Gas Question
I've successfully just put 82 litres of LPG in the Doka. What is the usual size of the tank?
Phill they could have fitted any size tank. Some have the capacity stamped near the connections. If not you may need to do the old measuring tape and calculator jobbie. Greg E
I would expect that the capacity would be stamped on the collar.
From: Syncro_T3_Australia@yahoogroups.com [mailto: Syncro_T3_Australia@yahoogroups.com ] On Behalf Of hdvwoc
Sent: 14 May 2011 17:46
Subject: [Syncro_T3_Australia] Gas Question
I can't see any of the normal things on the tank that are in the instructions.
Gauge?
Shut off?
Information plate?
> Phill,
> [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of hdvwoc
> usual
> size of the tank?
Is it in the treasure chest? Greg E
> Gauge?
> Shut off?
> Information plate?
> > Les Harris <leslieharris@...> wrote:
> > Phill,
> > Les
> > _____
> > usual
> > size of the tank?
Sure is!
I would have thought a valve on the line to the engine was mandatory. Have you traced the line from the tank to the cut off solenoid? Greg E
> Sure is!
cut off solenoid?
> > Sure is!
> > Phill
Yeh, should be a solenoid to cut off gas when on petrol. Greg E
Sent: Saturday, 14 May 2011 9:20 PM
Subject: Re: Re: [Syncro_T3_Australia] Gas Question
cut off solenoid?
> > Sure is!
> > Phill
