Thanks for the great tips on an engine oil pressure gauge. Now the next issue is, has anyone installed an oil temp gauge in their gearbox? Another help in managing our vehicles.
Peter from Port
Peter from Port
On 21/09/2015, at 5:25 PM, "peter@coeconsult.com.au [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:Thanks for the great tips on an engine oil pressure gauge. Now the next issue is, has anyone installed an oil temp gauge in their gearbox? Another help in managing our vehicles.
Peter from Port
A non invasive option would be a cyl head temp gauge, it can go under a bolt or even epoxy to the case some where. Would not give an exact oil temp, but will give a good "relative" temp to monitor and is non invasive
German Supply - Parts for Volkswagen® Cars - Home
Shoptalkforums.com • View topic - cylinder head temp gauges
I have a couple of these on air cooled VW's.
With the oil cooler (engine), are they worth the effort if the cooling system is working correctly? The factory cooler should keep engine oil temps in check?
