If it doesn't, the boots are the same as 14" and I should be able to find the part number.
> Hi all,
> My apologies to those of you on multiuple Lists for the crosspost. I was
> looking to fix my CV boots and wondered if anyone knows how to break
> down
> the L�BRO part numbers. The out CV boot that John Wessels (SyncroMog
> builder) took out of my Syncro 16 many years ago had the following
> markings:
> L�BRO 2 152 15 75 00 029
> Is that the correct part number? John found out that the Audi 200/5000
> turbo
> boots fit the larger Syncro 16 outer CV's. Unfortunately, they do not
> appear
> to be as durable in the Syncro. The boot he took out is the rigid nylon
> type
> vs. the Audi soft rubber type. I may resort to using Audi boots again
> just
> to get my Syncro moving sooner than it takes to order parts from Europe.
> I would like to be able to ask for the right part number other than just
> asking for Syncro 16 boots. I've always found that saying "Syncro 16" is
> just as bad as asking for a parts using a Porsche part number vs. asking
> for
> the exact same part with the VW part number. The difference in names
> seems
> to multiply the price geometrically.
> Thanks in advance,
> BenT
Hi Ben,
You may already have the information, anyway I have a new LOBRO boot in its box as a kit, and the number on the boot is 2 152 15 75 00 025 1-1. The part number for the kit on the box is 251 498 203E. Hope this will be useful.
Yurik
[mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of BenT Syncro
Sent: Tuesday, 28 April 2009 2:07 PM
To: BenT Syncro
Subject: [Syncro_T3_Australia] Help with LÖBRO CV Boot part number /
Syncro 16
crosspost. I was looking to fix my CV boots and wondered if anyone knows how to
break down the LÖBRO part numbers. The out CV boot that John Wessels (SyncroMog
builder) took out of my Syncro 16 many years ago had the following markings:
LÖBRO 2 152 15 75 00 029
Is that the correct part number? John found out that the Audi 200/5000 turbo boots fit the larger Syncro 16 outer CV's. Unfortunately, they do not appear to be as durable in the Syncro. The boot he took out is the rigid nylon type vs. the Audi soft rubber type. I may resort to using Audi boots again just to get my Syncro moving sooner than it takes to order parts from Europe.
I would like to be able to ask for the right part number other than just asking for Syncro 16 boots. I've always found that saying "Syncro 16" is just as bad as asking for a parts using a Porsche part number vs. asking for the exact same part with the VW part number. The difference in names seems to multiply the price geometrically.
Thanks in advance,
It appears that your kit is for a 16" syncro with diff locks from VIN 24-J-050 667 to 24-L-007 602 ('88-'90).
Now the kit is different but the boot may be the same. It may only be one clamp different or it could be the boot.
> Yurik Orlowsky <yuriko@iinet.net.au> wrote:
> Hi Ben,
> its
> part
> Regards
> Yurik
> To: BenT Syncro
> Subject: [Syncro_T3_Australia] Help with L�BRO CV Boot part number /
> Syncro
> 16
> Hi all,
> down
> markings:
> turbo
> appear
> type
> just
> for
> seems
> Thanks in advance,
> BenT
