Headlight Dash Rocker Switch Required
Hi Skot.
Sorry, I can't log onto syncro forum as it says I don't have permission, so emailing straight to you which I hope works.
Oil pressure warning light & buzzer were randomly going off even though oil was at high mark on dipstick measured on level ground. Had relay switch replaced at mechanics last Wednesday for $350. Buzzing & light warnings happened again yesterday.  Oil still full.  Back at mechanics next Wednesday but it driving me nuts. Any suggestions for me and the mechanic please.  Thanks Skot.
Cheers, Jim Roger.
Sent from BlueMail
On 2 Apr 2017, at 20:12, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Jim,
If you need window winder mechanisms I know a bloke or two near me that has them (factory ones).
On 2/04/2017 6:28 PM, jim jkr100@hotmail.com [Syncro_T3_Australia] wrote:
Thanks Skott.
I broke 2 jk T2 drivers door window winder regulators in 2 weeks having to have the 3rd  brazed to equal the original.   That part was a mess yet my T2 door handle is good. Yes, will see how the quality is as you say.  I really appreciate the offer of your German spare.
Thanks again
Cheers. Jim
Sent from BlueMail
On 24 Mar 2017, at 15:20, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
I lot of JK stuff is good quality.
I'm sure it will work.
If it fails you have a warranty implied for 12 months or I still have my original factory spare.
On 24/03/2017 2:40 PM, jim jkr100@hotmail.com [Syncro_T3_Australia] wrote:
Hi Skot. Thank you.  I am getting  one from Justkampers Auburn as I really need it now.  I think it will probably be junk, so would like to hear your op ed  about quality please, as I guess yours would be quality German?   Thanks again. Cheers Jim
On 24 Mar 2017 1:54 pm, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Jim,
My switch was from an 89 model too so it should be the same.
I will check it if I can find it my box of T3spare goodies.
On 24/03/2017 11:49 AM, jim jkr100@hotmail.com [Syncro_T3_Australia] wrote:
Hi Skot.
Thanks again for the offer.  I have checked and it is an 8-pin switch.
Cheers.  Jim.
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of jim jkr100@hotmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>
Sent: Wednesday, 22 March 2017 6:13 AM
To: Scott; Syncro_T3_Australia
Subject: Re: [Syncro_T3_Australia] Headlight Dash Rocker Switch Required
Hi Scott. Thanks for the kind offer. I will look and see if it is an 8 or 10 pin switch.  Cheers. Jim
On 22 Mar 2017 4:31 pm, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Jim,
I have a spare headlight switch as I bought one thinking it might be my problem for my high beam issues.
Turns out it wasn't.
I can dig it up if you are keen. It has lost a lot of the white headlight decal ink but it works.
On 22/03/2017 4:07 PM, Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia] wrote:
Hi Jim,
So apparently there are early and late model switches, one different t'other .....
http://www.gowesty.com/search-results.php?search_phrase=headlight+switch
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of jkr100@hotmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>
Sent: Wednesday, 22 March 2017 3:42 PM
Subject: [Syncro_T3_Australia] Headlight Dash Rocker Switch Required
Hello to All.
I need a  replacement rocker headlight dash switch for my 1989 van.
Tooley Import are out of stock and Volkshome do not have any.
Can anyone suggest another source please?
Thanks.  Jim.  Sydney.
Hi Roger,
This seems to be coming through from the forum email system via Yahoo so hopefully others see it.
Where are you based?
The oil pressure lights and buzzers come from the two oil pressure switches - one near the front crank pulley/ water pump and one under the passenger side push rods. Either could fail or a wire may have melted through. See the brown wire in the photo on the front LHS of the engine.
On 3/05/2017 11:39 AM, jim jkr100@hotmail.com [Syncro_T3_Australia] wrote:
Hi Skot.
Cheers, Jim Roger.
Sent from BlueMail
Jim,
Thanks Skott.
Thanks again
Cheers. Jim
Sent from BlueMail
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
Hello to All.
Hi Skot.
Thanks, seems I'm not a member any more according to yahoo.
I am in north shore of Sydney.
Mechanic changed only one module so probably the other needs check/replacement. Will look into that. Thanks again.
Cheers, Jim.
Sent from BlueMail
On 3 May 2017, at 12:30, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Roger,
Hi Skot.
Cheers, Jim Roger.
Sent from BlueMail
On 2 Apr 2017, at 20:12, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" < Syncro_T3_Australia@yahoogroups.com> wrote:
Jim,
Thanks Skott.
