Front diff
Hi All / Greg,
Has anybody taken the front g/box / diff out ?? Any tips what to remove ? Can't find any
mention in Bentleys. Like to replace bearings as it starts to make a noise once decoupler is engaged.
Hartmut
Sent from my iPad
Hart,
I will dob Ben in here - he has pulled most of his van apart now and I remember him having troubles with the front diff mounts.
He would be a good starting point.
Dont forget to disconnect your speedo cable!
On 19/06/2013 1:04 PM, Hartmut Kiehn wrote:
Hi All / Greg,
Hartmut
Sent from my iPad
Hi Hartmut,
No idea re your query but Rudi R&R'd mine in 2007 and he appreciated that I'd already placed alignment marks on all mating mount surfaces to do with the front diff using white enamel paint. This made the accurate re-positioning on install simpler.
Date: Wed, 19 Jun 2013 13:04:16 +1000
Subject: [Syncro_T3_Australia] Front diff
Hi All / Greg,
Hartmut
Sent from my iPad
Hartmate,havent pulled it right out but,what are you stuck with?
BenC
--- In Syncro_T3_Australia@yahoogroups.com, Mr Scott Pitcher <spbconsulting@...> wrote:
> Hart,
> Skot
> > Hi All / Greg,
> > Hartmut
> > Sent from my iPad
Give your car a good wash up front underneath before u start.
Jack front of car up and place on stands.
Get some crc onto all nuts that will be removed.
Remove tail shaft  protection bars and tail shaft/ carefull with the tailshaft bolts not to round them off.
Undo front inner cvs and cover and tie up away.
Loosed fill and drainpugs before completely undoing.
Remove front diff front centre bolt.
Remove rear bolts and cross brace of front diff.
Push diff forward and tail shaft will drop down.
Remove speedo.
Remove breather.
Remove front diff rear wards.
Qed
Sent from my iPhone
On 19/06/2013, at 1:57 PM, Ken Garratt <unclekenz@hotmail.com> wrote:
Hi Hartmut,
Hi All / Greg,
Hartmut
Sent from my iPad
Hi Guys,  thank you all for your words of wisdom, encouragment, tips, and guidance, and also Hamish for the correct sequence of events to release the box from the vehicle. Will keep you informed what had to be done to it.
Hartmut
On 19/06/2013, at 1:04 PM, Hartmut Kiehn wrote:
Hi All / Greg,
Hartmut
Sent from my iPad
Hi Hart, Sorry your having troubles, not bad for 400,000kms though! Did the noise change as you got on and off the throttle? Are you sending the whole unit out for reco? Greg E
Sent: Thursday, 20 June 2013 6:18 PM
Subject: Re: [Syncro_T3_Australia] Front diff
Hartmut
Hi All / Greg,
Hartmut
Sent from my iPad
Hi Greg
Noticed an ever so little whining noise when engaging the front and know from  experience that the damage is only half as bad if attended to straight way .
Also pull the gearbox out to have plumbing for cooling installed. And to top it off, sending the Wbx for a complete rebuild . (no,didn't win the lotto ) Hartmut
Sent from my WalkingStick!
Hartmut
Hi All / Greg,
Hartmut
Sent from my iPad
