For those that have fitted the tanks from SA recently, do any of you have the middle row seats? I just put the tank in position to prepare for fitting and thought the mounting brackets were the wrong size.
The tank however does not sit hard up against the floor. There are 4 bolts/nuts for mounting the middle row seat that the tank sits against instead of the floor.
How have you worked around this?
Ideally there would be 4 notches in the tank where the nuts are, but will be a big job to do that now.
