Certainly sounds like a bearing, has anyone heard or known of these symptoms before?
Most likely crownwheel and pinion.
Behalf Of Uwe
Sent: 13 July 2009 06:48
To:
Gearbox noise
Hi all, I wonder if anyone has had a similar problem
with a noise coming from the gear box. Its a loud groan while driving,
noticeable more in third and fourth gear where the engine is quieter and even
has a slight harmonic to it. The noise disappears when backing off the
accelerator and when power is applied again to the drive train it returns. When
the clutch goes in its also gone. So it only appears when the drive train is
under load.
before?
To elaborate on that, the symptoms match excessive wear in the crownwheel and pinion. This is irreversible and the noise will increase as it wears further. The only course is replacement. The Australian delivered ratio is 5.43 – which VAG no longer stocks. Fortunately, Albins are now making this ratio so we are covered.
Unless you have a lot of gearbox experience, this is a job for not just a professional transmission workshop but also one with experience with the 094 gearbox. Choose carefully.
It is highly recommended that you have all the bearings in the box changed while you are at it so that you get back to best possible condition. In any event, the metal particles that have been ground off the crownwheel (this is the noise you are hearing) circulate with the oil and go through the bearings and set them up for early failure.
Behalf Of Les_Harris
Sent: 13 July 2009 07:49
To:
Gearbox noise
[mailto:Syncro_ T3_Australia@ yahoogroups. com] On Behalf Of Uwe
Subject: [Syncro_T3_Australi a]
Gearbox noise
Hi all, I wonder
if anyone has had a similar problem with a noise coming from the gear box. Its
a loud groan while driving, noticeable more in third and fourth gear where the
engine is quieter and even has a slight harmonic to it. The noise disappears
when backing off the accelerator and when power is applied again to the drive
train it returns. When the clutch goes in its also gone. So it only appears
when the drive train is under load.
before?
On Mon, Jul 13, 2009 at 12:48 PM, Les_Harris <leslieharris@optusnet.com.au> wrote:
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Les_Harris
Subject: RE: [Syncro_T3_Australia] Gearbox noise
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Uwe
Subject: [Syncro_T3_Australia] Gearbox noiseHi all, I wonder if anyone has had a similar problem with a noise coming from the gear box. Its a loud groan while driving, noticeable more in third and fourth gear where the engine is quieter and even has a slight harmonic to it. The noise disappears when backing off the accelerator and when power is applied again to the drive train it returns. When the clutch goes in its also gone. So it only appears when the drive train is under load.
Looks like the gearbox needs to come out and and get looked at. I'm in Melbourne also and I would love to know where you had it fixed Francesca. Going through the archives I remember reading Les had a similar problem, where did you get it fixed Les. Thanks to Hartmut also, I could read the reply in German but I guess our locations make the difference in terms of getting it fixed.
A little background on me, I joined the list almost 12 months ago after buying my Syncro, an ex-telstra with broken headstud. I've been reading all the posts but haven't had to be more active than that while the car is a still a project, I'm working on an engine transplant and body cleanup before it makes its debut. My daily car is an 85 Caravelle.
But my brother was inspired with the syncro and finally found one recently, also ex-telstra and its now a camper, unfortunately it has the gearbox problem
Any help on where to go and maybe a ball park cost would be greatly appreciated.
Regards, Uwe
Francesca Coles wrote:
Hi there,
We went through the crownwheel and pinion/gearbox rebuild just recently, so I sympathise with your predicament. >From your description the noise in your gearbox matches the symptoms our syncro displayed exactly. If our experience could be of help (though we are in Melbourne), drop me a line and I can let you know how we dealt with it. It's whisper quiet and sweet-changing now - long may it last!
Francesca.
On Mon, Jul 13, 2009 at 12:48 PM, Les_Harris <leslieharris@ optusnet. com.au> wrote:
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_T3_Australia @yahoogroups. com] On Behalf Of Les_Harris
Subject: RE: [Syncro_T3_Australi a] Gearbox noise
From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_T3_Australia @yahoogroups. com] On Behalf Of Uwe
Subject: [Syncro_T3_Australi a] Gearbox noiseHi all, I wonder if anyone has had a similar problem with a noise coming from the gear box. Its a loud groan while driving, noticeable more in third and fourth gear where the engine is quieter and even has a slight harmonic to it. The noise disappears when backing off the accelerator and when power is applied again to the drive train it returns. When the clutch goes in its also gone. So it only appears when the drive train is under load.
Uwe,
If you live north of the Yarra, speak to Volkwerke in Greensborough, If you live south of the Yarra, speak to Volkspower in Burwood.
Behalf Of 911Jack
Sent: 13 July 2009 19:23
To:
Gearbox noise
Hi and
thanks for the replies Les, Hartmut and Francesca
appreciated.
