change the exhaust in the near future on my 90 syncro.Is
