How do you apply the Syncro sticker
G'day all,
I took advantage of the recent good weather to strip back the front of the van and apply a new coat of paint, which doesn't look too bad from across the road on a dark night.
The next challenge is to apply the "Syncro" sticker. How does it attach?
Roger [Beetle] Bayley
Hi Roger
Stickers are applied by wetting the surface with water, apply the sticker and once in the correct position, squeeze water out with a squeegee (don't if that's the correct spelling ).
Hart,
Sent from my iPad
On 14/05/2013, at 10:20 PM, "gullyraker1953" <Gullyraker@aol.com> wrote:
G'day all,
Roger,
The following link suggests correct dimensional positioning.
I'd still double check other sources or known original sticker, all the same.
Date: Wed, 15 May 2013 22:39:07 +1000
Subject: Re: [Syncro_T3_Australia] How do you apply the Syncro sticker
Hi Roger
Hart,
Sent from my iPad
G'day all,
Someone else asked for the position and I did this for them – see attachment.
Sent: 16 May 2013 00:39
Subject: RE: [Syncro_T3_Australia] How do you apply the Syncro sticker
Roger,
Hi Les,
To replicate the "syncro" sticker original position, starting with a blank canvas, I'm of the view those dimensions are not sufficient.
Others may like to check dimensions on their own "original" sticker as I will and get back here to report accurate findings, that way we can ascertain/confirm exactly the true position and record it accordingly in the files.
Date: Thu, 16 May 2013 09:41:42 +1000
Roger,
Not in the rocket science category.  The top edge of the printing is parallel to the indicated line in the front panel and it is the stated distance in from the side join.
Sent: 16 May 2013 12:00
Hi Les,
Les,
Ok no problem.
I might check a few when I get the chance, just curious because if I replaced mine using those dimensions, it'd end up dissimilar to what it is now.
Date: Thu, 16 May 2013 12:12:05 +1000
Hi Les,
As far as I know, mine is in the original position but cross checking a few more should give a good indication.  On a production line, things like this are usually affixed by using a mask – which is a template that is put in position and has a window in it to locate the sticker.  Any takers please?  It would need only a couple of minutes to check.
Sent: 16 May 2013 14:44
Les,
Ok no problem.
ERROR
Disregard the last post. These are the correct measurements.
Les, can the previous be deleted to avoid confusion? Otherwise their sticker will be out by 2mm.
Top of centre of "n" to crease = 82mm
Top of centre of "s" to crease = 84mm
Top of centre of "o" to crease = 86mm
Right edge of "o" to seam = 53mm
Mine is original.
I have deleted the first message.  Since yours is known to be original, I will change the drawing and put it in files.
Sent: 16 May 2013 16:46
ERROR
Thanks Hart
                   sounds a bit like the way we used to apply the od registration stickers.
  I guess I'm showing my age here.
  Remember when you could register your old splittie for about sixty bucks?
        Roger beetle Bayley
Thanks for all the advice. Will buff back the paintwork on the next warm day [if I live long enough] and apply the sticker. It's been sitting on the shelf for a few years, so I hope it is still O.K.
                                     Cheers, Roger beetle Bayley
