I am wondering if anyone has had the experience of the fuel filler breather hose leaking? And if so how I would go about replacing it.
It has developed a small hole where a cable tie holds it in place just under the wheel arch..many years of rubbing I'm guessing. It wont leak as long as I don't fill right up, but as soon as I do it weeps out of the small hole.
I have removed the plastic surround around the filler cap but I am unable to work out where/how it then travels to then come out of the body at the rear of the wheel arch..
Can I just cut and join it (safely) under the wheel arch or do I need to replace the whole hose?? Keeping in mind that It is just a breather hose..
Anyway, any thoughts regarding this will be greatly appreciated.
Cheers Tony
Cheers Tony