Regards, Uwe
Hi there,
We went through the crownwheel and pinion/gearbox rebuild just recently, so I sympathise with your predicament. >From your description the noise in your gearbox matches the symptoms our syncro displayed exactly. If our experience could be of help (though we are in Melbourne ), drop me a line and I can let you know how we dealt with it. It's whisper quiet and sweet-changing now - long may it last!
Francesca.
Sent: 13 July 2009 07:49Subject: RE: [Syncro_T3_Australi a] Gearbox noise
On Mon, Jul 13, 2009 at 7:23 PM, 911Jack <911jack@gmail.com> wrote:
Hi and thanks for the replies Les, Hartmut and Francesca
Regards, Uwe
Francesca Coles wrote:Hi there,
Francesca.
Hi there, We had ours reconditioned
by Lloyd Davies at Volkwerke in Greensborough. It was Brian Reed (a member of
this list) who recommended Lloyd. He had his syncro transaxle overhauled by
Lloyd about 10 years ago, and to the best of his knowledge it's still going
strong (he sold the vehicle a while ago). Lloyd has had lots of experience with
VW transaxle rebuilds and syncros, and owns and drives T3s. I found him
very good to deal with and he gave us a 12-month warranty on the work, so long
as we either removed the tailshaft or put in a decoupler (or, presumably, a new
viscous coupling - something he didn't recommend). It's worth bearing in mind,
incidentally, that it's more than likely an aggressive viscous coupling, past
its use-by date, that has wrecked your transaxle. Lloyd was happy to take
on the job, so long as I took on the task of sourcing the crownwheel and
pinion. I located an OEM one with the correct ratio at the Syncro Hopsital in
South Africa and had it shipped here, but I'm pretty sure it was their last
remaining one (might be worth checking). Unfortunately, the total cost for that
was just over $2K. As Les has pointed out, you can also get new ones from
Albins in Ballarat for slightly less ($1600 or so). There are several days of
labour involved plus sundry other parts, so you can probably get the picture
that the final bill was rather large (I hesitate to say exactly how much!). Oh, Lloyd also managed to
locate a pair of factory-recondition ed syncro transaxles in Germany, but
that would have worked out more expensive again. They might still be there if
anyone's desperate... .. Other than that, there's a guy called Rudi
Purkhart on Bribie Island who apparently meticulously reconditions syncro
transaxles (among other things), but it will cost $$$$$$. There's also a guy
called Aidan Talbot in the UK who rebuilds syncro transaxles, but that's
probably too logistically and financially challenging from here. Anyway, good luck and I
hope you get over this hurdle to enjoy your uniquely satisfying vehicle. We
have grown to love ours! Francesca. On Mon, Jul 13, 2009 at
7:23 PM, 911Jack <911jack@gmail. com>
wrote: Hi and thanks for the
replies Les, Hartmut and Francesca Hi there, We went through the
dealt with it. It's whisper quiet and sweet-changing now - long may it last! Cheers, Francesca. On Mon, Jul 13, 2009 at
12:48 PM, Les_Harris <leslieharris@ optusnet. com.au> wrote: To
now making this ratio so we are covered. Unless
Choose carefully. It is
and set them up for early failure. Les From:
On Behalf Of Les_Harris Subject: RE:
[Syncro_T3_Australi a] Gearbox noise Most
likely crownwheel and pinion. Les From:
On Behalf Of Uwe Hi all, I wonder if
fixed.
appreciated.
Regards, Uwe
Gearbox noise
before?
Hi all fellow syncro owners rang albins today they have all sold out of C/P they have an agent selling them ??--- On Mon, 13/7/09, Francesca Coles <fcoles6@gmail.com> wrote: |
Access Yahoo!7 Mail on your mobile. Anytime. Anywhere. Show me how.
Albins manufacture primarily for the US market and there is only one distributor outside of Australia . Everyone in the world except Australia has to buy through this one distributor. Inside Australia , Tooleys handle local distribution. If Tooleys don’t have any in stock, then there aren’t any available.
We have an established relationship with Albins whereby the members of this group can buy direct. This is not a commercial arrangement. It is an arrangement whereby we can keep our Syncros on the road in Australia . If I ever find that anyone is trying to buy commercial quantities under this arrangement, it will be stopped instantly.
