Phil do you already access this site? Any of these experiences/solutions of any help for your imbalance problem. I can understand the frustration particularly at such a low mileage but am sure you will successfully persevere. Don't they say " If at first you don't succeed then perhaps sky diving is not for you"
Good luck.
Melbourne
----- Forwarded Message -----
From: "Syncro@yahoogroups.com" <Syncro@yahoogroups.com>
To: Syncro@yahoogroups.com
Sent: Thursday, 9 August 2012 9:45 PM
Subject: [Syncro] Digest Number 5615
4 New Messages
Digest #5615
Messages
Wed Aug 8, 2012 9:39 am (PDT) . Posted by:
"Richard A Jones" rjones1942
> My Syncro still experiencing a vibration around 45 mph even though I have removed the propeller shaft.I had vibration problems once and removing the prop shaft didn't cure
everything. We found an outer front CV that was very stiff. It wasn't
apparent until the axle was removed. I think it was making the front
diff strain in the mounts and putting vibes into the van, if that makes
sense. Anyway, new axles made the ride smooth.
Wed Aug 8, 2012 1:12 pm (PDT) . Posted by:
"Dan Goade" dgoade2
All:
I feel the vibration in the seat and the steering wheel. The best ways I can describe the vibration is that it is like the "Magic Fingers" in cheap motel rooms, or an out of balance fan. It is not the radiator fan nor is it the heater fan.
I have confirmed that all four axels are not rubbing on anything. I also verified that I did not leave a bolt in the transaxle or front differential after I removed the driveshaft.
Is there anyone in the Knoxville, Tennessee area that would like to go for a ride and help diagnose this vibration???
Regards – Dan G
1987 Syncro Westy Butter Churn
Wed Aug 8, 2012 1:35 pm (PDT) . Posted by:
"batomika" batomika
Years ago I had this same problem with a '91 tintop where I did pretty much as you have done plus more, including all new axles front and rear, new VW propshaft (they were still available) as well as shimming the front diff. to get the "proper" flange angle with no success. Dropping the propshaft did nothing in removing the "magic fingers" between 45 and 55. My VC was also aggressive and after replacing it and reassembling everything using what is now known as the "Van-Cafe" method of alignment, the problem went away. I could only assume that the VC was out of balance although I never tested to confirm this.
--- In mailto:Syncro%40yahoogroups.com, "Dan Goade" <dgoade2@... > wrote:
> All:
> Regards – Dan G
Wed Aug 8, 2012 2:31 pm (PDT) . Posted by:
"Robert Stevens" mtbiker62
Dan,
Has wheel/tire imbalance been eliminated, or bent wheel-rim?
bob
GROUP FOOTER MESSAGE
Please note that the default "Reply" function will route your reply to the entire group. If you have a private message for a member you'll need to specifically address your message to them.
If you would like to modify your subscription settings (including unsubscribing), visit:
http://groups.yahoo.com/group/Syncro
Rude or offensive language is not allowed on the Syncro list. Please try your best to resolve differences privately and keep them off the list.
