Fuses, Hall Sender, Dual Battery
Blank
I hope the following is of interest in relation to recent posts.
Attached Fuses_HallSender.pdf lists fuses and relays layout, and connections for Hall sender.  This is taken from Hayes (2WD) Transporter manual (#3452) but matches Syncro instruction manual.
I have an ED5 Exide Endurance deep cycle battery (550CCA) fitted behind passenger seat.  While this battery fits the plan area of the battery tray well (303x173mm²), its height (@ 222mm) does reduce rearward passenger seat travel.  This battery cost $128 as of Feb 05.  Further info on Exide batteries @ http://www.exide.com.au/products/specifications.php.
Graham P.