Les Harris
Syncro_T3_Australia
On Behalf Of bettaitems
Sent: 14 July 2009 16:13
Gearbox noise
Hi all
Sent: Tuesday, 14 July, 2009 4:26:15 PM
Les Harris
Syncro_T3_Australia
From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of bettaitems
Subject: Re: [Syncro_T3_Australi a] Gearbox noise
Great news they have an agent in melbourne and there are only a couple of sets left and albins will not produce any more when l rang them because of the high production costs unless you order and prepay for 20 sets to be made ..--- On Tue, 14/7/09, hamish dobson <dobson_hamish@yahoo.com.au> wrote: |
I'm in contact with and acting on behalf of the agent for the ring and pinions, anyone interested purchasing a 5.34 R&P set can contact me via e-mail.
Also other Syncro specific NLA items may be in stock, for example, front to rear water pipes and water junction box.
Some second hand Syncro parts available.
regards,
Steve.
Yarra Junction, Victoria.
> --- On Tue, 14/7/09, hamish dobson <dobson_hamish@...> wrote:
> From: hamish dobson <dobson_hamish@...>
> Subject: Re: [Syncro_T3_Australia] Gearbox noise
> Received: Tuesday, 14 July, 2009, 8:42 PM
> FYI - Albins sell direct (to private persons)Â regardless of any group.
> From: Les_Harris <leslieharris@ optusnet. com.au>
> Albins manufacture primarily for the US market and there is only one distributor outside of Australia . Everyone in the world except Australia has to buy through this one distributor. Inside Australia , Tooleys handle local distribution. If Tooleys donât have any in stock, then there arenât any available.
> Â
> Â
> Les Harris
> Syncro_T3_Australia
> Â
> Â
> Â
> Â
> ____________________________________________________________________________________
> Show me how: http://au.mobile.yahoo.com/mail
Hi Steve,
What is the price on the front to rear pipes.Also what are the other second hand syncro parts.
Everard
Sent: Monday, 13 July, 2009 8:15:20 PM
Hi there, We had ours reconditioned by Lloyd Davies at Volkwerke in Greensborough. It was Brian Reed (a member of this list) who recommended Lloyd. He had his syncro transaxle overhauled by Lloyd about 10 years ago, and to the best of his knowledge it's still going strong (he sold the vehicle a while ago). Lloyd has had lots of experience with VW transaxle rebuilds and syncros, and owns and drives T3s. I found him very good to deal with and he gave us a 12-month warranty on the work, so long as we either removed the tailshaft or put in a decoupler (or, presumably, a new viscous coupling - something he didn't recommend). It's worth bearing in mind, incidentally, that it's more than likely an aggressive viscous coupling, past its use-by date, that has wrecked your transaxle. Lloyd was happy to take on the job, so long as I took on the task of sourcing the crownwheel and pinion. I located an OEM one with the correct ratio at the Syncro Hopsital in South Africa and had it shipped here, but I'm pretty sure it was their last remaining one (might be worth checking). Unfortunately, the total cost for that was just over $2K. As Les has pointed out, you can also get new ones from Albins in Ballarat for slightly less ($1600 or so). There are several days of labour involved plus sundry other parts, so you can probably get the picture that the final bill was rather large (I hesitate to say exactly how much!). Oh, Lloyd also managed to locate a pair of factory-recondition ed syncro transaxles in Germany, but that would have worked out more expensive again. They might still be there if anyone's desperate... .. Other than that, there's a guy called Rudi Purkhart on Bribie Island who apparently meticulously reconditions syncro transaxles (among other things), but it will cost $$$$$$. There's also a guy called Aidan Talbot in the UK who rebuilds syncro transaxles, but that's probably too logistically and financially challenging from here. Anyway, good luck and I hope you get over this hurdle to enjoy your uniquely satisfying vehicle. We have grown to love ours! Francesca. On Mon, Jul 13, 2009 at 7:23 PM, 911Jack <911jack@gmail. com> wrote: Hi and thanks for the replies Les, Hartmut and Francesca Hi there, We went through the crownwheel and pinion/gearbox rebuild just recently, so I sympathise with your predicament. >From your description the noise in your gearbox matches the symptoms our syncro displayed exactly. If our experience could be of help (though we are in Melbourne), drop me a line and I can let you know how we dealt with it. It's whisper quiet and sweet-changing now - long may it last! Cheers, Francesca. On Mon, Jul 13, 2009 at 12:48 PM, Les_Harris <leslieharris@ optusnet. com.au> wrote: To elaborate on that, the symptoms match excessive wear in the crownwheel and pinion. This is irreversible and the noise will increase as it wears further. The only course is replacement. The Australian delivered ratio is 5.43 – which VAG no longer stocks. Fortunately, Albins are now making this ratio so we are covered. Unless you have a lot of gearbox experience, this is a job for not just a professional transmission workshop but also one with experience with the 094 gearbox. Choose carefully. It is highly recommended that you have all the bearings in the box changed while you are at it so that you get back to best possible condition. In any event, the metal particles that have been ground off the crownwheel (this is the noise you are hearing) circulate with the oil and go through the bearings and set them up for early failure. Les From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_T3_Australia @yahoogroups. com] On Behalf Of Les_Harris Subject: RE: [Syncro_T3_Australi a] Gearbox noise Most likely crownwheel and pinion. Les From: Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_T3_Australia @yahoogroups. com] On Behalf Of Uwe Hi all, I wonder if anyone has had a similar problem with a noise coming from the gear box. Its a loud groan while driving, noticeable more in third and fourth gear where the engine is quieter and even has a slight harmonic to it. The noise disappears when backing off the accelerator and when power is applied again to the drive train it returns. When the clutch goes in its also gone. So it only appears when the drive train is under load.
