Well I'll be sticking around a while longer yet. Seems my wheel bearings though worn weren't the culprit of my wobbly wheel. Anyway thus far I have pulled the whole front end apart again (getting good at this) Removed the wheel,brake disc and cv joint and rotated the hub. It's a long way out by around 5mm when rotating by hand. To me it suggests either the cast iron arm which seats the wheel bearing could be warped or the hub is bent. I don't know about the condition of the outer cv joint so it may well be bent too. Any one have any other ideas?
God knows what abuse this van has been through at the mercy of the previous owner.
I know of a wrecker with a syncro nearby that I may be able to source a new hub and the cast iron arm from but highly doubt the outer cv will still be there as all the good bits are already gone. Next question is does anyone know where I can source a new outer cv joint from?
Looks like I'll be paying a visit to imparts too for another wheel bearing seeing as It'll be damaged when I disassemble the hub.
cheers and may I be on the road to perth soon:)
