Need to buy a viscous coupling
Hi all, Just joined the group.
I have just bought a 1990 Hightop Camper in very good condition with
220,000 kms on the clock.
I'am looking at buying a VC, mine is dead. I have check the internet
and it looks like they only last for about 100,000 km anyway.
I have done the check, where you jack up the back wheels to see if it
engages, zipp nothing.
Where can I get one from?
Steve
Hello Steve, welcome to the Australian Syncronauts. What part of
Australia are in? One possible source of a new VC is Volkspower in
Melbourne, 03 9808 6777, speak to Dean Coutts, who also owns a Syncro.
Les Harris
--- In Syncro_T3_Australia@yahoogroups.com, "stephencriddle"
it
> Steve
Hi Leslie,
I'am from Geraldton WA, about 400kms north of Perth.
Thanks for that. I will give him a call this week and check the price.
Steve
--- In Syncro_T3_Australia@yahoogroups.com, "Leslie C E Harris"
Syncro.
> Les Harris
with
internet
if
> it
> > Steve
Hi Steve…and welcome.  Have you looked into the option of a Decoupler??  ..you can get these sent to you for around the AUS $2000 mark ..and in my opinion they are worth every cent.  Do you have a Diff Lock with your VW??  Its just a bit easier to install the Decoupler if you do!!  ..but not impossible if you don’t…
Feel free to email/Phone  me direct if you would like more info on the Decoupler’s..What part of the Country are you in??
I'm sure we would all like to see some Photos of your Camper…
Regards..
Ken Tyler
Sent
: Monday, 11 April 2005 5:27 PM
To:
Subject: [Syncro_T3_Australia] Need to buy a viscous coupling
Steve
Hi Ken,
I was thinking if a Decoupler would be a better option, if there
around the same price. Just reading about them on the net last night.
I'am in Geraldton about 400km north of Perth
I will send some photos through of the Syncro.
Steve.
--- In Syncro_T3_Australia@yahoogroups.com, "Ken Tyler" <kct@i...>
wrote:
> Hi Steve.and welcome. Have you looked into the option of a
Decoupler??
in
your
do!! ..but
> not impossible if you don't.
the
> Decoupler's..What part of the Country are you in??
> I'm sure we would all like to see some Photos of your Camper.
> Regards..
> Ken Tyler
> From: stephencriddle [mailto:criddle@w...]
> Sent: Monday, 11 April 2005 5:27 PM
with
internet
it
> Steve
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> <mailto:Syncro_T3_Australia-unsubscribe@yahoogroups.com?
subject=Unsubscr
> ibe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms
of
> Service <http://docs.yahoo.com/info/terms/> .
Hi Steve,
There is a bit of divided opinion about decouplers.  I'm of the view that I want my 'all wheel drive' available at all times (it having saved my bacon at least twice on bitumen roads, at times when I would never have had a chance to 'switch in' a decoupler), so I wouldn't fit a decoupler even if it was given to me.
But you need to do something about your VC even if you fit a decoupler, since it sounds like it has failed in the 'open' mode (ie not connecting drive to the front axle sufficiently or at all).  Thus even with a decoupler you still have only 2wd, until you replace the VC with either a solid shaft or a welded or 'closed failure' (ie too stiff) VC. As it happens I have one of these in my shed, having replaced it with a new VC I obtained from Derek Drew in the States. It's available for sale at about 10% of new price if you decide to go the decoupler route. (heavy to ship though).
Reading the American list, about the only firm advantage of the solid connection & decoupler set-up, against a properly working VC, would seem to be in soft sand (which may apply to you), although even this is disputed by some who say the real key to sand driving is sufficient 'airing down'.
