Interpretation of front diff serial number./location of serial no.
Anyone know of the compatability of swapping a non difflock front diff with a
locking
version ? The first problem I have encountered is that my front diff does not
have the serial
number stamped on the top front of the casing as per the Bentley (casting is
still rough
and there has been no preparation for stamping) but does have a serial/model
number
directly underneath on the opposite side which is : 6N/D 41386. (The "N" is on
top of the
"D".) As this does not corresond to anyone elses serial /model numbers I am
unsure of the
compatability and ratio of the ring and pinion. It is an ex Telecom syncro 1991.
Can anyone help me or direct me
to
someone who can decipher the code.
Nick.
Dear Nick,
At the recent Victorian VW car show I was telling someone (Les?) that a local VW wrecker had told me he was bringing in syncro front lockable diffs.That person responded that you have to be very careful to ensure ratio compatibility otherwise your VC becomes very unhappy with you. Your email seems to show awareness of this but whilst I can't be more helpful just wanted to make sure you weren't about to destroy your VC.
If no one in the group responds the VW wrecker is Wolfsburg Automotive  of Essendon Victoria tel (03) 9370 3100  perhaps they can help with advice/supply of correct ratio.
Good luck
Carlton North Vic
locking
have the serial
still rough
number
top of the
unsure of the
to
Nick.
Find local movie times and trailers on Yahoo! Movies.
Nick, Roger, et al,
The Australian delivered Syncros came with 5.43 diffs. The original
brochures put out by Ateco (then the Australian distributor) stated
4.86, but this was incorrect.
What Roger says is correct - the front and rear diff ratios MUST be
the same. The VC will tolerate only a few percent difference in
rotational speeds between the front and rear axles. Running two
different ratios would rip the guts out of the VC.
This said, buying a front diff out of any Australian delivered
Syncro would be safe in respect of the ratio being correct. In any
event, the ratio is easy to check when the diff is out of the
vehicle just by rotating the input shaft and counting the output
revolutions.
And a few words about the front lock. For just about all off-road
driving except the very extreme, the rear lock and VC will get you
just about anywhere. A front lock will give you a few more percent
of capability but at the expense of making the vehicle next to
unsteerable when the front lock is engaged.
There are other means of getting more front traction (solid drive
plus decoupler) but do consider whether the end result will justify
the work and expense.
--- In Syncro_T3_Australia@yahoogroups.com, Roger Bell
<bellrmit@y...> wrote:
> Dear Nick,
> Good luck
> Roger
> Carlton North Vic
diff with a
> locking
diff does not
> have the serial
(casting is
> still rough
serial/model
> number
(The "N" is on
> top of the
numbers I am
> unsure of the
> to
> Nick.
> To visit your group on the web, go to:
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Be careful as there are a lot of odd syncros that Ateco imported and
the diff could be either.
If your front diff is a 6N, the gearbox is 6P (5.43) and there is no
diff locks. A 6PA gearbox has a rear diff lock. The correct front diff
lock would be a ADM.
