Front Bearing Housing Removal
Has anyone here removeved the front wheel bearing housing complete with the CV attached?
It is impossible, as you can't remove the lower ball joint without
removing the CV...
Martin Henning, DM5OY
martin@easy2design.de
http://log.tigerbus.de
The Bentley is very hard to understand, but it appears that you can only do this on early models. Bentley does not mention the later ones. I wonder if I can cut part of the body of the CV to give enough clearance to get the bearing housing off the ball joint? ........either that or sell the thing.
> removing the CV...
> > Yahoo! Groups Links
Phill! You wouldn't sell your Syncro surely?
> removing the CV...
> > Yahoo! Groups Links
It's getting close. This is causing me grief.
> only do
> wonder if I
> thing.
> > > Martin Henning <martin@easy2design.de <martin%40easy2design.de>>
> > > removing the CV...
> > > > Yahoo! Groups Links
Phil,
Persevere with removing the CV before doing anything drastic. You no doubt tried many techniques however using a good heavy puller is  the proper solution.  The attached photo is a simulation as the bearing housing has been removed however it does show the type of puller I used.  The usual preparation is soaking the splines with penetration oil and then when screwing up the puller to a high tension, a good impact with a hammer on the head of the screw creates radial shock that can loosen the seized splines. You may need to repeat this several times.
Wishing you success.
Yurik
Sent: Thursday, 3 September 2009 5:30 AM
Subject: Re: Re: [Syncro_T3_Australia] Front Bearing Housing Removal
> removing the CV...
> > Yahoo! Groups Links
