I need a replacement rocker headlight dash switch for my 1989 van.
Tooley Import are out of stock and Volkshome do not have any.
Can anyone suggest another source please?
Thanks. Jim. Sydney.
Hi Jim,
So apparently there are early and late model switches, one different t'other .....
http://www.gowesty.com/search-results.php?search_phrase=headlight+switch
Hello to All.
Hi Jim,
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of jkr100@hotmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>
Sent: Wednesday, 22 March 2017 3:42 PM
Subject: [Syncro_T3_Australia] Headlight Dash Rocker Switch RequiredHello to All.
Hi Ken. Thanks very much for that. Brilliant! Will check mine. Cheers. Jim.
On 22 Mar 2017 4:08 pm, "Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Jim,
Hi Scott. Thanks for the kind offer. I will look and see if it is an 8 or 10 pin switch. Cheers. Jim
On 22 Mar 2017 4:31 pm, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Jim,
I have a spare headlight switch as I bought one thinking it might be my problem for my high beam issues.
Turns out it wasn't.
I can dig it up if you are keen. It has lost a lot of the white headlight decal ink but it works.
On 22/03/2017 4:07 PM, Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia] wrote:
Hi Jim,
Hi Skot.
Thanks again for the offer. I have checked and it is an 8-pin switch.
Cheers. Jim.
Jim,
Hi Jim,
Hi Skot.
Cheers. Jim.
From: Syncro_T3_Australia@yahoogroups.com <Syncro_T3_Australia@yahoogroups.com> on behalf of jim jkr100@hotmail.com [Syncro_T3_Australia] <Syncro_T3_Australia@yahoogroups.com>
Sent: Wednesday, 22 March 2017 6:13 AM
To: Scott; Syncro_T3_Australia
Subject: Re: [Syncro_T3_Australia] Headlight Dash Rocker Switch RequiredHi Scott. Thanks for the kind offer. I will look and see if it is an 8 or 10 pin switch. Cheers. Jim
Jim,
Hi Jim,
Hi Skot. Thank you. I am getting one from Justkampers Auburn as I really need it now. I think it will probably be junk, so would like to hear your op ed about quality please, as I guess yours would be quality German? Thanks again. Cheers Jim
On 24 Mar 2017 1:54 pm, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:
Hi Jim,
My switch was from an 89 model too so it should be the same.
I will check it if I can find it my box of T3spare goodies.
On 24/03/2017 11:49 AM, jim jkr100@hotmail.com [Syncro_T3_Australia] wrote:
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
On 24 Mar 2017, at 15:20, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:I lot of JK stuff is good quality.
I'm sure it will work.
If it fails you have a warranty implied for 12 months or I still have my original factory spare.
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
Thanks Skott.
I broke 2 jk T2 drivers door window winder regulators in 2 weeks having to have the 3rd brazed to equal the original. That part was a mess yet my T2 door handle is good. Yes, will see how the quality is as you say. I really appreciate the offer of your German spare.
Thanks again
Cheers. Jim
Sent from BlueMailOn 24 Mar 2017, at 15:20, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:I lot of JK stuff is good quality.
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
On 2 Apr 2017, at 20:12, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:Jim,
If you need window winder mechanisms I know a bloke or two near me that has them (factory ones).
On 2/04/2017 6:28 PM, jim jkr100@hotmail.com [Syncro_T3_Australia] wrote:
Thanks Skott.
Thanks again
Cheers. Jim
Sent from BlueMailOn 24 Mar 2017, at 15:20, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" < Syncro_T3_Australia@yahoogroups.com> wrote:I lot of JK stuff is good quality.
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
Gday Jim,
In case you are interested, I've recently replaced both my AGM starting and AGM Deep Cycle camping batteries in my syncro Trakka from the following supplier in QLD. I'm in NSW so it's no problem for Peter to courier batteries interstate, arrive at your chosen address no problem. I highly recommended Peter as a source for batteries and his excellent service supplying my order.
Have a read here:
Goto: http://www.batteryvalue.com.au/
Strong carry case housing 12V 40Ah LiFePO4 battery pack. Anderson style, merit, ciga sockets, 4xUSB adaptor. All inputs and outputs controlled by internal battery ...
Thanks Skott.
Thanks again
Cheers. Jim
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
Hi Skot.
I only have access to my phone at the moment & cannot access the list of recommended starter & auxiliary 12v batteries for the Syncro. Would you mind sending me the link please? Thanks.
From memory you had a standout.
Jim.
Sent from BlueMailOn 2 Apr 2017, at 20:12, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:Jim,
Thanks Skott.
Thanks again
Cheers. Jim
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
Hi Jim, not so sure on the best battery to get and what style for the house battery, but just had to replace the battery in my 2WD bus. The battery that fits is spec DIN65L MF (picture below from page Ken linked to)
This one lists 750CCA, but 580-600CCA (rating for a starting battery) is typical for this size battery. Size is 278L/175W/175H and has the terminals below the top, and ridge at the bottom to clamp on as in the picture.
One thing I would recommend, this type of battery often comes with a plastic cover that sits over the +ve terminal. Well worth it when a metal cover sits over the top!!
http://www.batteryvalue.com.au/Banner70.JPG
I have the battery out of the Golf in the Syncro for a while with no issue, basically the same battery, just shorter, spec was DIN53L MF and 550CCA.
It's usually recommended to have a deep cycle battery for the house battery, but unless you drain it a long way regularly, I have not had issues using a starting battery in the past.
On 10 Apr 2017, at 22:57, "cathrich1@yahoo.com.au [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:Hi Jim, not so sure on the best battery to get and what style for the house battery, but just had to replace the battery in my 2WD bus. The battery that fits is spec DIN65L MF (picture below from page Ken linked to)
On 10 Apr 2017, at 16:12, "Ken Garratt unclekenz@hotmail.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:Gday Jim,
Have a read here:
www.batteryvalue.com.auStrong carry case housing 12V 40Ah LiFePO4 battery pack. Anderson style, merit, ciga sockets, 4xUSB adaptor. All inputs and outputs controlled by internal battery ...
Sent: Monday, 10 April 2017 2:05 PM
Subject: Re: [Syncro_T3_Australia] Headlight Dash Rocker Switch RequiredHi Skot.
Jim.
Sent from BlueMailOn 2 Apr 2017, at 20:12, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" < Syncro_T3_Australia@yahoogroups.com> wrote:Jim,
Thanks Skott.
Thanks again
Cheers. Jim
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
On 10 Apr 2017, at 16:16, "Scott Pitcher spbconsulting@bigpond.com [Syncro_T3_Australia]" <Syncro_T3_Australia@yahoogroups.com> wrote:Hi Jim,
I use Varta batteries for my cranking and aux batteries.
There are lots of others out there and other members would know better I would assume.
On 10/04/2017 2:05 PM, jim jkr100@hotmail.com [Syncro_T3_Australia] wrote:
Hi Skot.
Jim.
Thanks Skott.
Thanks again
Cheers. Jim
Hi Jim,
Hi Skot.
Cheers. Jim.
Jim,
Hi Jim,
Spot on Ken. On Scott’s recommendation I went for the Varta one a few years ago and it fits under a Just Kampers swivel seat. Still a bit tricky and from memory I took out the swivel to set it all up. Also got a thick bit of rubber to go on top as a precaution. Runs my waeco fridge very nicely.
Peter from Port
