My heat / vent fan motor has a noisy bearing and I set out to lubricate it in situ. Many years ago, I found this helpful description of how to do it:
http://www.thesamba.com/vw/forum/viewtopic.php?t=386923
I pulled everything off the front and drilled a hole as described – no fan motor in sight!!
The probable reason is that there is a difference between LH drive and RH drive vehicles. ETKA does not show different assemblies, nor does Bentleys, so I am at a bit of a loss. Removing the dash and digging into the entire heater is something that I wish to avoid!
Has anyone had any experience with this?
