Scott,the clicking was not there one day and the next day I heard it.Almost
gave me a heart attack!I thought at first it was final drive.Just
recently,after I fitted my decoupler my VC has become aggresive.Previously,I
did 90% of the year driving with tailshaft dropped.When the tailshaft was
installed I could do these tight turns without a CV issue.
Did you have any
problems getting the shaft out of the hubs?Did you do inners and outers?How
much did it cost?
--- In Syncro_T3_Australia@yahoogroups.com,
"Mr Scott Pitcher" <spbconsulting@...> wrote:
Ben,
> My front CV's clicked before I replaced them with new
ones. The height of my syncro causes increased wear on my CV's front a rear
but the new ones have done about 25,000kms with no complaints to date - touch
wood.
> Get some new front CV's!
> Scott
> From: bencroft96
> Sent: Monday, May 31, 2010 12:39 PM
> Subject:
[Syncro_T3_Australia] Re: Front diff mounts
Had a good look at the mounts today.Whilst on the hoist,I could easily move
the F/diff and there was a metalliac tap noise whist moving the diff by
hand(up and down).There was also movement side to side.
> I found that
the locator,plastic??spacers,between mouled rubber bushes were not located.I
put them back together properly and tightened the bolts.The diff was much more
solid,no metallic tap,but still apears to be moving around.
> The rubber
moulded bushes appeared'squashed',and was soft to push the metal insert in the
middle.I will replace them when I get some.
> I have been trying to
diagnose a very slight vibration and are ruling out possibilities before I
replace my unis.I will not do the unis before I know the diff is not moving
around.
> I believe that I have now inherited a new Syncro fun job.My
front CVs are clicking whilst I pull into my driveway.I know I should avoid
tight turns.They also click in the sand as well on tight turns,I went out Boat
Harbour today to test this.
> Has anyone else experience this?
"bencroft96" <bencroft96@> wrote:
Ken,thankyou.If I get a second set you could do yours while you are doing
mine.Your a good bloke.Did you say you would do it for a case of beer?
Ken Garratt <unclekenz@> wrote:
> > > Ben,
> > > See the attached pdf ETKA sketch and parts
list.
> > > The front diff uses 6 (3 pair) of
these mounts ... called "bonded rubber mounting". ETKA position 6. Part no.
183 199 381 A
> > > To see a pic, goto: http://www.worldimpex.com/parts/genuine-part-rubber-mounting_5878.html
> > > To see a price, goto: http://www.vwdiscountparts.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=214028
> > > To see about using Phills usual enquiry/buy
suggestion, goto: yourphone@homeandtelephonelocalvagoutlet
> > > To see me fit them for you while you relax over a beer,
goto: http://www.youvegotbuckleys.com.au
> > > Did I miss
something?
> > Cheers.
> > > Ken
> > From: bencroft96@
> > > Date: Fri, 28 May 2010 11:47:54
+0000
> > > Subject: FW: [Syncro_T3_Australia] Re: Front diff
mounts
> > > Ken,can I still buy replacement
rubber mounts.Do you think there is a better option,like urethane etc.If they
are available surely better.
> > > Does anyone know where I should
be looking?
"Ken Garratt " <unclekenz@> wrote:
> > Ben,
> > > > Deterioration of either/and/or
front/rear drivetrain rubber mounts and perceived consequential effects has
been the subject of debate on the US Syncro forum in the past.
> > > > Of note is the claim that deteriorated
rubber mounts cause/contribute to the drivetrain vibration issue.
> > > > I vaguely recall also a suggestion at the
time that it was worth a try turning the rubber mounts upside down. Obviously
better still, R&R with new.
> > > > Cheers.
> > > > -----Original
Message-----
> > > > From: bencroft96
<bencroft96@>
> > > > Sent: Thursday, 27 May 2010 10:06
PM
> > > Subject: [Syncro_T3_Australia] Re: Front diff mounts
> > > > Scott,Hart,Ken
and group.The movement I am talking about is up and down.I need dry daylight
time to investigate futher.I can "bench press'' action my f/diff @ the
tailshaft end and get some up and down movement.Whilst the tailshaft is
dropped,the front diff moves like a cock in a...When looking at the front diff
mounts there is a gap between the washer and the rubber mount.The nuts are
tight.Has anyone experienced the mounts squashing over time.
> > > > Scott and group.I would deem the movement excessive.Just
wondering if a few of you could try and see how much their diff moves.I didnt
discover this until yesterday.
"Mr Scott Pitcher" <spbconsulting@> wrote:
> > > > > > Never tried it but I would say there
would be a bit of give in the mounts as with all mount points on a
drivetrain.
I noted how much a 75 model 2L engine moves between gear changes. Almost
looked like half a foot in play.
> > > > > > From: bencroft96
> > > > > Sent: Monday, May 24, 2010 6:02 PM
> > > Subject: [Syncro_T3_Australia] Front diff mounts
> > > > > > All,
> Has anyone ever,grabbed hold of the nose of the front diff,and pushed and
pulled on it.
> > > > > > I have dicovered that when I do
this,I can move the diff on its mounts.The rubber mounts seem fine and the
bolts are tight.
> > > > > > Does anyone else experience
this,or know what I am telling you about?
__________________________________________________________
Need a new place to live? Find it on Domain.com.au
> > > http://clk.atdmt.com/NMN/go/157631292/direct/01/
