leaking head
I have recently noticed water leaking from the left hand side of my engine, just where the tin ware bolts onto the motor. I have had a conversation with Paul Muller (Muller & Muller Sydney) regarding this and he suspects that the head gasket is to blame.... One solution he suggested is to put a radiator stop leak into the system hoping that that this will get me out of trouble for the meantime...
I guess if that doesn't work i will be looking for a good VW (Syncro) mechanic hopefully on the western side of Melbourne as i am located in Ballarat. At this stage i am finding it difficult finding anyone with the knowledge to fix it.. I spoke with the local VW/Audi service center today regarding my issue and he replied "Whats a Syncro?"
Any help, suggestions, comments welcomed....
Cheers Tony
Tony,
If it has to be replaced, Volkwerke in Greensborough is the best place to take it.  Lloyd Davies has more experience with the MV engine than most and has a top reputation.  There are a couple of places on the west side but you would need to be well attached to the Mafia to even think of going there!
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of logwood_1
Sent: 19 June 2012 18:06
Subject: [Syncro_T3_Australia] leaking head
Cheers Tony
Tony,
For what its worth, prior to heading off from east to west recently, Graham Adams syncro had a leaky head and was advised to try a not inexpensive you beaut stop leak treatment ... which he then agreed to have done.
Only to discover soon after the treatment that the leak dramatically worsened. So the only recourse was to pull the motor for a head job.
Sounds to me like a trip to a Melbourne based water boxer engine rebuilder. Good luck.
Date: Tue, 19 Jun 2012 08:06:02 +0000
Cheers Tony
Hmm, ok thanks for your advice. I think I'll try the additive for now but it looks like a trip to Greensborough... Should I do any other sort of maintenance while the donk is in bits?? She has 154000ks on her
Tony
To: _T3_Australia forum Syncro <syncro_t3_australia@yahoogroups.com>;
Subject: RE: [Syncro_T3_Australia] leaking head
Sent: Tue, Jun 19, 2012 8:55:06 AM
Tony,
Cheers Tony
Tony,
Don't know your syncro service history nor its present condition, but preventative maintenance is done much more easily while the motor is out than in.
Aside from the head job, a heavy duty clutch kit, then think about all those tricky R, R or R jobs that are hard to do in situ, rule them in or out, such as ...
Starter motor and bush.
Water pump/oil cooler/mini coolant hoses & associated seals.
Oil pump and/or seals.
High and low oil pressure switches and seals.
Exhaust system components could be a can of worms.
Think about where all other engine case orifices seals are located.
I could go on. Life's a bitch! HA!
Date: Tue, 19 Jun 2012 02:38:18 -0700
Subject: Re: [Syncro_T3_Australia] leaking head
Tony
Tony,
Cheers Tony
My head hurts!! I'll give Volksworke a call today and see what they think...
Thanks again
Tony
Sent: Tue, Jun 19, 2012 11:13:10 AM
Tony,
Tony
Tony,
Cheers Tony
Stay away from those "stop leaks" they will cause more harm than good. Greg E
Sent: Wednesday, 20 June 2012 7:42 AM
My head hurts!! I'll give Volksworke a call today and see what they think... Thanks again Tony
Tony,
To: Syncro_T3_Australia@yahoogroups.com From: logwood_1@yahoo.com.au Date: Tue, 19 Jun 2012 02:38:18 -0700 Subject: Re: [Syncro_T3_Australia] leaking head
Hmm, ok thanks for your advice. I think I'll try the additive for now but it looks like a trip to Greensborough... Should I do any other sort of maintenance while the donk is in bits?? She has 154000ks on her Tony
Tony,
To: Syncro_T3_Australia@yahoogroups.com From: logwood_1@yahoo.com.au Date: Tue, 19 Jun 2012 08:06:02 +0000 Subject: [Syncro_T3_Australia] leaking head
Hi all, I have recently noticed water leaking from the left hand side of my engine, just where the tin ware bolts onto the motor. I have had a conversation with Paul Muller (Muller & Muller Sydney) regarding this and he suspects that the head gasket is to blame.... One solution he suggested is to put a radiator stop leak into the system hoping that that this will get me out of trouble for the meantime... I guess if that doesn't work i will be looking for a good VW (Syncro) mechanic hopefully on the western side of Melbourne as i am located in Ballarat. At this stage i am finding it difficult finding anyone with the knowledge to fix it.. I spoke with the local VW/Audi service center today regarding my issue and he replied "Whats a Syncro?" Any help, suggestions, comments welcomed.... Cheers Tony
Thanks to everyone with advice on my leaking head.. I have booked her in for a head job at Volksworke in Greensborough...
Sent: Tue, Jun 19, 2012 10:01:28 PM
Tony,
Tony,
Tony,
Tell Lloyd Davies that you are a member of Syncto_T3_Australia and the referral came via the web group.  (He knows me.)
From: Syncro_T3_Australia@yahoogroups.com [mailto:Syncro_T3_Australia@yahoogroups.com] On Behalf Of Tony Marshall
Sent: 21 June 2012 10:00
Thanks les, I have already mentioned that you refered me to him.. He tells me if all goes well he will have it done in a day..
Cheers Tony
Sent: Thu, Jun 21, 2012 12:21:13 AM
Tony,
