New engine and air fuel ratio gauge
Hi Greg, congrats on your expanding family news. Sure it's not a good time to consider a syncro caravelle? Another option wuold be a his and hers syncro . See how good you are at getting that one passed the finance police!
To answer your question , I am in and aruond the burbs pretty much every day so just let me know the days that would best suit you . Call or text on 0413585530 if you like. Eddie.
> Hey Eddie the switch has arrived. Looks good too. I had the right terminals in stock so i put those on. Are you in the big smoke any time soon? Greg E
> --- In Syncro_T3_Australia@yahoogroups.com, "eddie" <bergodaz@> wrote:
> > I've been able to do a bit of internet research on my AFR gauge & what it can do for the MV engine. Turns out you can customise the output signal or voltage, it sends to the ECU when you use it's 02 sensor in place of the stock 02 sensor. This is done by running the supplied program, plugging the gauge into a laptop & altering the numbers.(should read ALL the instructions before fitting & not just the quick install) Almost brings Digifant into this century. I'll have a go at it on the weekend & report the results. Hopefully I don't stuff it up! Eddie.
Hey Eddie, around Saturday and monday to thursday.
Sent: Friday, 31 August 2012 8:02 AM
Subject: [Syncro_T3_Australia] Re: New engine and air fuel ratio gauge
--- In mailto:Syncro_T3_Australia%40yahoogroups.com, "gregespo73" <gregespo73@...> wrote:
> --- In mailto:Syncro_T3_Australia%40yahoogroups.com, "eddie" <bergodaz@> wrote:
Hey Greg, just finished installing the switch & gotta say it works an absolute treat! Reacts quicker than I had expected about 1-2 seconds from hitting the go pedal to seeing a richer mixture . Not enough to see best ET's down the quarter mile but certainly enough to make up for some of digifant's shortcomings. Still have to do some highway testing but real impressed so far. Eddie.
Very happy to hear that Eddie. Did it take long to get the ideal vacuum switching point sorted? Did you end up running my vacuum gauge up front to do it? If so care to share what inches of mercury you set it at? Greg E
Sent: Saturday, 15 September 2012 1:08 PM
Did a quick check of vacuum at the fuel pressure regulator and took an educated (dumb?) guess that where you set it was a good starting point. With the 2 analogue out signals I programmed them both so they dont have much choice in afr's. For example the rich circuit I have .1v=13afr and 1.1v=13.1afr. this seems to limit the amount of straying from my prefered values. With the gauge as a guide it's easy to regulate when you want to run rich or lean so the the exact switching point doesn't seem too critical at this early stage. Is your engine together yet or have your kids claimed all your time? Eddie.
> From: eddie <bergodaz@...>
> Â
> --- In mailto:Syncro_T3_Australia%40yahoogroups.com, "gregespo73" <gregespo73@> wrote:
Thats exactly what I was thinking I would do. Rich side set to 12.8- 13.2 and cruise set to 14.5 ish may be leaner.
Yeah the kids are definately eating up all my quality syncro time. Really frustrated now because I have everything ready to go but no time to do it. I have the cases preped, the rods and cam are clearanced. The pistons are back from the machinist. Crank is assembled. Ported and replaced guides in one head and half way through the other. I reconditioned the starter and replaced the cross shaft and bushes whilst the trany is out. Soooooo just need a free day to get the crazy glue out and put the cases together...
Sent: Saturday, 15 September 2012 4:57 PM
--- In mailto:Syncro_T3_Australia%40yahoogroups.com, greg esposito <gregespo73@...> wrote:
> To: mailto:Syncro_T3_Australia%40yahoogroups.com
Greg,Eddie,
I'm missing out on all this. When we are back in Melbourne I'll have to
catch up with what you have done.
I'm basically happy with my set-up,definately more gruunt, did not get
stuck on Fraser I. in the sand like last time.
But the Idle is still an issue.
Theo & Chris
13.2
a> nd cruise set to 14.5 ish may be leaner.
Really
f> rustrated now because I have everything ready to go but no time to do
it.
I> have the cases preped, the rods and cam are clearanced. The pistons
are
ba> ck from the machinist. Crank is assembled. Ported and replaced guides
in
on> e head and half way through the other. I reconditioned the starter and
repl> aced the cross shaft and bushes whilst the trany is out. Soooooo
just
need> ��a free day to get the crazy glue out and put the cases
together...�> �
> From: bergodaz <bergodaz@ozemail.com.au>
educ> ated (dumb?) guess that where you set it was a good starting point.
With
th> e 2 analogue out signals I programmed them both so they dont have much
choi> ce in afr's. For example the rich circuit I have .1v=13afr and
1.1v=13.> 1afr. this seems to limit the amount of straying from my
prefered values.
W> ith the gauge as a guide it's easy to regulate when you want to run
rich
or> lean so the the exact switching point doesn't seem too critical at
this
ea> rly stage. Is your engine together yet or have your kids claimed all
your
t> ime? Eddie.
vacuum
s> witching point sorted? Did you end up running my vacuum gauge up front
to
d> o it? If so care to share what inches of mercury you set it at? Greg E
abs> olute treat! Reacts quicker than I had expected about 1-2 seconds
from
hitt> ing the go pedal to seeing a richer mixture . Not enough to see
best ET's
d> own the quarter mile but certainly enough to make up for some of
digifant's> shortcomings. Still have to do some highway testing but real
impressed so
> far. Eddie.
termi> nals in stock so i put those on. Are you in the big smoke any time
soon?
Gr> eg E
wha> t it can do for the MV engine. Turns out you can customise the output
signa> l or voltage, it sends to the ECU when you use it's 02 sensor in
place of
t> he stock 02 sensor. This is done by running the supplied program,
plugging
instruc> tions before fitting & not just the quick install) Almost brings
Digifant
i> nto this century. I'll have a go at it on the weekend & report the
results.> Hopefully I don't stuff it up! Eddie.
Message sent using MelbPC WebMail Server