Check out VC prices from Derek, or Berndt Jaeger in Germany, and factor in a solid shaft, or stiff VC to add to your decoupler, to compare the total cost.  If I recall, it cost me about $2200 including duty and GST to land my VC from Derek, but the $AUD is a lot stronger against the $US than it was then. Installation of the VC is relatively quick & simple, and should be less than a decoupler.
good luck,
Brian Reed
Melbourne
Sent: Tuesday, April 12, 2005 5:18 PM
Subject: [Syncro_T3_Australia] Re: Need to buy a viscous coupling
Hi Ken,
Steve.
Decoupler??
in
your
do!!  ..but
the
> Regards..
> Ken Tyler
with
internet
it
> Steve
>   _____
subject=Unsubscr
> ibe>
of
hi all,
as some of you know, we used a vc while travelling oz.
since one week we've been having the decoupler and solid shaft instead of the vc.
our gearbox (with 190 000 km on it) had completely gone.
the pro's and con's for both systems have been discussed heavily in other newsgroups, so we don't want to raise the discussion again. we only want to express that we're absolutely happy with the decoupler because
-> we know driving and steering is a lot easier without awd
-> fuel consumption has dropped by 1,5 liters (!) in 100 km (new gearbox can come into
    play as well)
-> we hope a decoupler and a shaft don't need to be replaced anymore
-> we hope the gearboxes and drive shaft will need servicing a lot less
-> we don't think we really need an awd on dry or wet bitumen. on gravel the vc is
    probably best. but in sand, even with air pressure let down and both diff locks
    engaged we got stuck - which we believe wouldn't have happened with the solid shaft.
that's all not technical knowledge - just experiences through travelling.
regards to all
joachim and jasmin
Steve,
I concur with Brian's opinions.  A VC operating in its specified
range of torque transfer is an extremely good drive system which
works well on dry bitumen, wet bitumen, good gravel and atrociuos
surfaces.  An aggressive/stiff VC is the next best but a non-
functioning VC is nothing at all.
The only time that an "aggressive" VC is a liability is tight turns
on dry bitumen, as in parking manoeuvres.  I am running
an "aggresive" VC and I am about to fit a decoupler.  It is probable
that I will leave the drive engaged for general driving and switch
it out only for tight msnoeuvres.  I have yet to decide whether I
would switch it out on long freeway or highway driving.
There is considerable security in running the AWD system as it was
originally designed but, as Brian says, you will have to sum up the
cost factor as well.  My preference is first a normal to stiff VC,
second a VC with decoupler, and a very distant third is solid drive.
Hi Steve,
good luck,
Brian Reed
Melbourne
Joachim and Jasmin,
Thanks for that. As I do a lot of gravel road driving, I was thinking
the VC was the best option. If the decoupler was engaged all the time
while driving on gravel roads, it would put a lot more strain on the
drive train than a VC.
Steve
--- In Syncro_T3_Australia@yahoogroups.com, uluru2002@a... wrote:
> hi all,
instead of
> the vc.
in other
only want to
gearbox can
> come into
> play as well)
anymore
less
gravel the
> vc is
and both
> diff locks
with the
> solid shaft.
travelling.
> regards to all
> joachim and jasmin
> Steve,
turns
probable
the
drive.
> Hi Steve,
view that I
my bacon at
a chance
it was
> given to me.
decoupler,
connecting drive to
decoupler you
shaft or a
one of these
Drew in the
decide to
solid
would seem to be in
by some who
factor in a
total
to land my VC
was then.
less than a
> decoupler.
> good luck,
> Brian Reed
> Melbourne
> Hi Steve,
> good luck,
> Brian Reed
> Melbourne
> Hi Ken,
night.
> Steve.
<kct@i...>
> Decoupler??
mark ..and
> in
with
> your
> do!! ..but
on
> > Regards..
> > Ken Tyler
> with
> internet
if
> it
> > Steve
> > _____
> > Yahoo! Groups Links
> subject=Unsubscr
> > ibe>
Terms
> of
> a.. To visit your group on the web, go to:
> b.. To unsubscribe from this group, send an email to:
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
