It could be last 10+ yrs for the original vw filter. Most of the problem come from the hose fuel line, not from the filter or the fuel. The hose degrades by time and can clod the filter. Check them carefully.
Sent from Hanniboon BlackBerry® by dtac.
Date: Wed, 16 Feb 2011 22:58:05 -0000
Subject: [Syncro_T3_Australia] Fuel filter?
The van mysteriously ground to a halt yesterday. I disconnected the fuel filter and blew it out, and disconnected another filter... a carbon one? Carbon granules trickled out of the base of the filter (through the inlet/outlet pipe) when I shook it. Should this happen?
I also found that the piece of moulded black plastic on the side of the distributor body, which holds three tiny wires, was broken and so hanging off a bit (the wires still connected) I put it back in place as best as I could and the van drives fine now.
Questions.... does the fuel filter need changing often... its impossible to see how dirty it is? Does the carbon filter need changing?
Where can a get a black plastic 'thingy' for the distributor body?
And if I put new gowesty springs and OME shocks on the van (the shocks have to be replaced anyway) do I need to replace the CV"s? Its a heavy camper.
Thanks to all
Nick
