Mine is also a ‘92, with 223,000km on the clock, and it’s had a previous
gearbox rebuild, albeit quite a while back (have to check bill for date/kms)
It’s now wanting to pop out of 4th, but also likes to pop out of 1st when
sitting at the lights.
As the gearshifting is a little harder than should be, I’m leaning towards
worn shift linkages etc, so am going to look at fixing that first, which is a
lot easier and cheaper.
Will report on how it goes!
Sent from my iNuke
Hi Gerry,
Jumping out of gear usually means the 4th gear and idler
have worn flanks. 4th gear gets a lot of use and is a common failure point in
a syncro .
Its re-build time unfortunately. Maybe talk to the bank
manger.
Also Rudi is injured and unwell so my re-builder recommendation
is gone also unfortunately.
19 years is an excellent run without major
gearbox issues though - count yourself
lucky!
Hi Syncro t3 group
I have a 1992 t3 syncro that i have had for 19 years. And
i am wondering if some one can give some advice on why it is jumping out of
4th gear ?
The gear box was totally rebuilt about 10 years ago . and
wondering if it is a costly repair ?
Thanks gerard.
Sent from Mail
for Windows 10
Best regards, Scott Pitcher SPB
Consulting
