Hi,
Question 1:
How do I get the anti-roll bar support link and bush off of the bar?
Question 2:
In my Haynes manual (which admittedly does not consider the Syncro), the upper wishbone
bushes are spot welded the the wishbone. This is not mentioned in my Bentley manual.
I am replacing mine and before I press attempt to get the bushes out, I'd like to know if this
is this the case on our Syncros?
All items are removed from the vehicle.
Andy.
              Thanks for everyone's replies.
Yurik I need to get hold of a puller to remove the CV joints from the axles so will try it on the
stabiliser as well.
Andy.
PS. I can't see the image. Is there a setting I need to change in my account?
              Yurik,
The puller worked well - thanks.
How did you get the same bushes back over the widened end of the anti roll bar?
Andy.
              Todays update!
I had to pay mechanics to:
a) fit the stabiliser link over the new anti roll bar bush and;
b) remove the old upper control arm bushes and fit the new ones.
I have got one lower control arm off but on the other, the nut will
not budge with about a nut and a half of thread left to go. Time for a
nut splitter. That's what ya get for driving a bus that spent over a
decade on salted roads!
Andy.
