Yes Theo that's correct. Ive left one of the analog outputs as is to mimmick the oem 02 sensor and programmed the other to suit me. As mentioned in an earlier post, be careful not to connect that second output without first reprogramming it's output voltages. From memory factory defaults were 0 to 5 volts and not sure how the ecu would react to a extra 4 odd volts. I programmed the second output with 1.2 volts as a maximum (to give a rich mixture) and .2 volts to give a lean mixture(from memory -I'd have to recheck my values). This actually reverses the graph from factory defualt but it seems to work. As i said there is still a bit of tweeking to do so hopefully I can get some input from yourself and Greg when your installs are complete. Good luck and hope it gets you good results .
Eddie.
Eddie.
> Hi Eddie,
> I'm just in the process of fitting my AFR gauge.
> Am I right in understanding that you are not using the factory O2 sensor but
> instead the AFR sensor? Thereby be able to change
> the ECU setting with the lap-top?
> Theo
> At 11:00 AM 14/07/2012, you wrote:
> >I'm happy to report that all is well with my new
> >set up . My syncro feels more like my 2wd to
> >drive . Has power to accelerate , climb hills &
> >even enough for the odd overtaking manouvre. I
> >haven't really done an economy run yet as I'm
> >constantly putting the foot down to check if
> >that go is really there. The only drawback so
> >far is that it gets the odd hiccup while driving
> >before it reaches operating temp, but after it
> >does, all is good. I haven't done much searching
> >for a vaccum spdt switch as I only run on petrol
> >when I need power so I switch to the richer
> >mixture when on petrol. the rest of the time I'm
> >on gas & the gas system I have runs off vaccum
> >to determine air fuel mixture ,so the 02 signal
> >is irrelevant. I'm contemplating setting up the
> >same gauge/system in my stock 2wd to see if it
> >makes a difference. Still have some fine tuning
> >to do but has already exceeded my power expectations with this engine. Eddie.
> >--- In
> ><mailto:Syncro_T3_Australia%40yahoogroups.com>Syncro_T3_Australia@yahoogroups.com,
> >"eddie" <bergodaz@> wrote:
> > > For all who are interested (in particular
> > Greg E) I have just succesfully wired my AFR
> > gauge's 02 sensor to run my engine at 2 pre
> > determined AFR's.One at 14.7 for cruising and
> > one at 13.5 for when the engine is under load.
> > Works really well in prelim testing, has quite
> > a bit more go when accelerating. Will see how
> > it goes in normal driving during the week. Eddie.
> > > --- In
> > > > I've been able to do a bit of internet
> > research on my AFR gauge & what it can do for
> > the MV engine. Turns out you can customise the
> > output signal or voltage, it sends to the ECU
> > when you use it's 02 sensor in place of the
> > stock 02 sensor. This is done by running the
> > supplied program, plugging the gauge into a
> > laptop & altering the numbers.(should read ALL
> > the instructions before fitting & not just the
> > quick install) Almost brings Digifant into this
> > century. I'll have a go at it on the weekend &
> > report the results. Hopefully I don't stuff it up! Eddie.
