Hi Ken
Hi Ken, After replacing the TX valve and installing a new compressor the verdict is that the prestige system will work well on a cool day. It will blow cool air on my face on a hot day and if I put a curtain between the front and the back that will help.
I have decided there is no magic fix I have had the 2 most experienced car a/c people in town look at it independently and one described the evaporator as the smallest one he had ever seen.
I will be driving across the Nullabour in a week with cold air blowing into my face and a spray water bottle at the ready.
If you get a different result Ken be sure to let me know the secret. Greg
--- In Syncro_T3_Australia@yahoogroups.com, "Greg" <greg_navarro95@...> wrote:
> Hi Ken
> I think what your describing are mushroom adapters from O ring to flare type tx valve.
> The man from OEX told me about them but I have never seen one.
> the valve I installed is a TXX 7004. The flare fittings are for #6 and #8 flare nuts.
> Both this valve and Yuriks are 1.5 ton capacity. I will let you know the outcome of the replacement. May not be until tomorrow until I give it a work out. Regards Greg
> > Hi Greg,
> > Ok good ... nice to see some progress and I'd appreciate your info asap on the valve model you have installed.
> > I've now pulled the old TX valve and had a look at it more closely and concerning its connectors, this is what I found ...
> > There is the valve itself with two open ports, one larger than the other, that are threaded on their outsides. Inserted into each of these ports was a short brass adaptor piece, shaped on the leading (out) side to suit what looks like a flare nut. On the inside of these brass adaptor pieces is a rubber seal, not sure if they would be described as an O-ring but a seal nevertheless. To me it gave the impression that the threaded ports are pretty much standardised in shape such that with the a suitable brass adaptor piece, would suit flare or O-ring connectors, depending upon what your needs are and hence, the type you insert. Just curious then did you or your AC guy notice these short brass adaptors and their rubber seals? They fit snugly into the ends of the ports and they simply pull out with a little help. Makes me wonder then perhaps Yuriks valve is the correct one anyway, just needs the correct brass adaptor pieces and seals to suit in our cases, flare type connectors.
> > Any thoughts on these observations please.
> > Cheers.
> > To: Syncro_T3_Australia@yahoogroups.com
> > From: greg_navarro95@
> > Date: Thu, 13 Dec 2012 12:47:45 +0000
> > Subject: [Syncro_T3_Australia] Re: Prestige AC system
> > Yes Ken
> > I have had the new one fitted today and its being pressure tested overnight for gas up tomorrow. I tracked down the equivalent flare fitting TX valve with the valve Urik fitted to his system. I rang the Australian distributor for the valves and chatted with a research man there. I will give you the part # and let you know if it works. Greg
> > > Hi Greg,Just been talking to my AC guy about the issue of identifying a suitable spec replacement TX valve. I agree with you ... no one seems to know.I'm about to pull my old TX valve and hand it on to him and see what he comes up with. Honestly, identifying the equivalent/correct spec replacement is rocket science.Have you progressed any further yet on identifying a replacement TX valve?Cheers.Ken
> > > Date: Fri, 7 Dec 2012 07:48:16 +0000
> > > Hi Ken and Yurik
> > > I have just come back from the Air cond man and he showed me the old TX valve on the system is a Flare fitting and the new one is an O ring type.
> > > which takes the TX valve replacement back to a lottery. unless anyone has any success with other flare type TX valves that have worked in a Prestige system.
> > > regards
> > > Greg
> > > --- In Syncro_T3_Australia@yahoogroups.com, "Yurik Orlowsky" <yuriko@> wrote:
> > > > Ken,
> > > > Correction, I just checked my old Prestige TX valve and it has O ring type
> > > > connectors. The replacement TX8731 is the same.
> > > > Regards
> > > > Yurik
> > > > From: Syncro_T3_Australia@yahoogroups.com
> > > > [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Ken Garratt
> > > > Sent: Wednesday, 28 November 2012 9:51 AM
> > > > To: _T3_Australia forum Syncro
> > > > Hi Yurik and Greg,
> > > > Just a follow up clarification please. The link below goes to a supply
> > > > source for the TX8731 valve:
> > > > Goto: http://ishop2.cooldrive.com.au/products/TX8731
> > > > Confusingly it states "O Ring" in the model description. Does this infer O
> > > > Ring type connectors for this valve, not "flare " type connectors which I'm
> > > > assuming for this 20 yo system, would have been of the flare type? Any
> > > > thoughts on this please? Or am I misunderstanding something here?
> > > > Also, can you please confirm this TX8731 was a direct swap-in replacement of
> > > > the old TX valve removed (ie, no mods required to the fittings/pipework)?
> > > > Thanks Yurik.
> > > > Cheers.
