Yes, believe it or not.
> Washing a paper filter???
> --- On Thu, 14/4/11, plander@optusnet.com.au <plander@optusnet.com.au>
> wrote:
> From: plander@optusnet.com.au <plander@optusnet.com.au>
> Subject: Re: RE: [Syncro_T3_Australia] Fixing Mechanics Fixes
> Received: Thursday, 14 April, 2011, 9:49 AM
> Thanks Ken, I've often wondered if the filters were washable as are the
> Donaldsons.
> I have a s/h one that I can try it on.
> > Ken Garratt <unclekenz@hotmail.com> wrote:
> > Phill,
> > Goto:
> http://cgi.ebay.com/ebaymotors/Heavy-Duty-Air-Filter-Vanagon-VW-part-025-
> > 129-620B-/330467378893#ht_500wt_1182
> > Goto:
> http://cgi.ebay.at/VW-TRANSPORTER-3-Bus-Kasten-MANN-LUFTFILTER-/310301791
> > 669?pt=Autoteile_Zubeh%C3%B6r&hash=item483f6d95b5
> > I've mentioned this before here but the filtering material in the
> > 025129620B oval filter looks much the same as the filtering material
> in
> > a re-washable Donaldson brand air filter that was already installed in
> > my T2 kombi 2 cab ute back in 1980. It's still there. It came with a
> tin
> > of Donaldson "Concentrated Washing Compound For Air Filter Elements".
> > Pretty simple, add 2 tablespoons of the compound (powder) to a bucket
> of
> > warm water, dunk the filter in, leave it to soak for less than 24
> hours,
> > swill it about occasionally then rinse it in clean water and leave it
> > out in the sun to dry. Then reinstall for another 20000klms or
> whatever
> > takes your fancy.I say this because I've already tried
> washing/cleaning
> > the 025129620B oval filter using the same donaldson washing
> > powder/bucket of warm water procedure.
> > Seems to me to be ok, can't see any change in performance, these oval
> > filters are heavy duty and I'd be thinking twice about throwing them
> > away after a single use.
> > Cheers.
> > Date: Tue, 12 Apr 2011 21:20:16 +0000
> > Subject: [Syncro_T3_Australia] Fixing Mechanics Fixes
> > I spent yesterday repairing some of the fixes that some previous
> > Melbourne mechanics had done to the Doka.
> > Oil cooler seal was leaking and found that a previous mechanic had
> just
> > used a filter seal.
> > Need to replace some water hoses as a previous mechanic had fitted
> fuel
> > hose instead.
> > Replaced air filter element with correct type. 025 129 620B The
> correct
> > element is getting hard to source. It may be worth stocking up with
> > spares,
> > I now need to find an air filter pre-filter which was removed by gas
> > conversion mechanic.
> > Does anyone have a spare for sale?
> > Phill