Thanks again
Cheers. Jim
Sent from BlueMail
On 24 Mar 2017, at 15:20, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" < Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Jim,
Hi Skot.
Cheers.  Jim.
Jim,
Hi Jim,
Hello to All.
Hi Jim,
Its hard now with Les not with us anymore to get back on the forum.
Not sure how to fix that?
Who is your mechanic?
On 3/05/2017 2:52 PM, jim jkr100@hotmail.com [Syncro_T3_Australia] wrote:
Hi Skot.
Cheers, Jim.
Sent from BlueMail
Hi Roger,
Hi Skot.
Cheers, Jim Roger.
Sent from BlueMail
Jim,
Thanks Skott.
Thanks again
Cheers. Jim
Sent from BlueMail
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
Hello to All.
Hi Skot.
Will get around it somehow.
Mechanic was Reliable Automotive in Artarmon.  Do old and new VW's as well as any others.  Honourable people.
Cheers. Jim.
send from HOMTOM-HT6
On 3 May 2017 14:59, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Jim,
Hi Skot.
Cheers, Jim.
Sent from BlueMail
Hi Roger,
Hi Skot.
Cheers, Jim Roger.
Sent from BlueMail
Jim,
Thanks Skott.
Thanks again
Cheers. Jim
Sent from BlueMail
Hi Jim,
Hi Skot.
Cheers.  Jim.
Jim,
Hi Jim,
Hello to All.
There is that Mackellar Automotive in Brookvale.
They have a good reputation.
Or Wolfsburg Motors in St Peters
Ph: 9519 4524
On 3/05/2017 3:07 PM, jim jkr100@hotmail.com [Syncro_T3_Australia] wrote:
Hi Skot.
Cheers. Jim.
Hi Jim,
Hi Skot.
Cheers, Jim.
Sent from BlueMail
Hi Roger,
Hi Skot.
Cheers, Jim Roger.
Sent from BlueMail
Jim,
Thanks Skott.
Thanks again
Cheers. Jim
Sent from BlueMail
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
Hello to All.
Hi Ken.  Not sure if I replied to you, so I would like to say thank you for the help and info.
It was/is very much appreciated.  Cheers.  Jim.
On 17/04/17 23:27, Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia] wrote:
Hi Jim,
A 750 CCA starting battery (DIN66) will fit and clearance under the drivers seat but only if the seat is raised because a captains chair metal swivel base is in place. Without a swivel base, then you need to stay with the usual DIN65 sized battery.
From: "jim jkr100@hotmail.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com>
Date: 16/04/2017 8:29 PM (GMT+10:00)
Hi Richard.  Thanks so much for the very helpful reply. Was looking at 550CCA but I like the idea of a 750CCA starter battery.  Loojing to get a deep cycle this time for the auxillary.
Thanks again.  Cheers. Jim.
Sent from BlueMail
On 10 Apr 2017, at 22:57, "cathrich1@yahoo.com.au [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Jim, not so sure on the best battery to get and what style for the house battery, but just had to replace the battery in my 2WD bus. The battery that fits is spec DIN65L MF (picture below from page Ken linked to)
This one lists 750CCA, but 580-600CCA (rating for a starting battery) is typical for this size battery. Size is 278L/175W/175H and has the terminals below the top, and ridge at the bottom to clamp on as in the picture.
One thing I would recommend, this type of battery often comes with a plastic cover that sits over the +ve terminal. Well worth it when a metal cover sits over the top!!
http://www.batteryvalue.com.au/Banner70.JPG
I have the battery out of the Golf in the Syncro for a while with no issue, basically the same battery, just shorter, spec was DIN53L MF and 550CCA.
It's usually recommended to have a deep cycle battery for the house battery, but unless you drain it a long way regularly, I have not had issues using a starting battery in the past.
No problem. Glad it helped.
For safety and convenience, be sure to fit one of these too on the negative pole of the battery:
http://www.ebay.com.au/itm/Car-Motorcycle-Cut-off-Kill-Switch-Battery-Terminal-Disconnect-Isolator-XH/371640757260?_trksid=p2385738.c100677.m4598&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20160908110712%26meid%3Da772dbaa9d7548f7884de574f8c14a60%26pid%3D100677%26rk%3D3%26rkt%3D50%26sd%3D172448213686
Ken.
Date: 09/07/2017 9:50 PM (GMT+10:00)
Hi Jim,
Sent from BlueMail