Regards, Uwe
com
http://www.volkswagen-classic-parts.de/
> Phil Lee <phil.lee73@yahoo.com> wrote:
> Hi, I had a gearbox rebuild last year through the same people that Les
> used,����I had the 5.43��C&P problem. Waited��4 months while VW classic
> did a run��of��OEM 5.43��C&P's��in Germany, my understanding was that
> they��are��again available through VW Classic or Classic VW in Germany.
> Don't know how to contact them.��I was told that they are a part of VW.
> Phil
> From: stuart parry <stuart@oddball.com.au>
> Hi there,
> and syncros, and owns and drives T3s. ��I found him very good to deal
> how much!).
> Francesca.
> Looks like the gearbox needs to come out and and get looked at.�� I'm in
> Francesca.�� Going through the archives I remember reading Les had a
> similar problem, where did you get it fixed Les.�� Thanks to Hartmut
> buying my Syncro, an ex-telstra with broken headstud.�� I've been
> body cleanup before it makes its debut.�� My daily car is an 85
> Caravelle.
> gearbox problem
> appreciated.
> Regards, Uwe
> Hi there,
> in your gearbox matches the symptoms our syncro displayed exactly.��If
> Francesca.
> crownwheel and pinion.�� This is irreversible and the noise will
> increase as it wears further.�� The only course is replacement.�� The
> Australian delivered ratio is 5.43 ��� which VAG no longer stocks.��
> the 094 gearbox.�� Choose carefully.��
> condition.���� In any event, the metal particles that have been ground
> From:Syncro_T3_Australia @yahoogroups. com [mailto:Syncro_T3_Australia
> Subject:RE: [Syncro_T3_Australi a] Gearbox noise
> ��Les
> under load.
> symptoms before?
> ___________
Good to know about this site.
They specifically mention availability of Syncro gearbox parts:
| Gearbox parts for T3 syncro With immediate effect, miscellaneous gearbox parts for T3 Bus / Transporter / Vanagon syncro are available again, e.g. Article 091 311 301 B - synchronizing hub Article 091 311 145 J - gear Article 094 301 217 E - housing Article 094 311 375 - needle bearing |
On Tue, Jul 21, 2009 at 7:30 AM, <plander@optusnet.com.au> wrote:Try here
> used, I had the 5.43 C&P problem. Waited 4 months while VW classic
> did a run of OEM 5.43 C&P's in Germany, my understanding was that
> they are again available through VW Classic or Classic VW in Germany.
> Don't know how to contact them. I was told that they are a part of VW.
> Phil
> Hi there,
> how much!).
> Francesca.
> Caravelle.
> gearbox problem
> appreciated.
> Regards, Uwe
> Hi there,
> Francesca.
> under load.
> symptoms before?
> ___________
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
mailto:Syncro_T3_Australia-digest@yahoogroups.com
mailto:Syncro_T3_Australia-fullfeatured@yahoogroups.com
I have made a number of attempts to contact this site and have even had some replies to email questions. Unfortunately, the replies were to different questions to those that I had asked. The assumption appears to be that there are only German speaking owners of early Volkswagen in the world. Pity.
On Behalf Of Mark Kofahl
Sent: 21 July 2009 15:22
Subject: Re: Re:
Hi Phil
Gearbox parts for T3 syncro |
On Tue, Jul 21, 2009 at 7:30 AM, <plander@optusnet. com.au> wrote:
Sent: Tuesday, 21 July 2009 6:10 p.m.
Subject: RE: Re: [Syncro_T3_Australia] Gearbox noise
From: Syncro_T3_Australia @yahoogroups. com [mailto: Syncro_T3_Australia @yahoogroups. com ] On Behalf Of Mark Kofahl
Subject: Re: Re: [Syncro_T3_Australi a] Gearbox noise
Hi Phil
Checked by AVG - www.avg.com
Version: 8.5.392 / Virus Database: 270.13.20/2249 - Release Date: 07/20/09 06:16:00
id=4391&category_id=93&category_parent_id=