> > > > Ken
> > > > _____
> > > > From: unclekenz@
> > > > To: syncro_t3_australia@yahoogroups.com
> > > > Subject: RE: [Syncro_T3_Australia] Re: Prestige AC system
> > > > Date: Sun, 25 Nov 2012 23:53:05 +1100
> > > > Thank you Yurik for going to the trouble, valuable information indeed and
> > > > worth noting down for future reference as well.
> > > > Hopefully this info will make my AC service guy a lot happier.
> > > > Cheers.
> > > > Ken
> > > > _____
> > > > Date: Sun, 25 Nov 2012 12:05:04 +0000
> > > > Thanks Yurik
> > > > Greg
> > > > <mailto:Syncro_T3_Australia%40yahoogroups.com> , "Yurik Orlowsky"
> > > > <yuriko@> wrote:
> > > > > Hi Ken, Greg,
> > > > > I have searched documentation on the TX valve that I used and have at last
> > > > > found the invoice and part number of the valve. It is TX8731 purchased
> > > > from
> > > > > Coventrys. It is a replacement unit that I used for the Prestige AC system
> > > > > and has performed well in my AC. If you search the net it comes up as a
> > > > > valve used in Landrover Defender models.
> > > > > Trust this is useful information for you.
> > > > > Yurik
> > > > <mailto:Syncro_T3_Australia%40yahoogroups.com> ] On Behalf Of Ken Garratt
> > > > > Sent: Sunday, 25 November 2012 3:45 PM
> > > > > Hi Greg,
> > > > > No feedback so far on identifying the correct TX valve. I was hoping one
> > > > or
> > > > > more of the members here who have dabbled with syncro AC systems may have
> > > > > some thoughts on the matter.
> > > > > Anyone please? TIA.
> > > > > Cheers
> > > > > Ken
> > > > > _____
> > > > > Date: Sun, 25 Nov 2012 03:51:07 +0000
> > > > > Hi Ken
> > > > > I too am about to replace the TX valve so interested to here if you have
> > > > had
> > > > > any info or feedback on this question. Regards Greg
> > > > > <mailto:Syncro_T3_Australia%40yahoogroups.com> , Ken Garratt <unclekenz@>
> > > > > wrote:
> > > > > > Hi ALL,Does anyone know the correct model and/or specification
> > > > replacement
> > > > > TX valve for this Prestige AC system? Not sure if a "universal" type would
> > > > > do it.Attached are a couple of pics of my present/original TX valve I'd
> > > > like
> > > > > to replace with new. TIA.Cheers.Ken
> > > > > > Date: Thu, 22 Nov 2012 00:41:19 +0000
> > > > > > Hi Francesca
> > > > > > I am in the middle of remediating the prestige ac system in my Trakka.
> > > > > > I have replaced the compressor with a new one and about to replace the
> > > > TX
> > > > > valve over the next few weeks and also make the hole coming out of the
> > > > > outlets on either side of the dash
> > > > > > larger as per a suggestion in a previous post.
> > > > > > I will let you know the outcome.
> > > > > > Greg
> > > > > wrote:
> > > > > > > Hi Francesca,Yurik in Perth has previously reported here his success
> > > > in
> > > > > remediating the Prestige AC system, which has kept me interested to
> > > > attempt
> > > > > a "rebirth" on mine ever since.Logic concludes the two front occupants
> > > > would
> > > > > benefit most, with the front passenger the most smug.Most adults would
> > > > > wisely concur that for the kids in the rear, it's character
> > > > building!Leaves
> > > > > me wondering though all the same, if the Prestige AC system was all that
> > > > > bad, how the heck did so many buyers agree to have it fitted? Did no one
> > > > try
> > > > > it before they bought it?
> > > > > > > As a reminder, please read attached file, some past forum comments on
> > > > > the Prestige AC system topic.
> > > > > > > I live in hope! Cheers.
> > > > > > > Ken
> > > > > > > From: fcoles6@
> > > > > > > Date: Thu, 22 Nov 2012 10:16:09 +1100
> > > > > > > Subject: [Syncro_T3_Australia] Re: Idler pulley
> > > > > > > Hi Ken,
> > > > > > > Precisely nothing has been done to remediate our dodgy Prestige
> > > > air-con,
> > > > > mostly because I have understood from other people that it is
> > > > fundamentally
> > > > > a shonky affair. If anyone begs to differ they can correct me, though.
> > > > > Living in these southern climes and not utilising the Syncro as a daily
> > > > > driver, we don't have quite the motivation to get the air-con up and
> > > > running
> > > > > that others might. I do feel sorry for the kids in the back when it gets
> > > > on
> > > > > the warm side, though.
> > > > > > > Francesca.
