Hi team.
I have a leak where the hose from the brake fluid reservoir enters the master brake cylinder.
There is a hose clamp that connects the supply line to the master brake cylinder @ the bottom via a plastic connector.
This connector is loose and wobbles where it enters the master brake cylinder and brake fluid leaks out drop by drop.
Can that be fixed and how do you do it.
Tom
