Mystery Box Rally 2026- Charleville
Hi Punters,
Just got back late last week from the 2026 Mystery Box Rally and wanted to share some of the fun.
My 2wd T3 did really well and managed the entire event and home without too much trouble.
I did have an issue with the shifter ball on the gearbox riding up to the top of the arm and shifting became almost impossible until I got under the van, pulled the ball back down to the base in the cup and installed a couple of large zip ties to stop it riding back up again - still working, yet a bought a new one to be fitted this weekend). Could easily happen on a syncro - same style of shifter.
I also had an issue with the alternator - the regulator and brushes as one had significantly worn and the spring was very weak allowing it to jamb in the housing and not touch the stator. I managed to lube it and pull the bush out enough to get it to work again until I got to Charleville and replaced it with a new regulator/ brushes set.
The other thing that happened 500m from home - yes half a km was that the catalytic converter inner honeycomb broke up completely and was clogging the exhaust causing the van to struggle badly.
I pulled the muffler and cat off, cleaned out the cat, reinstalled it and it runs great again!
All issues that can affect a syncro.
The van got through the mud, dirt roads and water crossings well.
So much fun!
Start line
Muddy engine after the first morning and some dust in through the tailgate seal.
Thargomindah camping first night - great sunrise!
Animal print dress up day - Healthy and unhealthy Harold!
Pub lunch with my buddy group
Deep water crossing which the 2wd T3 did easily
Nice dirt road and mud on sills
The alternator woes - you can see the gap where the regulator/ brushes go.
Self explanatory
Bloody catalytic converter mess
Great effort to you and Phil, nice to hear you got through well.
Hope the event was a success!!
Thanks Richard.
Yes, It was great - loads of insane people there so I felt right at home!
Well done Scott. Great photos. And a worthy cause. I am impressed with your mechanical skills on the road. Great that you kept the van going and good that you made it. I looked inside my cat once when I replaced exhaust brackets. It was completely empty!!
Thanks Peter.
Agree the Cancer Council is a worthy recipient of the money!
In my opinion, an empty Cat is a great Cat!
