Hartmut,
I did in fact vee out the splits with my Dremel but
I didn't want to complicate the instructions too much. Veeing is
the superior technique because it increases the bond area. It is
best done with a small grinder but can also be done with a rough diamond
burr.
For those not familiar with the Dremel, it is a
small, high-speed hand grinder (controllable up to 40,000 RPM) which uses a
collet chuck to hold an amazing (but also expensive!) variety of drills, burrs,
stones, diamond points, even tiny cloth buffs of about 20 mm
diameter. They used to be ferociously expensive (I paid $240 for mine
fifteen or more years ago), but they have come down a very long way in
price. I think that I have seen them in Bunnings. The appropriate
tool for veeing out the crack in the mudflaps is a small
pointed grindstone, up to 10 mm diameter max.
It is now possible to buy diamond points and burrs
from big weekend markets at prices that are incomprehensibly low. I bought
a set in a box a couple of years ago - 20 for $24!! Diamond cutting
wheels are also available, 25 mm diameter, about .5 mm thick, ideal for
glass.
Am I a tool nut? You judge. (Elke,
is Hartmut a tool nut?)
----- Original Message -----From: Elke KiehnSent: Friday, October 19, 2007 6:34 AMSubject: RE: [Syncro_T3_Australia] Re: Mudflap wanted
Oh dear - have we opened a can of worms here??????We buy it normally from Homeware or Mitre 10 as we are no Bunnings fans......It is not a special thing Mark - it has been on the market for many years. It is Swiss and it works.And with Les' brilliant instructions there is just one more thing to add maybe - I cut a deep V groove into the crack using a small angle grinder and let the Sikaflex cure for approx. 1 week (lying flat) before I put the flap back on again.Good luckHartmut..![]()
