Phill , it worked for me. Hart
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of hdvwoc
Sent: Thursday, 19 August 2010 4:57 PM
Subject: [Syncro_T3_Australia] Go Westy Pipe Repair Kit
Do these kits work?
Pipe repair Kit
I was just thinking of one to keep for emergencies.
> Do these kits work?
> Pipe repair Kit <http://www.gowesty.com/library_article.php?id=113>
Date: Thu, 19 Aug 2010 17:25:29 +1000
Subject: RE: [Syncro_T3_Australia] Go Westy Pipe Repair Kit
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of hdvwoc
Yep, would one get it some where else? Ha
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of plander@optusnet.com.au
Sent: Thursday, 19 August 2010 5:28 PM
Subject: Re: RE: [Syncro_T3_Australia] Go Westy Pipe Repair Kit
Did you get it from GoWesty?
> Hartmut Kiehn <hartis@live.com.au>wrote:
>On Behalf Of hdvwoc
> Sent: Thursday, 19 August 2010 4:57 PMhref="http://www.gowesty.com/library_article.php?id=113">http://www.gowesty.com/library_article.php?id=113>
> Do these kits work?
> Pipe repair Kit <
> Yes worked for me to. I'm unaware of any other source for this kit than
> GoWesty.
> From: hartis@live.com.au
> Do these kits work?
> Pipe repair Kit
The opponents say the stainles steel lines are the only real fix and have a long argumnet a to why the gowesty kit cannot work.
However, I have not heard a single report of someone with leaky pipes that uses the gowesty kit. and $50 is a lot cheaper than the $300 or so for the stainless, not even thinking about shipping to australia.
Only other option I know of is to just run marine exhaust hose the entire length. Works too.
BTW I have a couple decouplers sitting here ready to ship. Anyone need one right now?
Florian
> Do these kits work?
Hi Florian
Re decouplers I am interested in fitting one to our otherwise unmolested T3. A couple on novice questions exist.
Who are they manufactured by?
What is their price?
Do they carry any warranty?
Do they come with fitting instructions?
How are they actuated?
Any thing else I need to know about their instillation/use?
col
Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Florian Speier
Sent: Friday, 20 August 2010 4:01
AM
Subject: Re: RE:
These kits seem to work great. I have one installed an
no leaking ever since (3 or more years of serviceso far).
australia .
length. Works too.
right now?
Florian
5:28 PM
>target="_blank">Syncro_T3_Australia@yahoogroups.com
> From:
> [mailto:target="_blank">Syncro_T3_Australia@yahoogroups.com] On Behalf Of hdvwoc
> Sent: Thursday, 19 August 2010 4:57 PMhref="http://www.gowesty.com/library_article.php?id=113" target="_blank">http://www.gowesty.com/library_article.php?id=113>
> Do these kits work?
> Pipe repair Kit <
Thanks for the input, as with Phill, a good idea to keep this GoWesty kit in the cupboard for the inevitable "rainy" day, who knows when this kit may go NLA.
Replacement coolant pipes has been the topic of discussion here in the recent past, still with no clear outcome. You've confirmed what I had previously heard on the US syncro forum about a marine hose solution.
Just wondering then for us Oz syncro owners, can you or someone identify the definitive type/size/model of marine hose and hose end clamping solution that is already known by the US syncro community and if so, provide these details and website links about them to this Oz forum please. Then perhaps we can identify the local agent/supplier of the same or similar products here in Oz. Thanks a lot.
Date: Thu, 19 Aug 2010 12:00:56 -0600
Florian
> Do these kits work?
Col,
Several members have fitted decouplers from Florian and they appear to be satisfactory. Florian can fill in more detail.
They are vacuum actuated and use the same actuator as is used for the diff locks. If you have a diff lock already fitted, the decoupler actuator plumbs into the same system. If you don’t, you have to install the vacuum reservoir and manifold tapping. The control is added to the same sub-panel used for the diff lock. (The control “switches” are actually vacuum valves.)
On Behalf Of Col Hadley
Sent: 20 August 2010 08:55
Subject: RE: RE:
Hi Florian
col
On Behalf Of
Florian Speier
AM
Subject: Re: RE:
These
kits seem to work great. I have one installed an no leaking ever since (3 or
australia .
length. Works too.
right now?
Florian
5:28 PM
> From:
> Do these kits work?
> Pipe repair Kit <
----- Original Message -----From: Ken GarrattSent: Friday, August 20, 2010 9:54 AMSubject: RE: [Syncro_T3_Australia] Go Westy Pipe Repair KitFlorian,
These kits seem to work great. I have one installed an no leaking ever since (3 or more years of serviceso far).
Florian
> Do these kits work?
Thanks Les
Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Les Harris
Sent: Friday, 20 August 2010 10:00
AM
Subject: RE: RE:
Col,
Subject: RE: RE:
Hi Florian
col
AM
To:
Subject: Re: RE:
These
australia .
length. Works too.
right now?
Florian
5:28 PM
> From:
> Do these kits work?
> Pipe repair Kit <
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Bob Dale
Sent: Friday, 20 August 2010 2:12 p.m.
Subject: Re: [Syncro_T3_Australia] Go Westy Pipe Repair Kit
try radoflex. bob----- Original Message -----From: Ken GarrattSent: Friday, August 20, 2010 9:54 AMSubject: RE: [Syncro_T3_Australia] Go Westy Pipe Repair KitFlorian,
Florian
> Do these kits work?
Col. I successfully fitted one recently as an amateur with help from Hart so if you need a “heads up” on the process more than happy to have a chat.
Peter from Port M
Thanks Peter
Syncro_T3_Australia@yahoogroups.com ] On Behalf Of Peter Coe
Sent: Friday, 20 August 2010 1:03
PM
Subject: RE: RE:
Peter from Port M
people here buy the marine hardwall hose type whatever is on sale. the typical selection is this, but its expensive:
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=19371&catalogId=10001&langId=-1&storeId=11151&storeNum=10111&subdeptNum=10640&classNum=10641
there are sellers on us ebay for around $5/ft ($15/meter)
basically marine water / exhaust hose with wire reinforcement works. I use the thread type hoseclamps, two side by side. The wire in the hose makes them hard to compress. Also note that the exterior diameter of these hoses may be bigger than your existing tube, which would result in you having to potentially enlarge some of the areas it needs to get routed through. I have used this hose only for the engine area in my subaru conversion. Its nearly too stiff for short runs, I have one spot where I cannot fit a huge clamp on it so I sometimes have a minimal drip there. But at that spot the hose is low and exposed, and this hose is so tough that I am sure it does not get ripped while offroading. I rather have a drip than a weak hose in an exposed location.
Florian
On Thu, Aug 19, 2010 at 5:54 PM, Ken Garratt <unclekenz@hotmail.com> wrote:Florian,
Florian
> Do these kits work?
As previously posted in this Forum I am using Marine Exhaust Hose to repair my coolant pipe. After the recent discussion I checked with
the Supplier for price & availability: 38mm OD X 3 Mtr. $196. in stock. www.hishose.com.au
t 09:54 AM 20/08/2010, you wrote:
Florian,
